displaying posts 476 to 500 of 1018
Pages (41): first .. 19 [20] 21 .. last
Author Subject: My 306 Dimma project, Mainly photos
Post #476
You can fit the pivot with the engine in dude ?
Posted 21st Aug 2014 at 19:13
pugheaven
Post #477
I know I can but its alot easier to do it with the engine out and with me going away now I dont see the point in rushing to put the engine in
I can also check the amount of play a lot easier with the engine out
its not as if it takes ages to fit the engine so it can wait
Posted 21st Aug 2014 at 19:24
Niall
Post #478
that engine looks stunning. Just out of interest, the left hand breather from the cam cover with the check valve in it, what does it go to? Normally it goes to the inlet iirc.
Posted 21st Aug 2014 at 22:24
pugheaven
Post #479
It does normally, atm it just goes to a breather but will go to the catch tank once iv fitted the engine and made the braided line for it
Posted 21st Aug 2014 at 22:27
Niall
Post #480
Yeah you want to get it into a tank. Mines just on a breather at the moment and if i end up sitting still for any period of time, i get a smell of oil in the car which gives me a right headache Sad
Posted 21st Aug 2014 at 22:40
pugheaven
Post #481
Got the gear linkage fitted
Next up was to fit the engine Smile
On its mounts and a few bits connected
Posted 22nd Aug 2014 at 16:52
marco gti6
Post #482
What a beautiful engine bay you have there mate. Incredible attention to detail as well.
Keep going strong Thumbs up
Posted 22nd Aug 2014 at 17:07
pugheaven
Post #483
Thanks buddy it's all becoming worth it now Smile
Posted 22nd Aug 2014 at 17:20
jimmyrallye
Post #484
Excelent work pal you have done a Stirling job on this build
Posted 22nd Aug 2014 at 20:09
pugheaven
Post #485
Been busy the last few days, got the shafts in and made all the wiring tidy. Slaved the bumper and splitter on to take some pics for pro alloy
As you can see the front bumper needs a lot of work still, hopefully my mate will sort that out while I'm away so when I get back I can get the car up to pro alloy for the intercooler and rad, then i can mount both oil coolers and oil filter relocation kit
I don't have enough braided line to finish the fuel lines in the engine bay so iv ordered some more
Probably the last update from me until I get back Sad
Posted 26th Aug 2014 at 18:05
mechanical_repairs
Post #486
Looks amazing.Thumbs up
Carl
Posted 26th Aug 2014 at 20:43
Cjwatson27
Post #487
Really looking good that front end looks awesome
Posted 26th Aug 2014 at 21:00
pugheaven
Post #488
Thanks lads, I forgot how bloody wide and mean it looks when it's all put together, hopefully next time I put it together it's all the same colour
Posted 26th Aug 2014 at 21:03
pugheaven
Post #489
As I cant do anything to the car whilst being away with work I thought I would do a spec sheet for the dimma as its changed alot from what I put on the first page....
Wheels and tyres
8x18 revolution millenium's with nankang ns2'r tyres
Brakes
Front
Ap racing 4 pot calipers with 315x28mm bell and rotors
Rear
Wp pro 310mm big brake conversion with yellow stuff pads
Lines
Braided lines routed inside the car with a wilwood brake bias valve (abs fully removed)
Suspension
Front
Custom upper strut brace
Phillip m lower strut brace
Gaz gold coilovers
Bridgecraft custom -2 degrees negative camber hubs
Phillip m adjustable drop links
Dimma wide track wishbones
Dimma mc phearson top mount plates
Rich w roller bearing wishbone bush's
Rear
Gaz gold dampers
22.5mm torsion bars
Hybrid anti roll bar
Bridgecraft engineering wide track conversion
Bridgecraft -3 degrees negative camber trailing arms
Steering
Xsara vts quick rack
Dimma extended track rod ends
Shell
Genuine steel body dimma kit
Phase 3 front bumper and splitter
Carbon fibre grill
Carbon fibre bonnet
Carbon fibre roof
Carbon fibre boot
Carbon fibre spoiler
Carbon kevlar slam panel
Plastic4performance 4mm window kit with pro slider kit
Interior
Custom made 6 point roll cage with twin door bars (copy of my safety devices cage but with rear legs going to the beam mounts)
Carbon fibre door cards
Carbon fibre fuel tank access covers
