displaying posts 1 to 25 of 31
Author Subject: Flywheel question
moxigti6
Has anyone got a lightweight flywheel on there car? If so what does it run like under 2000rpm because mine runs and drives quite lumpy under 2k in the higher gears I'm just wondering if its normal with the flywheels fitted or weather iv got another problem? If I is the flywheel then il happily live with it I just want to rule everything out first.
Moonstone gti6
Posted 25th Nov 2012 at 19:12
I've got one fitted, and also got a very slight misfire/lumpyness at light throttle under 2000 rpmDunno
Flywheel never crossed my mind, but it did start around the time I fitted itDunno
Posted 25th Nov 2012 at 19:35
Yup mine does this doesn't like running smoothly all te time when cold either a few of us from Kent meets noticed we all have the same issue and we all have lightened flywheels. Cant say for sure yours is the same though but quite likely.
Posted 25th Nov 2012 at 19:57
moxigti6
That's a relief don't have to worry about it being anything else now lol but that's exactly what mine does tho light throttle just under 2000 rpm and like u say worse when cold and trust me its definately the flywheel causing it iv spent bloody ages replacing things literally everything u could imagine had the timing belt replaced twice the first time I done and just to make sure I got a garage to do it again someone I know even lent me a perfectly working but unused gti6 to strip all the bits off and put on mine. Waste of time tho ay I just can't bare driving it knowing there might be a problem if I know what it is then I don't mind but if not I have got to find it haha
Thanks for the replies
Moonstone gti6
Posted 25th Nov 2012 at 20:11
Yeah exactly like mineThumbs down
Sounds like it's overfueling slightly, wonder if a remap could get rid of it?
Posted 26th Nov 2012 at 21:58
JWP EFi
Turbo Legend!
if you think its over fuelling when cold, then have you changed the coolant temp sensor?
Posted 26th Nov 2012 at 22:12
Good point, have you tried this Kev? Dunno
Posted 27th Nov 2012 at 06:30
YeahThumbs up new one fitted when first started running lumpy
Posted 27th Nov 2012 at 16:30
Maybe it's the Air Intake Temp sensor at fault, have you tried this one at all?
Posted 27th Nov 2012 at 16:51
davewagon
My motor (when it runs) has a flywheel, and apparently when it was fitted it highlighted injector timing issues (causing stalling or some s**t)
So it was remapped by Wayne (Chipwizards) and now runs lovely at idle
(slight lump every now and then, but it has pt80 cams in it too)
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 27th Nov 2012 at 17:04
Yeah, new one fittedThumbs up
Ah right cheers, good to knowBig grin
How much is a remap from chip wizards?Smile
Posted 27th Nov 2012 at 18:42
Around the £400 IIRC. Yes
davewagon
£400
plus a tank of fuel, and your travelling costs ...
Posted 27th Nov 2012 at 20:32
Thats alot of money for a remapYes
Why is it only chip wizards can map these, due to equipment needed?Dunno
Posted 29th Nov 2012 at 11:14
pretty much, a map for a DTA is about £100 less IIRC.
Posted 29th Nov 2012 at 11:53
rob_humphrey
Mine does exactly the same as well Thumbs up
Team Moonstone Big grin
Team Working Aircon
Posted 29th Nov 2012 at 12:01
niw
Same with mine Smile but f**k it, never run at low RPM anyway Wink
Posted 29th Nov 2012 at 12:19
Would I be correct in thinking a full map on a dta etc would be a lot more work than a tweaked map on a standard ecu?Dunno
Or can't the standard ecu map be tweaked, and requires a full remap?Smile
Posted 29th Nov 2012 at 13:01
A standard ECU map can be tweaked. Yes
Posted 29th Nov 2012 at 13:10
Ok ta.might give chip wizards a ring, can't see him wanting £400 just to tweak standard map?Thumbs up
Posted 29th Nov 2012 at 13:59
yes he will, tis the same process.
a further adjustment of an already socketed ecu would be less I believe.
Posted 29th Nov 2012 at 14:07
ryangti6
There are others that can do it, or so I've been told. I personally spoke to Midland performance centre who claimed they could do it, apparently the chap there used a gti6 as his uni project so has the equpiment to do it.
My understanding is you need an emulator to be able to talk to the Ecu hence there are not many people that have developed one to do it.
Ryan
Posted 29th Nov 2012 at 14:13
For £400+ id just put up with it! LOL
Posted 29th Nov 2012 at 14:16
Yes, this is correct. If your ECU is standard then you will have to have it socketed to take an EEPROM. If this process was already done, then it would be a lot cheaper to tweak that map. Yes
Posted 29th Nov 2012 at 14:23
that must be annoying actually! nearly put a lightened FW into mine. glad i didn't now. now i can worry about interior parts falling off and imminent cambelt failure rather than a misfire
Posted 29th Nov 2012 at 14:24
