Author Subject: Top Mount Part Number
darkstar753
Looking to refresh my suspension over xmas and wanted to check I had the right part number for a top mount refresh
Part im looking at is 5031 60 Mounting Ass (number 10 on diagram) is this right or will it be a case of I should only require the actual bearing?
darkstar753 has attached the following image:
Darkstar
Posted 16th Nov 2012 at 09:28
Number 10 indeed, I bought one not so long ago.
52 each iirc
Posted 16th Nov 2012 at 10:56
darkstar753
Yea £51.46 according to servicebox
Darkstar
Posted 16th Nov 2012 at 11:04
jord294
item 2 isn't included in the kit, and price each is around £20
Posted 16th Nov 2012 at 11:29
darkstar753
Is that part required, as I cant imagine it wearing out - could be very wrong of course.
Darkstar
Posted 16th Nov 2012 at 11:42
really depends on the condition, if you only need the bearings good ones can be had in the aftermarket for about £8.
Posted 16th Nov 2012 at 11:43
c_j_m
Complete skf kits are around £55 from ecp for the pair and thats before any discount and they have 30 off atm with the code midmonth30 which makes them under £40!
http://www.eurocarparts.com/ecp/c/Peugeot_306_2.0_2001/p/car-parts/suspension-and-steering/suspension/suspension-mounting/?669730040&1&b057217cc385ade26cd4a62c7d78eeebe53d8ddf&000872
Posted 16th Nov 2012 at 11:56
darkstar753
Wasnt 100% sure if that price on ECP was for a pair or just for one side :s
Darkstar
Posted 16th Nov 2012 at 12:29
"qty per axle:1"
pic shows a pair, I'd go with it being a car kit rather than single side kit.
Posted 16th Nov 2012 at 12:33
darkstar753
true, well we'll see probably worth a shot Smile may have to see what the SKF guy who appears at work occasionally can lay his hands upon
Darkstar
Posted 16th Nov 2012 at 14:53
Those #2 rest cups, are they generic between 205's and 306's?
  • Posted 19th Nov 2012 at 11:49
    they look like they would be, but easy enough to check, just cross reference the part number, given its the same bearing, and quite a few 205 springs are also used on 306's and partners, I;d say they would fit, but can;t remember if the part numbers are the same LOL
    Posted 19th Nov 2012 at 18:38
    To be fair I could go and dig out one of each shock and pull the top off and check myself by comparing, but thought I'd ask incase it was common knowledge to save the effort LOL
  • Posted 19th Nov 2012 at 18:44
    mik
    Might be quite rusty, but it is pretty thick steel. Could be de-rusted and painted.
    Check the condition of bump stops/dust boots as they need to be in good nick to stop crud getting onto the rod. Mine were perished.
    Cherry Rallye SOLD
    Posted 19th Nov 2012 at 21:54
    Skf are a rubbish fit Yes
    Get original or don't bother
    Posted 19th Nov 2012 at 22:03
    darkstar753
    That seems surprising from SKF, they're oem for pretty much every rail wagon I've ever come across, thought u would be fairly safe with them.
    Darkstar
    Posted 19th Nov 2012 at 22:28
    Get the peugeot ones dude. Buy cheap buy twixe with this s**t and its a pita to change once its on
    Posted 20th Nov 2012 at 22:35
