displaying posts 1 to 25 of 30
Author Subject: Rule of thumb - replacing suspension bolts
Hi All,
Bear with me as this is probably a bit silly.
But when you lot replace suspension components do you normally replace the nuts/bolts/washers etc as well?
Ive not changed any suspension stuff before just interior bits and sensors etc where you dont necessarily have to worry about the strength of the parts or they are less exposed to the elements.
So generally do you:
A)Always replace bolts washer and nuts with new ones when changing suspension bits ( for example even if a balljoint pinch bolt looks fine you still replace with new)
b )Only ever replace ones that have a bit of rust
Posted 13th Aug 2012 at 13:35
if i buy a new part and it's got new bolts with it, i use them regardless. technically a lot of stuff is Nyloc nuts so you wouldn't reuse them anyway but i've seen countless people do it without any problems. choices i guess
i've reused suspension pinch bolts and even nylocs without problems on my own cars. should you do it? not really. i wouldn't do it on someone elses car i was fixing
Posted 13th Aug 2012 at 13:39
Didnt think about nylocs Doh
Only pain in the ass is a few things I have came without bolts so I've had to get them separate.
I assume that the big front wishbone one wouldnt need to be replaced though? The one that goes through the frontmost bush and subframe?
Posted 13th Aug 2012 at 13:48
if you buy a new bush you might get the bolts though, so you might not "need" to do it but why not use the new bolts? you've paid for 'em!
but if you haven't bought new parts i'd re-use old ones. don't thnk they are a nyloc anyway either
Posted 13th Aug 2012 at 13:53
As Ricky said, you should do it yes but you would probably get away without.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Aug 2012 at 13:57
I didn't replace my front wishbone bolt, I just thread locked it.
Well I can't remember replacing it anyway.
Posted 13th Aug 2012 at 13:58
YOU NEGLECTED YOUR CAR, IT WILL NOT SELL
Posted 13th Aug 2012 at 13:59
LOL
Posted 13th Aug 2012 at 14:01
thing is if you are going to replace the front wishbone bolt, you may aswell replace the square piece or metal with the hole with the threads in that it screws into.
Posted 13th Aug 2012 at 14:09
and also the full subframe
and rear beam (or that'd happen if i was doing it)
Posted 13th Aug 2012 at 14:10
WHERE DOES IT END :p
Ok so in that case i need
Hub to damper bolts nuts washers
balljoint to wishbone ones x6
Wishbone bush to subframe x 2
ball joint to hub x 2
And I assume thats it.
Posted 13th Aug 2012 at 14:12
No, you must fit new numberplate bolts and those little plastic cap things on the wipers too, or the wheels will fall off.
Posted 13th Aug 2012 at 14:14
I did that also LOL
Posted 13th Aug 2012 at 14:18
f**k, I didnt budget for that :p
Tbh my cars falling apart at the seams anyways.
Think ill just replace EVERYTHING.
Posted 13th Aug 2012 at 14:49
mik
I've got new bolts for everything, but I am replacing subframe, wishbones, struts etc and it is easier to deal with nice new stuff than knackered rusty old stuff, and new bolts look better with shiny new parts.
The Haynes manual actually lists the nuts/bolts you should replace.
Cherry Rallye SOLD
Posted 13th Aug 2012 at 16:47
honestly3k
Your ball joints should come with new bolts anyway, pinch bolts will be fine to use again provided they are in good useable condition. I used the 6 new retaining bolts that came with the ball joints, reused the old washers, and reused the pinch bolt
Just use your common sense really, if a bolt/nut is damaged, rusted to fook, replace....its its in fine useable condition i wouldnt worry too much, id be far more concerned about getting the torque values right to ensure it doesnt fall apart whilst driving it off your drive Smile
Posted 13th Aug 2012 at 16:53
a lot of bolts used on the mk3 mondeos suspension components are stretch bolts and they recommend changing them every time, I bet loads of folk don't know that and don't change them though and have no issues.
Posted 13th Aug 2012 at 16:57
Mondeo's attract very pikey owners - so I think you may be correct.
They also endanger lives on motorways at high speed and don't recycle.
Now I know 2 of those will be on the money. What's it guna be? You speeding tree hugger.
  • Posted 13th Aug 2012 at 17:20
    That's reminded me to pick up a proper torque wrench so nice one Smile
    Posted 13th Aug 2012 at 17:28
    honestly3k
    http://www.ebay.co.uk/itm/Draper-Powerset-Torque-Wrench-1-2D-30-210Nm-Dual-Scale-30357-/260997511966?pt=UK_Hand_Tools_Equipment&hash=item3cc4a9fb1e
    I bought that one, its pretty good
    Posted 13th Aug 2012 at 17:33
    Nice one! Ordered. Usually I get the halfords stuff but that was a fair bit more and draper aren't shabby
    Posted 13th Aug 2012 at 18:08
    gilesy
    :eliotrw
    Posted 13th Aug 2012 at 20:24
    I replaced all of mine purely because it's relatively little money (but a surprising amount of hassle) compared with the cost of the new suspension. The main problem is that they're all high-tensile 10.9 bolts, which means they can take an awful lot of torque.
    Nothing to say they haven't been over-tightened in the past (I'm guilty of this too) so you don't really know what condition they're in. There could easily be cracks under the rust you can't see.
    Nyloc nuts should always be replaced, especially close to the brakes the nylon quickly becomes useless.
    Shiny.
    Posted 14th Aug 2012 at 08:48
    gilesy wrote:
    :eliotrw
    We dont all eat sleep and drink this stuff Razz
    I thought it was an innocent enough question anywho Razz
    Looks good owain, Just need to think of somewhere near me that would do this sort of stuff :s
    Posted 14th Aug 2012 at 09:41
    peugeot?! LOL you'll get the proper shanked bolts then
    Posted 14th Aug 2012 at 09:46
