displaying posts 1 to 25 of 42
Author Subject: hose near oil filter
As i was performing a few checks on my car, which ive been doing a lot since i suspected the head gasket was screwy i noticed that this pipe to the right of the oil filter (its so lose thry nearly touch)seems to be leaking coolant down the front of the engine.
Its only really seeping but its enough for it to collect at the sump and drip a teeny bit.
I checked the coolant and its level was more or less the same as 300 miles ago.
There was no mayo in it. No pressure release either.
Its hard to tell from above or under the car weather the coolant is coming from the pipe ( or more specifically its clip / where it mates with whatever it connects to OR slightly further above
Anyideas all?
Posted 21st Jul 2012 at 20:14
Anyone know what this is ? Sad
Posted 23rd Jul 2012 at 09:37
I think its for the oil cooler altough I thought that hose was lower down...
Posted 23rd Jul 2012 at 09:54
the oil cooler has 2 pipes coming off it. the one to the right of the filter is a breather hose, is it the thick one? like 45mm thick?
Posted 23rd Jul 2012 at 10:36
1 sec sorting a photo
Posted 23rd Jul 2012 at 10:38
its pretty thick yeah, secured with a clip and so close to the right side of the filter (as you look at it) that they nearly touch
Posted 23rd Jul 2012 at 10:44
Posted 23rd Jul 2012 at 10:46
in the last photo, the right oil cooler pipework is facing downwards when it's usually not.
the thick one goes up and to the right, to a T piece, which joins the breathers to the block and then upwards to the cam cover
Posted 23rd Jul 2012 at 10:47
I have a feeling its actually the once just below what you can see in the second photo and is visble in the first
Slightly below the fileter to the right.
Having said that, with the manifold on I can't see any higher up than that so it could easily be any of those pipes running down the block and collecting artound the hose :s
Posted 23rd Jul 2012 at 10:52
the thick one to the right of the cooler will have vapour in it, so it either needs tightening up or a hose above it is leaking and running down to it. the hose isn't a really tight fitment though, i pulled mine off with the clip still attached
Posted 23rd Jul 2012 at 10:54
This makes sense, As I seem to loose coolant after a drive where the car reached a certain temperature.
I Assume that could be when more vapour is going through that pipe (And therefore more of it is leaking?)
What kind of clip is it? a screw tighten jobby or a clip one?
Posted 23rd Jul 2012 at 11:36
It will be one of those hook over onto itself clips*.
* That isn't a trade name.
  • Posted 23rd Jul 2012 at 12:00
    LOL i thought so, Peugeot seem to love them....
    I assume this is a manifold off job then really?
    Posted 23rd Jul 2012 at 12:06
    Just to clarify (This is a dumb question.
    But the two oil cooler pipes contain coolant right? rather than oil being pumped to that mini radiator thing?
    Or is it the other way round?
    Posted 23rd Jul 2012 at 12:09
    Coolant runs between those two hoses through the heat exhanger.
    You should be able to get the thick breather pipe off without removing the manifold. Take the top hose off to the cam cover. Pull the T piece off. Get underneath and pull the large pipe it question out and away and it should drop down without having to of removed the inlet.
  • Posted 23rd Jul 2012 at 12:12
    Is it one pipe all the way up to the cam cover then (Parts number wise)
    I.e if I order a new one will it come as one part?
    Posted 23rd Jul 2012 at 12:32
    Just to clarify, the pipe your experiences problems with - is it the thick spongy curved one?
    It comes apart from the T piece, so you should be able to purchase just that bit alone from Pug.
    Have a look on service box.
  • Posted 23rd Jul 2012 at 12:46
    Dan, the oil breather system comes as one part. I broke the short piece that attaches to the cam cover and had to buy the whole lot regardless. Dry
    However, I can't see this pipe being the issue. It only carries oil vapour back to the sump, and the complaint is that coolant is being lost when up to temp...
    Posted 23rd Jul 2012 at 13:34
    Oh i see I thought it was coolant.
    In that case I imagine the next port of call is the right most coolant hose attached to the oil filter/head exchanger and work up from there?
    Posted 23rd Jul 2012 at 13:44
    matt evans
    As you can se from Rickkys picture the oil cooler has two water "pipes" the left hand one goes upwards, then accross to the right where it joins into the top rad hose (you wont see most of it as its under the inlet manifold and surrounded with loom and stuff)
    The right hand pipe is a much shorter run which goes to the lower pipe on the drivers side of the radiator, about 3inches above the bottom hose.
    The two clips that secure these pipes originally are spring clips, not worm drive jubilee clips, so you may have some corrossion on the actual oil cooler water pipes which is just allowing water to ooze out. Easy enough to sort, although i suspect you'd be best off draining the coolant, then the oil and taking the oil cooler off the car to do it, replacing the oil cooler seal (between the cooler and block) for good measure, that way you can really clean the pipes up and check the rubber hoses for damage as well
    honestly3k wrote:
    owain wrote:
    Posted 23rd Jul 2012 at 14:15
    So basically if i ever wanted a mocal oil cooler, now is the time?
    Posted 23rd Jul 2012 at 14:34
    You will need to strip all these parts down to fit the oil cooler, so yes basically if you wanted one you may as well fit it whilst it's all in bits now. Yes
    Posted 23rd Jul 2012 at 16:49
    Wouldnt it replace / make redundant the pipes too? Or no?
    Posted 23rd Jul 2012 at 18:56
    Posted 23rd Jul 2012 at 19:55
    are you going to go for a thermostatically controlled oil cooler? or normal one?
    Posted 23rd Jul 2012 at 19:58
