Author Subject: Shopping list for decent power Throttle boddies conversion
matt evans
Just a "theoretical" question for the more experienced people on here, but to build a decent power yet reliable TB converted engine what bits would be required from top to bottom?
My thoughts are
Rebuilt bottom end with h/duty bearings
Forged rods
Forged high compression pistons with bigger valve cut outs
Standard Pug MLS head gasket
Lightly worked head with uprated cams and bigger valves?
Vernier pullies
Throttle boddies & Inlet & injectors
Propper air filter (not socks)
Aftermarket management.
Is there a definitive list of what works, where to get it from and what sort of power gains you would likely see?
Just thinking out loud at present....Whistle Whistle Thumbs up
honestly3k wrote:
owain wrote:
Posted 16th Aug 2012 at 10:20
CockThumbs up
just buy a more powerfull car to start with springs to mind......Roll eyes
that ring any bells?!?!?!?LOL
Posted 16th Aug 2012 at 10:42
If your'e going to go as far as you have in that list though, you might as well put a richw gasket on it two. Its only 40 quid more?
Posted 16th Aug 2012 at 10:57
Solid lifters maybe?
Posted 16th Aug 2012 at 10:58
daver6
coskev wrote:
CockThumbs up
Haha, someone give him the answers haha. I'll be doing this too, but I'm gonna try and stroke mine too
Wishbone Polybushes available
I would also be tempted to go 2.1 if i was going down the N/A root tbh.
Matty's makes what 190 at the wheels?
I'm sure thats enough Razz
Posted 16th Aug 2012 at 11:00
daver6
Does he have a project build on here? I'm unsure of who Matty is.
Posted 16th Aug 2012 at 11:11
MattyRallye. Ill find it.
Posted 16th Aug 2012 at 11:15
Here you go.
http://www.306gti6.com/forum/showthread.php?id=75829&page=4#85
226hp was final result. Cams TB's and 2.1
Posted 16th Aug 2012 at 11:16
jord294
Buy my china and build your engine as high boost
Job done Thumbs up
Posted 16th Aug 2012 at 12:10
Mine's being mapped next week on bodies. I opted for the Sandy Brown/Colin Satchell setup.
Purely for noise if anything.
  • Posted 16th Aug 2012 at 12:17
    Job done Thumbs up
    He makes a good point this is the best throttle body conversion about. Big grin
    Posted 16th Aug 2012 at 12:27
    crossflow
    To get the 230bhp mark:
    Head ported and valves seat cut to 3 angles
    Cams
    Valve spring and retainers.
    Standard valves.
    Proper 4 branch manifold with system
    Forged pistons
    Standard rods with arp bolts
    Standard crank balanced
    Lightweight flywheel and front pulley
    After that bodies and aftermarket ecu, I have used the plug and play one that goes into the standard loom and has been perfect for me, takes alot of the hassle of rewiring out of the equation
    Posted 16th Aug 2012 at 14:05
    matt evans
    I'm not a cock CosBev, just weighing up my options for the engine in the garage, do i do something fruity with it like above or build it back up to OE with a slight twist, ie pistons and fast road cams and have the standard management tweaked by Chip Wizards (i think thats what they are called)
    Due to costs, thats probably more than likely the way i'll go. It's something to have a go at this winter, keep me occupied.
    Whats the best sort of cams/piston combo to go for and will standard rods suffice for that? ARP bolts required etc etc?
    Posted 16th Aug 2012 at 16:30
    crossflow
    As above standard rods are strong once balanced and arp bolts are used, with this spec 8000 rpm is your rev limit.
    Cam wise I do my own spec cams ground nothing off the shelf as there never a spec that I required.
    Piston wise you can get 218 bhp on a standard bottom end but with the age of the engine, the bores of the engine more than likely will be out of tolerance and too big. The problem is you can't get oversized standard pistons.
    You can go as cheap as possible and get wossner or I get my own piston made for me to my designs cost a little more but are far superior to the wossner piston
    Posted 16th Aug 2012 at 18:40
    smegal
    Buy Jord's SC-6 and bas**rdize it for parts. More bhp/£
    Ex SC-6
    Now in a Megane R26
    Posted 16th Aug 2012 at 21:22
    Looking at your list you don't need bigger valves, even if you can get them you won't be held back by the already huge standard valves until you head north of 270bhp and 8,500rpm.
    Posted 18th Aug 2012 at 21:52
    simonjames
    shopping list of decent power :-
    A. sell 306
    B. buy faster car
    /thread
    MY EBAY ITEMS
    07943066306
    Posted 18th Aug 2012 at 22:16
    A. sell 306
    B. buy faster car
    /thread
    Funnily enough thats what Matt advised me to do a few weeks ago!!!!Whistle
    Thumbs up
    Posted 18th Aug 2012 at 23:19
