displaying posts 776 to 800 of 1018
Pages (41): first .. 31 [32] 33 .. last
Author Subject: My 306 Dimma project, Mainly photos
eddy_gti6
Post #776
Really? I cant remember if it use to come on with my omex or not? I thought high boost still ran a stock ecu mapped? Not sure tho.
Posted 19th Mar 2015 at 23:06
pugheaven
Post #777
High boost set ups use standard management, super high boosts use dta
Posted 19th Mar 2015 at 23:08
Niall
Post #778
Omex has no way of activating the EML. Iirc emerald has a EML output. Not sure about DTA
Also, who the f**k wired that conversion loom. My pet hate is messy wiring lol
Posted 19th Mar 2015 at 23:14
pugheaven
Post #779
It's not messy when straight, as its been squished up it looks worse than it is, but to answer your question I dont know who rich got to do it!
Posted 19th Mar 2015 at 23:17
Niall
Post #780
I think its one of the standard DTA ones they sold tbh. They were never brilliant but functional i suppose!
Posted 19th Mar 2015 at 23:20
walker_texasranger
Post #781
Looks awesome Ollie, especially the bay Love
Hilux InvincibleX daily
306 No.13 Doh
Posted 20th Mar 2015 at 05:44
pugheaven
Post #782
Sorted out the oil level temp problem, the needle was pushed in to far so once I pulled it out a bit it now works fine!
Changed the battery light bulb but it's still not coming on, slaves another clock set in and it's the same so I know it's not the clocks?
Took the airbag bulb out so that's all good now.
I have 3 spare wiper motors and they all have the same fault, first setting on the stalk (auto wipe) nothing happens, second setting it works (slow speed) third setting does nothing! The rain sensitive sensor is plugged in.... What's likely to be at fault?
Posted 20th Mar 2015 at 14:43
Post #783
tried a replacement sensor?
Posted 20th Mar 2015 at 15:32
pugheaven
Post #784
Don't have one but would a faulty sensor make the fastest setting not work too? Strange how slow works that's all!
Posted 20th Mar 2015 at 16:10
luke306rallye
Post #785
I had the same wiper problem and it was the motor that was at fault.
Posted 20th Mar 2015 at 17:14
pugheaven
Post #786
It's not the motor as iv tried 3 known working ones
Posted 20th Mar 2015 at 17:30
Post #787
Could it be a relay?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Mar 2015 at 19:28
Puggitt
Post #788
Sounds like you got some little gremlins playing in your wires. Did you put it in water? Or feed it after midnight? LOL
Are all the loom connectors tight?
Posted 20th Mar 2015 at 20:01
pugheaven
Post #789
Which relay is the front wiper motor one?
Tomorrow I'm going to take the bulk head main loom apart and check it and also the engine bay to engine loom! Hopefully I'll sort them 2 problems out
Posted 20th Mar 2015 at 20:30
Puggitt
Post #790
I don't believe there is a relay for the front wipers, it's all controlled by the rain sensor and the input for the motor.
That's why I suspect you've pulled a wire you weren't meant to if you reduced the looms, or something isn't plugged in
Posted 20th Mar 2015 at 21:51
pugheaven
Post #791
Didn't touch the wiring for the wiper motor at all so hopefully just a loose/dirty connector
Posted 20th Mar 2015 at 22:02
Post #792
Do you even have a rain sensor.... Car started as a phase 1.....
Posted 20th Mar 2015 at 22:52
pugheaven
Post #793
Yup. All the looms are off a t reg phase 2 and I had a new windscreen put in that had the clips for the sensor
Posted 21st Mar 2015 at 06:09
cully
Post #794
there are two relays and the rain-sensor all of which control the speeds and auto wipe
you have got the column switch with the auto wipe function?
Posted 21st Mar 2015 at 08:24
cully
Post #795
also ref the airbag light
if you have removed the airbag ecu the light will illuminate 100% of the time as the plug at the airbag ecu has been unplugged
within the plug there is a set of shorting pins
several of these short the airbag lines together to stop voltage setting off the bags when disconnected
but one shorting pin sets the airbag light on!
just by removing this pin or cutting the wire will extinguish the airbag lamp
il see if i can find a picture which will explain better
Posted 21st Mar 2015 at 08:38
pugheaven
Post #796
Yup I have an auto stalk, going to leave those faults for now and get the engine running! I'll go and get some relays later and see if that sorts out the wiper fault
Posted 21st Mar 2015 at 10:30
pugheaven
Post #797
Well the car runs now..
For some reason it wouldn't start with the high pressure pump electrically connected, disconnected it and she fired up!
Checked all the fuel lines etc but as soon as the high pressure pump is electrically connected the engine dies?!?!
The bloody heater matrix is leaking too Sad don't think the o-ring is seated properly so the dash is coming back out next week but first I have to sort this running problem out
Posted 21st Mar 2015 at 15:48
ryangti6
Post #798
This project is immense fair play to you, good to see it almost complete.
That's an odd issue with the pump, only thing I can think of is have you wired it backwards
Ryan
Posted 21st Mar 2015 at 17:11
pugheaven
Post #799
I have just wired the high pressure pump straight from the battery and earthed it back to the battery and still the same fault!
Disconnected the fuel lines from the rail, just had the in tank pump electrically connected, turned the ignition on and fuel flowed, I then connected the high pressure pump electrically and the flow increased
Posted 21st Mar 2015 at 17:38
pugheaven
Post #800
Today the Dimma got rolled outside and had a wash as it was covered in crap
Then I took the dash out to fix the heater matrix leak
Think I'm going to try and fit the satchshift while the dash is out, might have to ring Colin up for some info but we will see
Posted 22nd Mar 2015 at 17:25
