displaying posts 1 to 25 of 41
Author Subject: six stalling
pug pete
my gti6 has started to stall when put clucth down not al the time any ideas pleaseThumbs up
Posted 3rd Sep 2012 at 22:45
Sometimes this is the map.
Is it when you are coming to a stop mainly?
Posted 3rd Sep 2012 at 22:48
pug pete
yeah ive change that and ive change the coolant temp sencor sat
Posted 3rd Sep 2012 at 22:50
How well does it idle ?
Posted 3rd Sep 2012 at 22:53
pug pete
it idles gd now and again it does judder when in 3rd at bout 30mph if that helps Thumbs up
Posted 3rd Sep 2012 at 22:56
woody.
Most likely to be the ICV pal. Try GSF for a new one Smile
Posted 3rd Sep 2012 at 22:59
pug pete
ok will have 2 try that is that behind the throttle body quite a small sencor
Posted 3rd Sep 2012 at 23:01
Nope it's the big black thing the small hose from the air intake goes to Thumbs up
It is situated on the back of the throttle body Thumbs up
Posted 3rd Sep 2012 at 23:04
If that doesnt sort it maybe unplug the pas sensor and see if it makes a difference.
Posted 3rd Sep 2012 at 23:09
JWP EFi
Turbo Legend!
im having erratic idle issues, changed stepper motor for 2 known working ones as well as map
and still all over the shop lol, cleaned out plastic housing, fitted new o rings etc
You should check the pas sensor as well imo.
Does all kinds of weird s**t..
Posted 3rd Sep 2012 at 23:10
pug pete
should i have a spare plug in same lome as map sencorWink
Posted 3rd Sep 2012 at 23:13
Yeah Smile
Posted 3rd Sep 2012 at 23:15
pug pete
eliotrw wrote:
Yeah Smile
few LOL i have looked for icv b4 i must be blind have 2 hav look mrw
Posted 3rd Sep 2012 at 23:17
Basically look at the throttle body and follow the small tube that comes off the intake hose to where it ends.
It attaches directly onto that hose
Two bolts iirc
Little black thingy. Should as magnettimarelli on it.
Posted 3rd Sep 2012 at 23:19
pug pete
Two bolts iirc
ok will do thanks let all know weekend on how get on thanks ladsThumbs up
Posted 3rd Sep 2012 at 23:21
woody.
Another vote for the power steering sensor too. Give the ICV a good clean and see if it helps at all (in my experience you'll have to replace it if its broken anyway). The power steering sensor is down between the rad and the inlet manifold, unplug that to see if it gets any better, if it does, replace it. Good luck!
Posted 4th Sep 2012 at 00:12
rich306
Sorry guys, but i'm confused as to why a PAS sensor would affect the engines performance?
Can anyone explain?
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 4th Sep 2012 at 00:35
cress87
It compensates for the extra load placed on the engine by the PAS pump when the PAS system is operated. When they misbehave they can cause idling and stalling issues.
Posted 4th Sep 2012 at 00:44
The lambda could well be at fault here, especially as you say it can be juddery low down at 30mph. That fault wouldn't be caused by an iffy ICV or PAS sensor. Wink
Try unplugging the lambda sensor and go for a short drive. If the problem is dramatically better/cured go and buy a new lambda and replace it. Yes
Posted 4th Sep 2012 at 11:45
woody.
Pretty sure you've got shares in GTi6 lambdas stanley!? Razz
Posted 4th Sep 2012 at 12:55
The amount of lambdas that have gone faulty recently I wish I did sell them mate...LOL
Posted 4th Sep 2012 at 16:39
jord294
I vote pas switch Yes
Posted 4th Sep 2012 at 16:54
JWP EFi
Turbo Legend!
funny you say that, when i did diagnostic run i had 2 trouble codes, PAS sensor and clutch which can only be A/C clutch
Posted 5th Sep 2012 at 22:50
blandy
The wires are broke to my pas switch but doesn't stall? So I'm guessing if it's unplugged etc then it doesn't look for a reading from the sensor?
Posted 5th Sep 2012 at 22:53
