Author Subject: Steel Prices / Part No.s
silky
Anyone know the price and part number for the H2 GTI6 Steels?
Are these similar in price to the C5 Steels?
I guess H2 steels take the flat seat bolts from the Cyclones and C5 take tapered bolts?
Think the Rallye could do with some Steels to go with the Pe2's I have in the garage
Posted 27th Nov 2012 at 12:08
silky
Looked through loads of old threads quoting various differen part numbers
Is the C5 PS815011 ?
Posted 27th Nov 2012 at 12:15
Later steelies used taper bolts, early C5 wheels took flat seat but were recalled due to cracking.
C3 or 307 steelies are significantly lighter, only half a kilo more than C5 alloy ones, only trouble is that the earlier on they are ET27, they are ET23 on newer ones.
5401 H7 is the part number for a 15" 306 steelie, £42.
5401 L7 is the C5 ally ones, £92 now Shock
There looks to be a wheel that may be alloy on the new C3 which is ET23 Hmm
the PS part number is the actual manufacturers own part number which you'll find stamped on it.
Posted 27th Nov 2012 at 12:26
silky
Cheers Mei, they're the numbers I'm looking for
I'm guessing those prices are +vat so even GTI6 Steels are priced at £200 for four
Getting into expensive territory
Posted 27th Nov 2012 at 14:11
I've probably got 4 GTi6 steels kicking about if you'd consider a used set.
  • Posted 27th Nov 2012 at 14:13
    silky
    Would do as long as they're straight and at a couriered price don't cost too much
    Posted 27th Nov 2012 at 14:27
