displaying posts 26 to 42 of 42
Pages (2): 1 [2]
Author Subject: hose near oil filter
Well the mocal ones i thought you were meant to fit on top of the old one?
Dunno really whatever is best?
Posted 23rd Jul 2012 at 20:31
eliotrw wrote:
Wouldnt it replace / make redundant the pipes too? Or no?
it can do,just put a straight hose joiner between the two coolant pipesThumbs up
if its mainly a road car I would leave the heat exchanger fitted,and fit the mocal sandwhich plate to it.
As the heat exchanger is used to warm the oil in cold weather,and tbh mocal oil coolers over cool the oil on road cars.
Posted 23rd Jul 2012 at 20:34
needs to be thermostat type for road car imoThumbs up
open circuit will cool the oil too much.Yes.
Posted 23rd Jul 2012 at 20:35
Ok so going by advice ive been give so far the best plan of action would be:
Take off inlet.
Drop oil
Remove oil filter
Remove current heat exhanger
Fit new seal
Refit
Connect inlet of heat exchanger to outlet
Fit mocal plate on top
Fit mocal rad
Fit oil filter
Put in new oil
Ammirite????
Posted 23rd Jul 2012 at 21:11
Not really!!!No
If you don't reconnect coolant pipes to heat exchanger you might aswell bin heat exchanger totally!!Smile
Posted 23rd Jul 2012 at 22:17
Im confused now then :s explain lmao...
Posted 23rd Jul 2012 at 22:22
Don't forget coolant spills.
  • Posted 23rd Jul 2012 at 22:45
    True would need a lot of it i assume
    Posted 23rd Jul 2012 at 22:54
    Your two options are when fitting a air to oil cooler:
    1.Remove heat exchanger,join coolant pipes together,fit Mocal cooler plate straight onto engine block.
    2.Leave heat exchanger on the block with coolant pipes connected,fit Mocal plate to heat exchanger.
    Posted 23rd Jul 2012 at 23:04
    Post #35
    Ok so in number 2 there would effectively be 2 oil coolers? Correct? Obviously with the mocal coming into effect the same time as the the standard one?
    And 2 is the best option for road?
    How many rows? I noticed you can get them in a few sizes for 10 up.
    Posted 23rd Jul 2012 at 23:11
    Post #36
    How often do you go out on track?
  • Posted 23rd Jul 2012 at 23:15
    Post #37
    Not yet but i plan on doing so a few times next year once the new suspension is on.
    I also instead on supercharging around may so i assume it will be farvmore importsnt then
    Posted 23rd Jul 2012 at 23:22
    Post #38
    I have both the sandwich plate and heat exchanger still fitted on mine. Yes
    I run a 19 row oil cooler, but to be honest on a standard car (or low boost) a 13 row will be more than sufficient. Wink
    Posted 24th Jul 2012 at 11:15
    Post #39
    no oil cooler is more than sufficient Razz
    Posted 24th Jul 2012 at 11:21
    Post #40
    I've been thinking about making a few of the recommended s/c changes pretty soon just to reduce the initial outlay.
    Slimline fans etc etc.
    However realistically this is just going to push back how quickly I can sort out my suspension.
    So i think I might have to just sort this for now and re-visit the oil cooler thing at a later date :S
    Theres so many bits I have lying around that i need to actually start fitting stuff now Razz
    Posted 24th Jul 2012 at 11:32
    Post #41
    IMO, if the prices of the smaller parts push back Suspension changes, then you need to be asking yourself are you getting cold feet at the idea of opening your wallet.
    With the supercharger idea, you are either commited and happy to shell out money left right and centre with the aim of a finished setup your happy with or it isn't for you IMO.
  • Posted 24th Jul 2012 at 11:43
    Post #42
    No no no i am happy with the cost.
    Its just atm I think the momeny would be better spend sorting the suspension.
    Once thats done the next port of call is a exhaust from prospeed and then looking at build a nice platform for the supercharger around april/may.
    This would involve doing the fan work, getting an oil cooler and a new nissen rad
    Posted 24th Jul 2012 at 12:53
    Pages (2): 1 [2]
