displaying posts 1 to 25 of 41
| Author | Subject: six stalling |
pug pete
Regular Location: newbury Registered: 30 Apr 2011 Posts: 161 Status: Offline |
my gti6 has started to stall when put clucth down not al the time any ideas please |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Sometimes this is the map.Is it when you are coming to a stop mainly? ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
pug pete
eliotrw wrote: Sometimes this is the map. Is it when you are coming to a stop mainly? yeah ive change that and ive change the coolant temp sencor sat |
How well does it idle ? ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
pug pete
eliotrw wrote: How well does it idle ? it idles gd now and again it does judder when in 3rd at bout 30mph if that helps |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
Most likely to be the ICV pal. Try GSF for a new one |
pug pete
woody. wrote: Most likely to be the ICV pal. Try GSF for a new one ![]() ok will have 2 try that is that behind the throttle body quite a small sencor |
Nope it's the big black thing the small hose from the air intake goes to It is situated on the back of the throttle body |
If that doesnt sort it maybe unplug the pas sensor and see if it makes a difference.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
JWP EFi
im having erratic idle issues, changed stepper motor for 2 known working ones as well as mapand still all over the shop lol, cleaned out plastic housing, fitted new o rings etc |
You should check the pas sensor as well imo.Does all kinds of weird s**t.. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
pug pete
should i have a spare plug in same lome as map sencor |
Yeah ![]() ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
pug pete
eliotrw wrote: Yeah ![]() few i have looked for icv b4 i must be blind have 2 hav look mrw |
Basically look at the throttle body and follow the small tube that comes off the intake hose to where it ends.It attaches directly onto that hose Two bolts iirc Little black thingy. Should as magnettimarelli on it. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
pug pete
eliotrw wrote: Basically look at the throttle body and follow the small tube that comes off the intake hose to where it ends. It attaches directly onto that hose Two bolts iirc Little black thingy. Should as magnettimarelli on it. ok will do thanks let all know weekend on how get on thanks lads |
woody.
Another vote for the power steering sensor too. Give the ICV a good clean and see if it helps at all (in my experience you'll have to replace it if its broken anyway). The power steering sensor is down between the rad and the inlet manifold, unplug that to see if it gets any better, if it does, replace it. Good luck! |
rich306
Seasoned Pro Location: Portsmouth Registered: 09 Aug 2009 Posts: 1,834 Status: Offline |
Sorry guys, but i'm confused as to why a PAS sensor would affect the engines performance? Can anyone explain? ________________________________________ Richies Project RallyeElectrical work carried out in Portsmouth jamiek_uk2000 wrote: - Top Tip!!! You'll need to throw money at the car. Not on parts. Just stand near your car and throw loose change at it, I find this increases performance for a short period of time |
cress87
Seasoned Pro Location: Norwich Registered: 30 Mar 2007 Posts: 11,360 Status: Offline |
It compensates for the extra load placed on the engine by the PAS pump when the PAS system is operated. When they misbehave they can cause idling and stalling issues.________________________________________ ![]() You feed beefburgers to swans. ![]() I may have been speeding Mr Policeman but [a] I live for the 306 and [b] did you see that dog? omfg |
stan_306gti6
The lambda could well be at fault here, especially as you say it can be juddery low down at 30mph. That fault wouldn't be caused by an iffy ICV or PAS sensor. ![]() Try unplugging the lambda sensor and go for a short drive. If the problem is dramatically better/cured go and buy a new lambda and replace it. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
woody.
Pretty sure you've got shares in GTi6 lambdas stanley!? |
stan_306gti6
The amount of lambdas that have gone faulty recently I wish I did sell them mate...![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
jord294
I vote pas switch ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
JWP EFi
eliotrw wrote: You should check the pas sensor as well imo. Does all kinds of weird s**t.. funny you say that, when i did diagnostic run i had 2 trouble codes, PAS sensor and clutch which can only be A/C clutch |
blandy
jord294 wrote: I vote pas switch ![]() The wires are broke to my pas switch but doesn't stall? So I'm guessing if it's unplugged etc then it doesn't look for a reading from the sensor? |
