displaying posts 26 to 33 of 33
Pages (2): 1 [2]
Author Subject: gearbox oil cooler
fatlapit
T400 PUG wrote:
mmm it would seem. LOL
ive got an electric supercharger im selling Whistle
LOL
Posted 9th Sep 2012 at 22:19
Maybe fatlapit could use this to power his transmission cooling system. Dunno LOL
Posted 9th Sep 2012 at 22:20
fatlapit
bbbboooooooooo again stan!!!
but your not far off!
http://www.merlinmotorsport.co.uk/p3652/MOCAL-ELECTRIC-OIL-PUMP/product_info.html
Posted 9th Sep 2012 at 22:22
pete_rallye
You could end up running the oil too cold, which is pretty much as bad as running it too hot. The touring cars run them because they run thin oil to reduce transmission losses, so need to keep it from getting too hot. In reality, you'd just run a slightly thicker oil and accept the additional 2whp you'll lose.
If you want toys I'd run an electric variable speed digital coolant pump that can alter your engines heat up and cool down time by not pumping at all, or carrying on pumping after the engine is cooled off. This would help get your oil temp up quicker, reducing wear on the engine and help it cool down quicker once the engines turned off. You'd also remove the impellor from the coolant pump so there'd be less load on the engine, freeing up a few bhp. Although there'd be slightly more load on the alternator, which may just steal those bhp back again...
Lap of the 'ring
Posted 9th Sep 2012 at 22:31
fatlapit
however using this system you can spay lubricate the diff also instead of splash lube which i think is another one of its plus point imo.
Posted 9th Sep 2012 at 22:35
Spend the money on running decent oil in there in the first place, sorted.
Posted 9th Sep 2012 at 22:46
pete_rallye
The diff sits in a pool of oil so I don't see how spray lubrication would be any better? To convert the box to spray lubrication would be quite difficult too. When you said oil cooling I figured you just meant tapping the box to fit some take offs and pumping the oil through the cooler then back into the box. I really don't think there is any need!
Lap of the 'ring
Posted 9th Sep 2012 at 23:14
fatlapit
Yeah thats what i do mean mate but you could also spray lube the fiff.
Posted 9th Sep 2012 at 23:38
Pages (2): 1 [2]
