then i thought about the power steering setup, would just fit a non pas rack from a basic model or even just
remove the hydraulic ram from the existing rack
Has anyone ever done this? if so how did you find it?
| Author | Subject: Power steering delete |
JWP EFi
over the winter i want to track prep my GTi6 so looking at ways to save on weight, air con and abs are first to gothen i thought about the power steering setup, would just fit a non pas rack from a basic model or even just remove the hydraulic ram from the existing rack Has anyone ever done this? if so how did you find it? |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
What is it like at the mo? Personally i wouldnt bother. If i was making a all out track car i probably wouldnt...Theres so many places i would be looking at first before going that extreme I would work down from this Spare wheel (15kg) Swap cylones for team dynamics alloys or c5 steelies (12-16kg) Ac system (15kg ish) Bonnet heat carpet (2kg or more) Swap seats for buckets (20kg depending on buckets) Fit kighter calipers and bells (as much as 8kg) Light weight flywheel and crank pulkey (4.5kg) Strip interior (lots kg) At this point you would start thinking about about fibreglass and carbon etc as well as polycarbonate windows Then sonewhere Down here that stuff is worth while...... i get removing abs in a track car but still. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
plate diff+xsara rack, keep PAS.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
eliotrw wrote: What is it like at the mo? Personally i wouldnt bother. If i was making a all out track car i probably wouldnt... Theres so many places i would be looking at first before going that extreme I would work down from this Spare wheel (15kg) Swap cylones for team dynamics alloys or c5 steelies (12-16kg) Ac system (15kg ish) Bonnet heat carpet (2kg or more) Swap seats for buckets (20kg depending on buckets) Fit kighter calipers and bells (as much as 8kg) Light weight flywheel and crank pulkey (4.5kg) Strip interior (lots kg) At this point you would start thinking about about fibreglass and carbon etc as well as polycarbonate windows Then sonewhere right now its a full fat gti6! tbh i prefer not have power assisted steering, ok very heavy for parking etc but once your on the move the feel is alot better Down here that stuff is worth while...... i get removing abs in a track car but still. |
JWP EFi
welshpug! wrote: plate diff+xsara rack, keep PAS. ive heard people talk about a ph1 xsara rack, whats different about them? |
I dunno. Im not sure i would want to drive one without. I wouldnt say mine is lacking feel either. Ive never driven a car that communicates as much through the steering wheel as a gti6. So why bother really?If its something you really want then do it, but personally if it is for weight loss reasons then theres far better gains to be made. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
JWP EFi
elliot, totally agree with you about steering feedback with pas, very well compromised imo |
eliotrw wrote: I dunno. Im not sure i would want to drive one without. I wouldnt say mine is lacking feel either. Ive never driven a car that communicates as much through the steering wheel as a gti6. So why bother really? If its something you really want then do it, but personally if it is for weight loss reasons then theres far better gains to be made. Drive a Xsara VTS ________________________________________ ![]() |
Really? I would have thought the rack dumbs it down a bit? As its basically more assisted?They do intrigue me though i would just need to drive one first as you say (or a gti6 with the same rack even) ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
JWP EFi
iirc the vts has less turns lock to lock...welshpug will know!not sure if ph1 or 2 had this or both |
Yeah ph1 has 2.4 and the ph2 2.6 iircPhase 2 doesnt fit directly though So ph1 is the way to go as its no fuss and less turns anywho ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
More info herehttp://www.306gti6.com/forum/showthread.php?id=147619 ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
If I had a 306 in the fleet (the HDi doesn't count) then I'd be buying a VTS rack and the 21mm TBs before anything else. I'm popping my VTS rack on the 205. Will take it down from 3.9 turns ![]() ________________________________________ ![]() |
Hmmm.Its something for me to have a think about for sure. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
JWP EFi
dangti6 wrote: If I had a 306 in the fleet (the HDi doesn't count) then I'd be buying a VTS rack and the 21mm TBs before anything else. I'm popping my VTS rack on the 205. Will take it down from 3.9 turns ![]() already have 21 mil t/b's to go on once ive rebuilt spare beam, vts rack from ecp is only £130 trade |
anth
jsa666 wrote: remove the hydraulic ram from the existing rack Has anyone ever done this? if so how did you find it? I done this- was f**king heavy at first and also when stationary, was great once up to speed and you got used to it. The car certainly picked up a fair bit faster once it was all out. I was just running crank to alternator without tensioners or pulleys. |
jsa666 wrote: dangti6 wrote: If I had a 306 in the fleet (the HDi doesn't count) then I'd be buying a VTS rack and the 21mm TBs before anything else. I'm popping my VTS rack on the 205. Will take it down from 3.9 turns ![]() already have 21 mil t/b's to go on once ive rebuilt spare beam, vts rack from ecp is only £130 trade Good luck getting the correct one!!! 21's arent enough for track. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
welshpug! wrote: plate diff+xsara rack, keep PAS. |
stan_306gti6
What would you suggest for track then Meirion? I have 21mm TBs and I think they are fine for track...________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
23 or 25 but you need special dampers and the ride will be shocking on the road. 21 is a good compromise though.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
stan_306gti6 wrote: What would you suggest for track then Meirion? I have 21mm TBs and I think they are fine for track... says the man who does not drive his car ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: stan_306gti6 wrote: What would you suggest for track then Meirion? I have 21mm TBs and I think they are fine for track... says the man who does not drive his car ![]() ![]() Very true, although I drove it for the last 3 years on track and fast road and found it fine. ![]() So to you! ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
stan_306gti6
daveyboy wrote: 21 is a good compromise though. That's what I felt when I was deciding what to go for. They certainly give good road performance and on track they give a good improvement over the 20's so I was happy. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
23 ftw.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
welshpug! wrote: 23 ftw. The problem with that is the ride for everyday road driving will probably be too harsh as Jim (Dave) says... ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
