displaying posts 76 to 100 of 205
Pages (9): first .. 3 [4] 5 .. last
Author Subject: GTi-6 - ITBs & CAMMED Track Car.. NOW ON EMERALD
jammapic
Post #76
Nope, not at all. Whisper quiet... It's all about the pads and discs you use ;-)
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 27th May 2013 at 21:25
7057sam
Post #77
What you running? G88 and ds25000?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 28th May 2013 at 09:00
Post #78
Good quality vidsThumbs up
Crap placing of the camera thoughThumbs down
The back of your helmet is boring!!!!Yes
Posted 28th May 2013 at 10:11
jammapic
Post #79
As the missus says "James, you've got a massive goobie head". Thanks. lol.
Brakes, I think are Tarox ones with those DS2500 pads, but I honestly can't remember.
Posted 28th May 2013 at 12:58
7057sam
Post #80
Are they grooved ones?
Rallye dead Sad
Posted 28th May 2013 at 15:31
jammapic
Post #81
Yep
Posted 28th May 2013 at 19:03
Post #82
So is this going to be turbo'd?
Looks like you are going down eaton route now Smile
Posted 29th May 2013 at 08:20
jammapic
Post #83
I am hoping that in the future I will turbo it, but at the moment funds are very tight (house stuff!) So the free eaton charger will get slapped on and see what happens. It's a pretty big charger, so should make really good power. Also, got a few bottom end mods which mean 300hp should be achievable.
JP
Posted 29th May 2013 at 08:28
jammapic
Post #84
Well that was a s**tter.
Went out for a drive in the car, 1st gear hard acceleration, changed into 2nd and boom noise of metal everyone, engine conked out and oil all over the floor and won't start again.
Balls
Posted 4th Jul 2013 at 18:44
JWP EFi
Turbo Legend!
Post #85
your motor didn't take kindly to 8000revs bud, has it thrown a rod?
when you say oil everywhere, is it engine or gear oil. if its gear oil then obviously youve blown the box, engine failing to start may be down to the crank sensor trigger teeth being damaged
Posted 4th Jul 2013 at 19:07
superchargedblack1997gti6
Post #86
Conrod failure?
Posted 4th Jul 2013 at 19:06
jammapic
Post #87
It's the box or the diff. Not engine oil.
Posted 4th Jul 2013 at 21:02
Post #88
traffic light racing? what was it a 7500rpm launch i did many of these with a quaife and never blew a gearbox. how many miles has the box done? did you shim the diff up correctly when you fitted it?
Posted 4th Jul 2013 at 21:11
Post #89
I thought a quaife was bolt on and forget not shim up?
Posted 4th Jul 2013 at 21:12
jammapic
Post #90
Didn't do any shimming of the diff? I was under the impression it was just drop in?
Set off gently in first, then built up to full throttle 8000rpm, then into second and away again.. That's when it went bang!
Posted 4th Jul 2013 at 21:15
Post #91
Nope needs shimming to get it set right otherwise it will move very slightly side to side. took it to lynx to sort out mine as it Fcked my diff bearings in under 200 miles. sounds like you have had a major bearing failure to me which has let your diff do a dance and causing the failure you have now suffered. Gutted for you mate i think I have a spare box you can have for peanuts if its any good to you? I'm sure you're diff will be fine cant say the same for the teeth on you're gears.
Posted 4th Jul 2013 at 21:22
Post #92
once fitted with the correct shims mine never gave me any other issues i didn't think they needed anything other than bearings when fitted but the shims were essential otherwise Nick from lynx told me that I would destroy something.
Posted 4th Jul 2013 at 21:26
jammapic
Post #93
Balls. That's the first time I have ever seen anything about shimming a Quaife in one of these! What shims will I need to use, and where do they go?
I didn't notice the stock diff to have any kind of shims in it?
JP
Posted 4th Jul 2013 at 21:25
Post #94
Give Nick @ lynx a call in the morning I'm sure he can explain it was a long time ago though but he will be able to tell you very quickly. Sorry mate gutted for you.
Posted 4th Jul 2013 at 21:27
Post #95
I've neve fitted a quaife so wouldn't know but I've also neer heard of having to shim one. I know plate diffs require shimming but thought quaife ones fit completely standard.
Posted 4th Jul 2013 at 21:33
jammapic
Post #96
When I dropped the stock diff there were no shims, and it all seemed to go in lovely and smooth with nothing required.
I can't even see where you'd have to put shims in? It just seemed to fit into the bearings and into the box?
JP
Posted 4th Jul 2013 at 21:49
Post #97
there's a single 62x55 washer on the rhs under the speedo drive housing against the right hand diff bearing, I've never needed to change from the original one.
they aren't on all boxes, and you can;t just buy one on its own, you have to buy a kit and set the pre load, I think the set of washers are about £20.
Posted 4th Jul 2013 at 22:02
jammapic
Post #98
Btw, if I put it in gear and click it on the starter, it still moves.
Posted 4th Jul 2013 at 22:07
allanallen
Post #99
Is this just on the 6 speed boxes? Never seen shims on a be3 before
Facebook
Posted 4th Jul 2013 at 22:10
Post #100
That must of been what I was missing on mine Welshpug.
Posted 5th Jul 2013 at 08:13
