Author Subject: engine tapping why ??
daipugralio
just had my head recon by engnering company , fitted 16 new vales 16 new buckets new seals and its still tapping , any idea wat this tapping noise is ?? its driving me mad Dunno
d james
Posted 22nd Nov 2012 at 18:18
smegal
Does it get louder with the revs and sound like a sewing machine?
Ex SC-6
Now in a Megane R26
Get a video up
  • Posted 22nd Nov 2012 at 18:19
    playboyb
    Like dan said get a video up mate Thumbs up
    306 1.8 xs moonstone blue-SOLD
    306 gti6 supercharged china blue-SOLD
    406 coupe D9 3.0 V6-SOLD
    Posted 22nd Nov 2012 at 18:21
    Did they do the valve guides ? Who put the head back on the car ?
    I suspect the guides had not been done and 1 is slightly damaged ? Or who ever put the yea back on did it wrong and bent. Valve Yes
    Posted 22nd Nov 2012 at 18:23
    bas_306gti
    probably bent valves, caused when refitting the head (intake valve hitting exhaust valve when rotating camshafts)
    Posted 22nd Nov 2012 at 18:24
    daipugralio
    it does get louder when u rev it , i fitted my self ,
    d james
    Posted 22nd Nov 2012 at 18:29
    daipugralio
    no they didnt do vale guides ??
    d james
    new crank pulley? did you rotate any of the cams more than a few degrees just to get the pins in?
    also, have you driven it a decent distance so the tappets fill up properly.
    Posted 22nd Nov 2012 at 18:31
    daipugralio
    yes i did turn them a few degrees , ive done 2 rallys in the car goes well , well over 300 miles
    d james
    Posted 22nd Nov 2012 at 18:34
    daipugralio
    this crank pulley is this why am strugleing to line the pins up
    d james
    Posted 22nd Nov 2012 at 18:35
    Crank pulleys slip,so if it has slipped and you time it up using the hole in the pulley it could well be outThumbs down
    Should have checked themSad
    Posted 22nd Nov 2012 at 18:43
    daipugralio
    ok cheers will put a vid up over the weekend , then strip it .
    d james
    Posted 22nd Nov 2012 at 18:46
    The valve guides will probably be ok. Yes
    As said though, you need to ensure your crank pulley lined up correctly as they do slip. Also, it's very easy to bend the valves on the head refitting, I mean like silly easy. Sad
    Posted 22nd Nov 2012 at 19:53
    bas_306gti
    they almost bend by looking at them Sad Sad
    The good old XU with 8 valves didn't have that problem...
    Posted 22nd Nov 2012 at 22:22
    kingykingy
    i have the same problem and i asked a queston to my mechanic and he sed its ether tappits or a bend valve iv only had the 6 for 4 months and bought it with the noise, my mechanic sed it will cost a bomb to repair should i just get a engine rebuild or new engine?
    jamie king
    Posted 29th Dec 2012 at 16:15
    Cheaper to get a decent engine then sell yours to recoup the cash.
    If youre looking for one, drop me a pmThumbs up
    Posted 29th Dec 2012 at 16:30
    aaron6
    What rat said is true. It's gotta be the easiest and cheapest way. Smile
    Posted 29th Dec 2012 at 17:12
    I'm not sure it's easier, it's easier to have a head off than swap a whole engine.
    Also, the cost of sorting the tapping may end up around £650-£800 depending on what's wrong, versus an engine for say £300. However, when you buy a second hand engine you don't know too much about the internal condition of it, wheras if you know your bottom end is good, it may be worthwhile sorting the head on yours.
    Posted 29th Dec 2012 at 18:09
    Really? Just taken the engine out of the Vile i'm breaking under 3 hours Wink
    And if you buy an engine like say the one i'm selling Whistle with good history etc you shouldnt go too far wrong.
    Posted 29th Dec 2012 at 18:20
    24seven
    ^^ This. Even if you factor in another belt and tensioner set for the complete replacement engine, I'd still say it's far easier to do a complete change than strip the head, get it fixed and refit at a (most likely) higher cost. Also Ratty's been through enough of these now to have a good idea of a good engine from a bad one and if it's got history with it I'd say it's a no-brain'er.
    Posted 29th Dec 2012 at 18:27
    Yes, if you *know* the engine. Yes
    I would personally fix the head if it were me, but then I would do it myself so save on the labour cost. Wink
    Posted 29th Dec 2012 at 19:12
    Thats where you,I and others are different.
    Agreed doing a HG isn't the hardest but not the easiest.And for someone like you it's not a massive job but you're a hero Wink
    Also as we've seen before sometimes the bottom ends fail after having the HG done.Horses for courses pal Wink
    Posted 29th Dec 2012 at 19:27
    doing a HG in the car is a right kent, ripping the lump out is far easier.
    Posted 29th Dec 2012 at 19:41
