displaying posts 1 to 25 of 45
Author Subject: 200 bhp XU10J4RS on factory inlet/exhaust manifolds
JWP EFi
Turbo Legend!
what would be needed to see the above? have searched on here but still a bit vague.
on top of good exhaust system, im thinking piper 285 cams with remap...lets assume we dont have a skimmed
head so valve to piston should be ok, iirc a certain company in Hampshire got 190 brake with lesser spec cams
Posted 6th Sep 2012 at 23:06
Can't be done end of
Anyone that says just a set of cams and a remap will get 200bhp is full of sh1t Yes
Posted 6th Sep 2012 at 23:09
Aftermarket pistons and better cams, mappable/mapped ecu, exhaust is fine.
or go bodies and milder cams, similar result and cash outlay, even better soundtrack.
JWP EFi
Turbo Legend!
worst case scenario - £5k for above, and for 30 brake, not really worth it
forged pistons along with slight over bore to say 86.5mm plus cams and remap would see 200 bhp, yes????
Hampshire based firm not being entirely honest then...
Posted 6th Sep 2012 at 23:22
A Hampshire based firm that's not entirely honest? What did you expect? Hang on, my firms Hampshire based, Oh shi...!
Posted 6th Sep 2012 at 23:25
5k maybe if you pay someone, i'm nearly there at 1300, modified pistons cams, bodies bought, just make a loom and a mani and map it
Posted 7th Sep 2012 at 07:45
JWP EFi
Turbo Legend!
take it pocketed your standard pistons?
£5- tb,s 2k
ecu- £600
mapping £400
cams £500
Forged pistons etc £700
plus any other bits, gaskets etc
Posted 7th Sep 2012 at 08:32
Yup.
Tbs 600, ecu 500, mapping 330, cams 400, inlet depends on what you choose, from 200.
A bit short of your guesstimate lol
Posted 7th Sep 2012 at 08:36
Rich_W made 207bhp on an otherwise standard engine running PT81 cams and a remap. Yes
Posted 7th Sep 2012 at 13:02
JWP EFi
Turbo Legend!
So it can be done then
Posted 7th Sep 2012 at 15:07
ryangti6
It can be done on standard manifolds but just like everyone is about Pug1off's claims I would be very, very surprised if it is possible to add another ~25% power to one of these engines with simply cams and a remap especially considering the cams that will fit in a standard engine are still pretty mild.
If you get your pistons pocketed, a bit wilder cam than Pt81 and a good map I don't see why it can't be done but no disrespect to Rich W, Stan or whoever believes 207 Bhp is achievable with the mod's mentioned I don't agree. A couple of others on here have got ~190bhp which I would say is more realistic. I know of a few people that have gone quite a bit further than simply fit Pt81's and Map and still only get around 200.
Make sure you keep us posted with what you do decide and what you achieve from it, it would be good to see.
Ryan
Posted 7th Sep 2012 at 15:26
You can get 190hp with cams and map + Decat all day long as long as you sort the pistons. Its not like someone hasnt done that already.
That car that has past hands more than a amsterstam prossy has 190hp.
I dont see how you could get 200hp with a little more work.
Maybe go into the same detail as Russian guy did and enlarge the TB and then polish the inside of the inlet.
With regards to the pug 1 off claims.
The car i think you are all talking about is the 205 in evo?
Well that has 195hp for a start from the following
"However, for an extra £1595 you can have the same motor uprated to full ‘195’ spec with high-lift, long-duration camshafts, a tubular exhaust manifold, a modified inlet housing and an ECU remap with a 7800rpm rev limit. That little lot delivers 195bhp"
Frankly I dont see why not.
The rev limit is raised.
Theres new cams
A new exhaust manifold
and a map.
Seems perfectly realistic to me,
Posted 7th Sep 2012 at 15:56
I don't see why they needed to raise the limit, they make peak well before the standard one.
Posted 7th Sep 2012 at 16:08
http://www.youtube.com/watch?v=ssaRxKV6jXk
Looks like they managed it with some Catcams 4903110's.
Don't know what pistons were used though.
I happen to have a set which i could let go for the right money. Whistle LOL
Posted 7th Sep 2012 at 16:26
ryangti6
Would it be that they have retarded the cams to avoid clearance issues thus pushing peak power higher up and the need to rev more? I know it will still tail off before 7.8k but from seeing their graphs but they do seem to have fairly good high rev figures.
I don't know what the clearance is like on their choice of cams and wether that would have any bearing on it tbh but that's the only feasible reason I can think of.
Ryan
Posted 7th Sep 2012 at 17:36
That does make sense actually yes.
Posted 7th Sep 2012 at 17:42
Don't let the figures take over.
What one person had on one set of rollers could be more than a 'higher spec' car on another.
  • Posted 7th Sep 2012 at 17:59
    miles
    This old one again, Claims are just claims and RR figures are just that, One will read different to another and on different days
    I don't like fitting base spec cams as for the money you can get much better, Abit with bottom end work
    www.pugracing.com
    Posted 7th Sep 2012 at 23:50
    swiftyboi006
    Spending 5k on a N/A engine will get you a low boost s/c setup with 50more bhp and alot more torque...........no brainer
    Black p3 Love
    Posted 9th Sep 2012 at 17:51
    The only reason you would bother spending that sort of money on N/A would be if you were limited to a series whereby you couldn't go forced induction. Yes
    Posted 9th Sep 2012 at 21:40
    fatlapit
    +1 sc/turbo ftw
    Posted 9th Sep 2012 at 21:43
    I'll certainly agree with the SC. Yes Devil
    Posted 9th Sep 2012 at 21:55
    fatlapit
    boooooooooooooooooooooooooooooooooooooooooooooooooooo stan No
    Posted 9th Sep 2012 at 21:59
    LOL
    I'm sure your turbo will be awesome mate, look forward to seeing the end result. Thumbs up
    Posted 9th Sep 2012 at 22:05
