displaying posts 751 to 775 of 1018
Pages (41): first .. 30 [31] 32 .. last
Author Subject: My 306 Dimma project, Mainly photos
rallyestyle
Post #751
Lovely Thumbs up Love the OME look of all this, very smart Thumbs up
Just Drive It
Posted 17th Mar 2015 at 18:14
pugheaven
Post #752
Spent £60 just on an6 banjo's and banjo bolts for the supercharger but unfortunately I won't be able to use them so I'm forced to use the usual supplied push fit banjos with rubber hose 😠
The banjos I got are the straight ones and think automotive want £25 for angled ones which I'm not prepared to spend £100 just for the banjos with out bolts or braided line! Due to the ones I got being straight I would need to space them at least 4mm away from the charger to allow the AN fitting to be installed as the Banjo would sit hard up against the charger!
I'm going to tart up the old fittings with some black paint, buy some new rubber lines and hopefully they will look alright!
Just noticed that I didn't get the lift reverse part for my satchshift so I'll be in the phone chasing that tomorrow!
Posted 17th Mar 2015 at 18:28
pugheaven
Post #753
So these are the fittings I wanted to fit to the supercharger oil circuit
Due to the reason in the above post I couldn't make them work so an alternative was needed, rubbed down the old banjo bolts and banjo's and then painted them Smile
Happy enough with the result Smile
More or less finished plumbing it all up but I am waiting for a take off for the oil temp gauge then I can prime the charger
Posted 18th Mar 2015 at 17:34
rallyeash
Post #754
Why do they need to be banjo?
Male male nipple screwed in and a 90 degree swept fitting not do? Then you can be braided.
309 3dr K20 Type R
Posted 18th Mar 2015 at 17:45
rallyeash
Post #755
Like a male male
http://www.ebay.co.uk/itm/6-AN6-06-6-Straight-Flare-Union-Adapter-/360760262329?pt=LH_DefaultDomain_3&hash=item53fefcbeb9
And (or have a tight non swept 90 if you prefer
http://www.ebay.co.uk/itm/6-AN6-6-JIC-06-90-DEGREE-Swivel-Seal-Hose-Fitting-/171208076704?pt=LH_DefaultDomain_3&hash=item27dccbeda0
309 3dr K20 Type R
Posted 18th Mar 2015 at 17:48
pugheaven
Post #756
I did think about getting m10x1.0 to an6 straight and then a 90 degree an6 fitting but it would be to high and the bonnet wouldnt shut, that's why I would have had to use bango bolts in the first place Sad the only option would be to buy angled banjos from think automotive but it's way to much money!
I didn't think I would be happy with my solution but I think it looks good and breaks up all the silicon and braided lines I have in the bay, it's starting to look a little cluttered now Sad
Posted 18th Mar 2015 at 18:15
superchargedblack1997gti6
Post #757
Looks immaculate as always Smile getting there now mate not long till you can fire her up Superman
Posted 18th Mar 2015 at 18:21
pugheaven
Post #758
Hopefully this weekend and then mot next weekend! Still won't be able to drive it tho as I have to re-import the car with HMRC then send off all the relevant paperwork to the DVLA, i should have done this ages ago but hey ho! Luckily I can use my mates trade plates (with him in the car) so will hopefully get the running in done and then get it mapped Smile
I'm starting to think it's got to much blue silicon
Posted 18th Mar 2015 at 18:30
Post #759
i did think that but i'm too polite to say so Yes
start again please
LOL joking aside it still looks awesome
Posted 19th Mar 2015 at 13:20
eddy_gti6
Post #760
Well its going to be fun keeping it this clean once its up and running. What made you go with a white engine bay and not the same colour as the car?
Posted 19th Mar 2015 at 15:19
pugheaven
Post #761
The inside of the car is white too, just splits it up a bit and makes bits stand out more, also its good for spotting leaks.
