displaying posts 101 to 125 of 139
Pages (6): first .. 4 [5] 6
Author Subject: Refitting box after clutch change - nightmare, please help!
Post #101
Laugh my ass off
Posted 20th Oct 2012 at 19:32
Post #102
Batesy86 wrote:
Light bulb moment, I got it out of my box of bolts to help me remove the arm!
LOL
How random...
Posted 20th Oct 2012 at 23:59
Batesy86
Post #103
Can't fathom where these two brackets went???
Posted 21st Oct 2012 at 13:35
Post #104
inlet manifold support brackets
Posted 21st Oct 2012 at 13:44
Batesy86
Post #105
Are they essential? I can't figure out where they bolt to
Posted 21st Oct 2012 at 13:54
Post #106
the big one supports the weight of the manifold downwards on the block so it bolts underneath the manifold and to the block. can't remember where the smaller one is fitted, I don't think I've got that one on my engine
Posted 21st Oct 2012 at 13:57
Batesy86
Post #107
I'm getting livid now, can't find a way to get the big bracket on!! Can only find two threaded holes, one on mani behind tb and one directly below on the box, but no matter what way I try it won't go anywhere near in the right place
Posted 21st Oct 2012 at 16:56
Post #108
big one doesn't go there, it goes to the middle of the mani in front of the starter.
Posted 21st Oct 2012 at 16:58
Batesy86
Post #109
Never mind, it's on
Posted 21st Oct 2012 at 17:12
Post #110
Little one bolts to the right bracket by the starter and folds around to a gearbox mounting point.
  • Posted 21st Oct 2012 at 17:30
    Batesy86
    Post #111
    Right, I've had it running, up in the air, and it seems to be working fine! Just need to lower it tighten hub nuts raise it put cyclones on and go for a drive. Hope all is ok! I found the big tube that goes over the the mount bolt though, has that gotta go back on or can I get away without?
    Posted 21st Oct 2012 at 20:45
    Post #112
    yes it does need to go on.
    Posted 21st Oct 2012 at 21:23
    Batesy86
    Post #113
    Boooo ok, least only the battery tray needs to come off. Thanks for everyone's help I know it's been a bit of a saga!
    Posted 21st Oct 2012 at 21:33
    Post #114
    Battery tray to come off for a tube to go on a mount?
    Initially I thought you meant the tube that goes over the upper left engine mount under the cradle. Now I'm lost.
    Based on what we've learnt about you so far in this thread I'd almost be temped to believe you did mean that part - and that you think it goes over the gearbox mounting stud.
    You didn't find it in your box of bits from when you did something in the past did you? The large washer on a previous page is from the top engine mount, so you've probably been poking about there in the past and may have this tube left over from then.
    Get a pic of this tube. I like to help as much as I like to take the p**s.
  • Posted 21st Oct 2012 at 21:55
    Batesy86
    Post #115
    No, my box of bolts is purely xr2 bits from when I broke one.
    This is the tube, I haven't had any other mounts off and I know it came off as part of this job...
    Posted 21st Oct 2012 at 22:14
    rich306
    Post #116
    I tell you what guys, this thread gave me a massive help this weekend getting the gearbox back on Ash's 306 lol. Struggled for ages before i read this thread and wriggled it back on!
    Richies Project Rallye
    jamiek_uk2000 wrote:
    - Top Tip!!!
    Posted 21st Oct 2012 at 23:53
    rich306
    Post #117
    And that piece is the sleeve that fits over the top of the gearbox mount bolt.
    Take off the rubber mount, and tap that over the bolt.
    - Top Tip!!!
    Posted 21st Oct 2012 at 23:54
    Post #118
    Ahh I see what you mean now.
    RE the XR2 bits, what have you got left?
  • Posted 22nd Oct 2012 at 00:03
    Batesy86
    Post #119
    I didn't think I was being an idiot lol.
    As far as the xr2 goes I don't think I've got anything left at all, what were you after?
    Posted 22nd Oct 2012 at 08:58
    Batesy86
    Post #120
    Finally had time to test drive it. Very satisfying, as it performs brilliantly and doesn't leak or anything lol. Only thing is a very low pedal and a sharp bite but presume that's the 'benefit' of the new clutch!
    Posted 23rd Oct 2012 at 20:36
    Post #121
    pedal shoulnd't be that low, did you fit a new cable?
    is the spring on the pedal still therE? if so bin it, was pug recall for that.
    Posted 23rd Oct 2012 at 20:40
    Batesy86
    Post #122
    No, thought I'd try to get away without a new cable.
    Which spring do you mean? There's a big spring on the plunger?
    Posted 23rd Oct 2012 at 21:07
    Post #123
    what plunger?
    Posted 23rd Oct 2012 at 21:19
    Post #124
    Not looking at the brake pedal where it joins the servo are you? LOL
  • Posted 23rd Oct 2012 at 21:31
    Batesy86
    Post #125
    I'm just recalling from memory, it's not a plunger but the black cylinder that moves upwards as you depress the pedal... Picture anyone?
    Posted 23rd Oct 2012 at 21:45