Carbon fibre boot panels
Carbon fibre drivers and co drivers footwells
Flocked dash
Carbon kevlar corbeau revolution bucket seats
6 point 3" luke harnesses
Sparco seat frames
Sparco 2 helmet box
Sparco steering wheel
Race battery and cage fitted behind passengers seat
Metal monkeys clock set
Gauges
AEM AFR gauge
AEM boost gauge
AEM oil pressure gauge
AEM oil temp gauge
Auto gauge oil temp gauge for supercharger oil temp
Auyo gauge volt gauge
Fuel system
AN 6 braided lines and fittings routed inside the car
Aircraft fuel shut off valve
Mocal fuel swirl pot
Bosch 044 fuel pump
Bosch fuel filter
Gearbox
Quaife diff
Shot peened and cyro dipped 1st 2nd 5th and 6th gears
KAD custom made straight cut 3rd and 4th gears
Dimma drive shafts
Pug racing metal gear rods
Clutch
Helix 4 paddle race clutch
Engine and gear box mounts
vibratechnics race gearbox mount
Baker bm group a solid fork bush
Custom solid lower mount
Custom solid upper mount
Engine
Rotrex c38-81 supercharger with braided oil system and 10 row oil cooler
Lynx power engineering 8 rib pulley set up
Lynx power engineering supercharger fitting kit
Lynx powrr engineering power steering relocation kit
Wossner pistons
Saenz rods with ARP 19 bolts
Oil filter relocation kit
19 row oil cooler
Ceramic coated exhsust manifold
Zero custom exhaust system
Custom pro alloy intercooler
Custom pro alloy radiator
Slim line fans
DTA S60 ecu
All parts have been powder coated or plated
probably forgot loads of bits
Posted 10th Oct 2014 at 08:05
Twangy
Post #490
awesome car and really nice job on it
wayne mcardle
Posted 10th Oct 2014 at 07:58
Post #491
what's the plans with the best intercooler and rad setup?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 10th Oct 2014 at 09:32
pugheaven
Post #492
Hopefully original design rad but 50mm core and 2" narrower each side for the boost pipes to go either side of the rad, a 100mm core intercooler and as big as I can grt to fit
if your interested let me know as it will be cheaper the more they make
Posted 10th Oct 2014 at 09:54
Post #493
Unfortunately Ollie Everything's on hold for me at the moment!
Have you thought about having a slightly shorter rad and having the boost pipes going over there's straight into the cooler?
Posted 10th Oct 2014 at 09:59
pugheaven
Post #494
Yep, I did think about having the boost pipes running under a shorter rad but then the water pipe from the engine would have to be changed, I also thought about the boost pipes going over the top of a shorter rad but the charger inlet would be too low and the heat from the top of the rad would transfer heat into the intercooler pipe work.
The best option would be to have a narrower but thicker core rad and the boost pipes to pass round the sides, this way the boost pipes dont have to be as long and the inlet out let of the cooler wont be far from the inlet mani and charger out let
Posted 10th Oct 2014 at 11:30
RetroPug
Post #495
It's all starting to come together now! That slam panel is pretty sexy.
Can't wait to see this all finished.
Posted 10th Oct 2014 at 12:11
pugheaven
Post #496
Thanks buddy, fingers crossed it will be fully built, up and running before Christmas for it to be mapped in the new year!
God knows what im going to do to keep my self busy once its done tho Sad
Posted 10th Oct 2014 at 16:05
mcvite
Post #497
Incredible attention to detail you are doing there mate,absolutely stunning,well done Thumbs up
http://s1160.photobucket.com/albums/q486/mcvite/
Posted 10th Oct 2014 at 17:04
Post #498
Would the pipes above the rad actually have any effect on warming up the air passing through as the air is gushing theough very very fast, would it have time to heat the air iup at all?
Posted 10th Oct 2014 at 18:50
pugheaven
Post #499
Probably not but the main issue would be the out let for the charger being lower than the rad.... no point having longer boost pipes when I can just go round the sides
Posted 11th Oct 2014 at 14:16
chiefton
Post #500
This looks mental dude you need to get her on the road asap!!!
cherry rallye daily (the money pit)
Posted 11th Oct 2014 at 15:30