Re-routed some of the silicon which has made a bit of a difference, looks good now in my opinion! It's mainly the oil catch tank hoses that were bugging me
Posted 19th Mar 2015 at 16:22
pugheaven
Post #762
The ecu box will be going black, the two 2" lengths of silicon on the braided lines are to stop the lines chafing on the engine/box but I might try and p-clip them so those bits of silicon hose can go
Rather a lot going on in the engine bay though to be fair and to make it look tidy or hidden is a pain in the arse especially with the filter relocation kit
Just wired up the fans, next is to earth the afr gauge and then it's time to fill the engine with oil and the fuel tank with fuel and do a leak check! Still can't turn the engine over though as I still need the take off for the charger oil temp before I install the last hose
Posted 19th Mar 2015 at 16:52
rallyeash
Post #763
Does the engine have anywhere to breath?!
309 3dr K20 Type R
Posted 19th Mar 2015 at 17:52
pugheaven
Post #764
Only through the catch tank, rich removed the breather from the charger when it was his car and has run like that since
Posted 19th Mar 2015 at 19:12
pugheaven
Post #765
Well well I dont believe it...
Just put half a tank of fuel in, filled the engine with oil, connected everything electrical, crossed my fingers and turned the key (didn't turn the engine over)
Considering I stripped the interior loom, dash loom and engine bay loom it appears everything I need working works lol
Both fuel pumps prime, all the lights work (except the side indicators but I dont need them), the horn works, the afr gauge works etc
The oil level gauge doesn't move, it's been such along time since iv been in a 306 I can't remember if it only shows the level when you start the engine or if it's meant to read the level when the ignition I's on???
Also the hazards flash to start with, I assume it's the alarm.... I currently have no central locking as I have no sensor in the roof so I'm guessing it thinks the car has been entered with out the doors being unlocked??
I need to remove the air bag light bulb but all seems to be good... I'll find out more when I start it tomorrow or Saturday
Posted 19th Mar 2015 at 22:03
Ben_W
Formerly gpm
Post #766
Good work.
I remember spending an age on the wiring on my buggy. Used a loom from a donor beetle plus had an A0 print out of the loom. Spent a week tracing and labelling wires. Remember hooking it all up and apart from a couple of crossed wires (indicators, so front left and rear right flashed together Big grin ) it was all good. Very rewarding feeling.
Nice one
Posted 19th Mar 2015 at 22:11
Post #767
My oil level shows with ignition on.
pugheaven
Post #768
hmmm something I will have to look into tomorrow then!
it was a big mile stone applying power for the first time in 3 years lol I hope tomorrow or Saturday goes well with no big issues when I go to turn the engine over for the first time
Posted 19th Mar 2015 at 22:17
Niall
Post #769
Yeah oil level should show on the second click of the key. If the sensor is missing or damaged, the needle waves a few times then sits at minimum
Edit: Also, your battery light isn't working Thumbs up
Posted 19th Mar 2015 at 22:32
pugheaven
Post #770
it doesn't move at all so don't know whats going on with it Sad
Posted 19th Mar 2015 at 22:31
pugheaven
Post #771
what would cause the battery light not to come on? other than maybe the bulb being dead!
Posted 19th Mar 2015 at 22:43
Niall
Post #772
bulb dead i would imagine as if i remember rightly, it is always on except when the dials receive voltage from the small wire off of the alternator.
Posted 19th Mar 2015 at 22:45
pugheaven
Post #773
nice one, just had a search and could only find problems with the battery light being constantly on or dim!
I cant even remember what car I took these clocks from, the dimma is built from various parts from 3 or 4 cars iv owned.
The wipers don't work either but I have a few motors to try LOL
Posted 19th Mar 2015 at 22:50
eddy_gti6
Post #774
If your hazards are flashing when you turn the key that usually points to the immobiliser. Yeah oil level should come on with ignition then drop to be oil temp once the car is started. Also you have no engine management light what should be on above the air bag light and your STOP light shouldnt be on either.
Posted 19th Mar 2015 at 23:05
Niall
Post #775
He won't if he's using aftermarket management which i thought the high boosts had to?
