displaying posts 51 to 75 of 205
Pages (9): first .. 2 [3] 4 .. last
Author Subject: GTi-6 - ITBs & CAMMED Track Car.. NOW ON EMERALD
jammapic
Post #51
Valve float? Do you get that with solid lifters?
Also - where do the revs drop when you change? That's right... right in peak power!
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 26th Feb 2013 at 17:57
Post #52
yeah, well beyond where you need it, right where it drops off Laugh my ass off
Posted 26th Feb 2013 at 18:02
jammapic
Post #53
Peak power on mine is made at 6880rpm according to the dyno.. So I change at 7750rpm and end up at 6250rpm(ish) so I've got a nice few revs of peak power before I change and get peak power again...
Plus, don't forget - transmission losses are less if you can stay in lower gears longer...
JP
Posted 26th Feb 2013 at 18:05
Post #54
Valve float is a byproduct of high revs and standard valve springs. Basically they are too soft to keep the valve firmly in contact with the follower/lifter. But I would'nt worry too much about it at stock rpm settings.
Posted 26th Feb 2013 at 18:42
jammapic
Post #55
Right, well - everything is now 100% working :-) yey!!!
Also, fitted my much lighter wheels, sticky tyres and I have to say, it is so so so much better to drive in every way, so I'm selling the challengers if anyone wants them?
Also, had it on the laser alignment kit the other day, and set up the geometry as per the BTCC Peugeot 306's and it feels great... As well as that, finally fitted some black masks and it looks mean!
Can't wait to get some heat in these tyres now!
JP
Posted 10th Mar 2013 at 19:32
Post #56
Looking niceThumbs up
coskev wrote:
jammapic wrote:
For now, yes. Along with throttle bodies. Not just using a 'map' I'm having rstuning put me one of their ecu's on.
I've got an engine on a stand in the garage which I am building for boost....
JP
What ecu is that?
And how much?Thumbs up
Dunno
Only the tracking is adjustable though?Dunno
Surely BTCC 306's would have run fully adjustable front and rear susp?Dunno
Posted 10th Mar 2013 at 20:27
jammapic
Post #57
Not rear. Just adjustable camber, castor, toe etc from the data I got given
Posted 10th Mar 2013 at 20:29
vts_tibi
Post #58
Willing to share?
VTS
best 60' : 2.272
Team Trackday™
Posted 10th Mar 2013 at 21:27
jammapic
Post #59
Course. Drop me a PM
Posted 10th Mar 2013 at 21:31
jammapic
Post #60
Given it a quick (and I mean QUICK, like 15 mins!) clean before it goes and does it's thing this weekend on a road rally... can't wait!
No knocks, no clunks, no pulls, working well... how long will this last? Lol!
JP
Posted 13th Mar 2013 at 17:51
jammapic
Post #61
OK... so long overdue thread update:
Took it on the road rally, was great fun, if a little cold and wet. The girlfriend thought this:
Then a couple of weeks later, did Curborough sprint day:
http://www.youtube.com/watch?v=lKxU12knmiM
http://youtu.be/WRVGePOdApU
Put the car back under it's cover outside, booked a load of track days this year, and then bought this:
That brings us up to date I think! Smile
JP
Posted 2nd May 2013 at 10:58
jammapic
Post #62
and my favourite picture:
Posted 2nd May 2013 at 10:59
allanallen
Post #63
Im Not trying to be a clever c**t but from your pictures you're not running anything even close to what btcc cars ran?! What uprights, wishbones, top mounts are you using to achieve the adjustability? Geo for which car, driver, circuit and tyres?
Facebook
Posted 2nd May 2013 at 20:27
jimmyrallye
Post #64
The gti looks great fella looks clean .. Your number plate looks like its saying gimp
Posted 2nd May 2013 at 20:33
jammapic
Post #65
I'm running the dry weather geo setup for slicks with the corner bias taken out, as best I can with the kit I've got. I've got no adjustability on the rear, other than ride heigh and damping, but I've got toe, castor, camber and obviously SAI to an extent on the front.
It's never going to be perfect but it's pretty good. Drives much better with a fair bit of toe out on if nothing else.
JP
Posted 3rd May 2013 at 07:54
allanallen
Post #66
jammapic wrote:
That picture alone tells me that you're not running anything like the required negative camber for radial slicks!? And why you'd want to run that geo on the road is beyond me! From personal experience stacks of negative camber and toe out on the road is s**t and destroys tyres.
Why so vauge with your reply? How much castor and camber do you rekon you've actually got on and how?
Car geometry is down to personal preference so there isn't ever going to be 1 setup for a '306 on slicks'. If think someone's been pulling your leg.
Facebook
Posted 3rd May 2013 at 17:50
jammapic
Post #67
No there isn,t you are right but I've taken the btcc geo and used bits of it to build my own which works well for me on this car.
It's based around the btcc specs, but like I said before, within the remit of us mere mortals.
I agree, I'm not as extreme as the full specs, but I've taken some of the pointers and gone with what works for them. With a few tweaks, it works well on my car!
Posted 3rd May 2013 at 20:22
jammapic
Post #68
A couple of mods:
Firstly, new torsion bars. 23.5mm jobbies from a group buy a while back, and reset with more ride height as it was too low before:
I fitted it ages ago but never wrote on here, oil cooler is on:
and finally, stripped some wiring and stuff out of the inside to lose a little more weight.
Posted 15th May 2013 at 16:23
Post #69
Do listen to Allenallen - he knows his stuff on that topic. You aren't running anywhere near -5.5 odd on the front for slicks, -4 odd for semi, the -2 or so on the rear or the toe out on the rear. If you speak to him nicely he can machine your trailing arms to give you more camber and toe. Same as what Martin, Denis and Ash run on their cars.
So its basically a slightly more aggressive road setup that won't work that well on slicks. Should be ok on the R888s or whatever is on there. Smile
On a lighter note it looks a very tidy car Thumbs up
Posted 15th May 2013 at 22:37
jammapic
Post #70
Seems to work ok, so I'm happy for now Smile
I need to speak to AllanAllen about rotrex chargers, as I've just bought one and need to nail it on the side of my motor...
JP
Posted 15th May 2013 at 22:42
jammapic
Post #71
Couple of vids on track at Mallory Park:
http://www.youtube.com/watch?v=z0SAs7GBESc
http://www.youtube.com/watch?v=TY0fsA-sQEM
http://www.youtube.com/watch?v=EiO2zIJnPEk
Posted 20th May 2013 at 15:50
fordygti
Post #72
Did you buy the lynx kit? If so there I step ny step.fitting instructions.on their website. Thumbs up
98 onyx black 306 Rallye
58 black Volvo c30 sport
Posted 20th May 2013 at 16:51
jammapic
Post #73
Nah. Got myself an Eaton Roots charger, will mock it up and fit that.
Posted 27th May 2013 at 18:44
Takedown
Post #74
H(EAT)ON
Posted 27th May 2013 at 20:19
7057sam
Post #75
I've heard that eatons make a awesome song Love
James do you brembo squal like a motherfuker LOL mine do.
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 27th May 2013 at 21:10
