displaying posts 1 to 25 of 44
Author Subject: cleaning inlet manifold sensors
boost
sorry for all the threads lol but whats best to use to clean all the sensors on the inlet mani or would it damage them ? just wana clean them to see if there clogged up
97 1.6 xs gti6 conversion Smile scrapped
99 black rallye ( low miles and immaculate Thumbs up ) sold
new owner of a 2001 diablo red hdi mile muncher Smile swapped
99 red rallye turbo sold then died Sad
00 moonstone 1.9d (slow)
Posted 29th Oct 2012 at 21:14
gti6girl
Brake cleaner
Posted 29th Oct 2012 at 21:28
bas_306gti
The only items who needs cleaning is the ICV (perhaps MAP and Air sensor) and the throttle body/manifold itself
The way to clean them is to disassemble the manifold and throttle body and clean them with brake/carb cleaner
Posted 29th Oct 2012 at 22:21
boost
u think with a good clean they may inprove fuel xonsumption cause it seems to be real bad on fuel Confused
Posted 29th Oct 2012 at 23:40
Not really, you can't really "clean" a MAP sensor to be honest.
Posted 30th Oct 2012 at 06:18
boost
i thought all the sensors got clogged after time
Posted 30th Oct 2012 at 09:04
The sensors don't really get "clogged" they're not sink plug holes. LOL
The only sensor which really gets anywhere near "clogged" is the lambda sensor as it can get quite sooted up depending on your AFR's. Yes
Posted 30th Oct 2012 at 09:38
Tbh I'm not sure any of them respond to cleaning either. They are usually just fecked
Posted 30th Oct 2012 at 09:42
boost
haha didnt really know that i just thought they gpt a bit clogged over time n needed a bit clean nevermind lol Smile
Posted 30th Oct 2012 at 09:47
No worries, if it ain't broke don't fix it. Wink
Posted 30th Oct 2012 at 14:40
stan_306gti6 wrote:
No worries, if it ain't broke don't fix it - give it time Wink
EFA
  • Posted 30th Oct 2012 at 14:41
    Well yes, you could look at it that way. Enjoy the rest you have now as you'll soon have all your spare time taken up with repairs etc. LOL
    Posted 30th Oct 2012 at 14:45
    boost
    lol touch wood its fine up till now only really had the plug issue the other day and the fact its a thirst motor Confused
    Posted 30th Oct 2012 at 15:15
    They shouldn't be *that* thirsty. You should see around 300-325 miles per tank with mixed driving. Yes
    Posted 30th Oct 2012 at 19:30
    boost
    ill be lucky if ill see 200-250 mixed driving mate its unreal there has to be sumit wrong sumwhere Confused
    Posted 30th Oct 2012 at 20:24
    woody.
    Normally lambda sensor or coolant temperature sensor mate. Try and get a known good one and try it, if not buy a new one
    Posted 30th Oct 2012 at 20:50
    swiftyboi006
    Lambda is themost common for this or driving at 5k+rpm like some people do Thumbs up
    Black p3 Love
    Posted 30th Oct 2012 at 21:01
    boost
    cheers lads al give it a shot n another thing if the thermostat is stuck open (think it may well be cause when driving it sits at 70degrees ) is there anyway of unsticking it or just buy a new one ?
    Posted 30th Oct 2012 at 21:31
    If your thermostat is stuck open (which it sounds like it is) then this will most likely be the cause of the poor fuel economy. Yes
    The engine will be running cold and therefore it will be running rich to compensate. Fit a new one, I'm sure you'll see an improvement. The stat on these are set to open at 83C so the reading on the instrument panel should be around this figure when travelling after the warm up phase. Smile
    Posted 30th Oct 2012 at 22:36
    boost
    ok cheers mate ill try pick one up today Smile
    Posted 31st Oct 2012 at 07:10
    From experience I would suggest buying a Pug one. Yes
    I bought a brand new one from a factors a few years back for £6 and it got stuck open VERY quickly and made my engine run at 70C. Sad
    I went to Pug for a replacement and felt a bit ripped off at £18, however it's run faultlessly and is still being used in my current engine a few years on. Yes
    Get what you pay for in my opinion. Smile
    Posted 31st Oct 2012 at 07:16
    boost
    pug parts are always better like a think al go today n pick one up cause tbh 18quid aint really alot like Smile
    Posted 31st Oct 2012 at 09:52
    It isn't a lot, especially when you consider it's probably the cause of your poor fuel economy. Therefore, by spending the £18 it'll soon pay for itself in the fuel that you'll be saving. Thumbs up
    Posted 31st Oct 2012 at 11:52
    beez_neez_gt
    Give them a clean with a toothbrush type tool with brake cleaner as mentioned. Then use some WD40 in the plugs to gain a better electrical connection as well as resisting water, the same goes for all the engine bay plugs.
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 31st Oct 2012 at 12:45
    boost
    would the thermostat stuck open affect performance ? and wheres the engine numbers on the 6 llump ? cause theres 2 isnt there the xu10j4r and the xu10j4rs ?
    Posted 31st Oct 2012 at 20:40
