Moonstone gti6
displaying posts 1 to 25 of 31
| Author | Subject: Flywheel question |
moxigti6
Newbie Location: gport Registered: 14 Aug 2011 Posts: 25 Status: Offline |
Has anyone got a lightweight flywheel on there car? If so what does it run like under 2000rpm because mine runs and drives quite lumpy under 2k in the higher gears I'm just wondering if its normal with the flywheels fitted or weather iv got another problem? If I is the flywheel then il happily live with it I just want to rule everything out first. ________________________________________ Moonstone gti6 |
I've got one fitted, and also got a very slight misfire/lumpyness at light throttle under 2000 rpm Flywheel never crossed my mind, but it did start around the time I fitted it ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Yup mine does this doesn't like running smoothly all te time when cold either a few of us from Kent meets noticed we all have the same issue and we all have lightened flywheels. Cant say for sure yours is the same though but quite likely.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
moxigti6
That's a relief don't have to worry about it being anything else now lol but that's exactly what mine does tho light throttle just under 2000 rpm and like u say worse when cold and trust me its definately the flywheel causing it iv spent bloody ages replacing things literally everything u could imagine had the timing belt replaced twice the first time I done and just to make sure I got a garage to do it again someone I know even lent me a perfectly working but unused gti6 to strip all the bits off and put on mine. Waste of time tho ay I just can't bare driving it knowing there might be a problem if I know what it is then I don't mind but if not I have got to find it haha Thanks for the replies ________________________________________ Moonstone gti6 |
Yeah exactly like mineSounds like it's overfueling slightly, wonder if a remap could get rid of it? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
JWP EFi
if you think its over fuelling when cold, then have you changed the coolant temp sensor? |
stan_306gti6
T99PUG wrote: if you think its over fuelling when cold, then have you changed the coolant temp sensor? Good point, have you tried this Kev? ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: T99PUG wrote: if you think its over fuelling when cold, then have you changed the coolant temp sensor? Good point, have you tried this Kev? ![]() Yeah ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6
Maybe it's the Air Intake Temp sensor at fault, have you tried this one at all?________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
davewagon
Senior User Location: Corby / Northampton Registered: 21 Feb 2007 Posts: 889 Status: Offline |
My motor (when it runs) has a flywheel, and apparently when it was fitted it highlighted injector timing issues (causing stalling or some s**t)So it was remapped by Wayne (Chipwizards) and now runs lovely at idle (slight lump every now and then, but it has pt80 cams in it too) ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
stan_306gti6 wrote: Maybe it's the Air Intake Temp sensor at fault, have you tried this one at all? Yeah, new one fitted davewagon wrote: My motor (when it runs) has a flywheel, and apparently when it was fitted it highlighted injector timing issues (causing stalling or some s**t) So it was remapped by Wayne (Chipwizards) and now runs lovely at idle (slight lump every now and then, but it has pt80 cams in it too) Ah right cheers, good to know How much is a remap from chip wizards? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6
coskev wrote: How much is a remap from chip wizards? Around the £400 IIRC. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
davewagon
£400plus a tank of fuel, and your travelling costs ... ________________________________________ Team: Moonstone GTI-6™Team: ian7675 wrote: Remember....a 6 isn't just a car, it's a part time job |
Thats alot of money for a remap Why is it only chip wizards can map these, due to equipment needed? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
pretty much, a map for a DTA is about £100 less IIRC.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rob_humphrey
Regular Location: St Austell Registered: 16 Sep 2011 Posts: 448 Status: Offline |
Mine does exactly the same as well ________________________________________ Team Moonstone![]() Team Working Aircon |
niw
Junior User Location: Frederiksberg Registered: 30 Jan 2012 Posts: 73 Status: Offline |
Same with mine but f**k it, never run at low RPM anyway |
welshpug! wrote: pretty much, a map for a DTA is about £100 less IIRC. Would I be correct in thinking a full map on a dta etc would be a lot more work than a tweaked map on a standard ecu? Or can't the standard ecu map be tweaked, and requires a full remap? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
stan_306gti6
A standard ECU map can be tweaked. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6 wrote: A standard ECU map can be tweaked. ![]() Ok ta.might give chip wizards a ring, can't see him wanting £400 just to tweak standard map? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
yes he will, tis the same process.a further adjustment of an already socketed ecu would be less I believe. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
There are others that can do it, or so I've been told. I personally spoke to Midland performance centre who claimed they could do it, apparently the chap there used a gti6 as his uni project so has the equpiment to do it.My understanding is you need an emulator to be able to talk to the Ecu hence there are not many people that have developed one to do it. ________________________________________ Ryan |
For £400+ id just put up with it! |
stan_306gti6
welshpug! wrote: yes he will, tis the same process. a further adjustment of an already socketed ecu would be less I believe. Yes, this is correct. If your ECU is standard then you will have to have it socketed to take an EEPROM. If this process was already done, then it would be a lot cheaper to tweak that map. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rikky
that must be annoying actually! nearly put a lightened FW into mine. glad i didn't now. now i can worry about interior parts falling off and imminent cambelt failure rather than a misfire________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
