displaying posts 1 to 25 of 37
Author Subject: oil pressure sensor
boost
anyone know where the oil pressur sensor is n how would i wire an oil pressure gauge to it ? Smile
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 5th Nov 2012 at 08:41
You wont have one, you need to get a sender and a compatible gauge
Posted 5th Nov 2012 at 08:43
what phase car?
you could add a threaded adapter with a takeoff and put one in that way. i think the p1 6's had oil pressure as standard on the speedo. i know my p1 xsi had it
Posted 5th Nov 2012 at 08:44
oh you have a rallye, yeah they're s**t
Posted 5th Nov 2012 at 08:45
boost
lol how they s**t haha
Posted 5th Nov 2012 at 08:51
Poverty spec.
  • Posted 5th Nov 2012 at 09:04
    boost
    LOL expensive poverty spec but still just as fun and i have more people drooling over the rally than me 6 yes i live near some sad people but the compliments are still cool Smile but the gauge is for me 6 a might just wire it to the oil temp switch
    Posted 5th Nov 2012 at 09:13
    As said above, you will need to buy a sender and a suitable gauge for this to work. If you plumb it in where the oil pressure switch is situated, you will need an adaptor to be able to run both the switch and the sender. Yes
    Posted 5th Nov 2012 at 13:37
    Rallyees were 3k less than a 6.
    Cheap Poverty bas**rd.....
    Posted 5th Nov 2012 at 15:23
    no he wont, there's two M16 holes in the block, phase1 and S16 used them, as did the ZX 16v.
    one above the starter and one near the oil filter.
    see, stan is wrong Razz
    Posted 5th Nov 2012 at 15:30
    I know there are two places you can use in the block Mei, however the reason I suggested the OP would need an adaptor is due to the sentence quoted below:
    This indicated to me that he wished to use the same access point to run the pressure switch AND the gauge sender in which case an adaptor would be needed.
    See, Stan is not wrong, just misunderstood. Razz Thumbs up
    Posted 5th Nov 2012 at 15:37
    wiring it to the oil temp switch will not give any indication of pressure whatsoever Laugh my ass off
    Posted 5th Nov 2012 at 15:39
    clen666
    Let's not start this s**t again!
    Team 'unintentional rat look'
    Posted 5th Nov 2012 at 17:10
    Laugh my ass off
    I know, I'm hoping he meant fit an adaptor there to take both sender units, but after reading through it again mate, I'm not so sure! LOL
    Posted 5th Nov 2012 at 17:30
    To save you the ball ache of searching to find the thread in the block behind where the starter motor goes it's M16x1.5 (Just below the core plug)
    I fitted an adapter in there to take it down to M10x1. which is what my sender was.
    I can't remember off hand whether the sender needs a live supply or grounding, then the other tab on it goes to the gauge signal in tab which is labelled 'S'.
    The gauge then needs a live feed to the '+' tab and earth to the other tab. The two tabs on the black bit are for an earth and live for the backlight.
    Heres the back of my VDO pressure gauge.
    Quite a simple thing to do if you are ok with spanners.
    Posted 5th Nov 2012 at 17:44
    I agree, but you've still got to find an ignition switched live and route the cables somehow from the engine bay to the passenger cabin. Yes
    Posted 5th Nov 2012 at 19:09
    boost
    yea stan mate i was guna use an adapter if thats possible to use the oil temp switch and it looks like a right faff on to do Confused
    Posted 5th Nov 2012 at 22:03
    Doesnt the temp sensor sit in the sump?
    Posted 5th Nov 2012 at 22:05
    yes it does indeed.
    Posted 5th Nov 2012 at 22:40
    Think he meant oil pressure switch. Yes
    Posted 5th Nov 2012 at 23:46
    Where would be the best place to find an ignition live for this within the passenger cabin?
    On the first click NOT second.
    Cheers. Smile
    Posted 6th Nov 2012 at 10:19
    there's a cabin other than for passengers?! Huh?
    Posted 6th Nov 2012 at 10:22
    Roll eyes LOL
    Come on Welshy, you've normally got all the answers...Yes
    Posted 6th Nov 2012 at 10:28
    midlife
    QualityLaugh my ass off
    Cool
    Team 330™Cool
    Team "no front end or engine"
    Posted 6th Nov 2012 at 10:41
    never needed to add one as my car has one as standard Razz
    Posted 6th Nov 2012 at 11:00
