Author Subject: 205 GTi parts
eddy_gti6
A friend of mine is in need of a 205 GTI 1.6 gearbox and drive shafts. Not sure if there is any difference between the 1.6 and the 1.9 but thats what he has asked for
Prices posted if anyone can help please Thumbs up
Posted 14th Jul 2012 at 22:57
Got 2 205 GTis here in bits.
Is it a BE1 or BE3 box he's after?
Got a pair of 1.6 shafts. The 1.6 box I have is the earlier BE1 box.
  • Posted 14th Jul 2012 at 23:07
    eddy_gti6
    Not sure he just said 1.6 205 Gti Gear Box Think its a BE3 box he is after. Whats the difference?
    Posted 14th Jul 2012 at 23:20
    one lift up reverse and the other isnt Wink
    Posted 14th Jul 2012 at 23:32
    eddy_gti6
    Its the none lift up reverse then.
    Are there any difference between the 1.6 and 1.9 box and the 1.6 and 1.9 shafts? as far as shafts go if i remember right the splines on the hud end are different.
    Do the 205 shafts fit into a 5 speed xsara vts box?
    Posted 14th Jul 2012 at 23:35
    The 1.6 and 1.9 boxes have different ratios.
    I have a 1.6 BE1 box, and a 1.9 BE3 box with a damaged casing. I could swap the levers and reverse mech over, but is more effort than it's worth so pop a wanted on the drivers forum.
    For a VTS box with 205 shafts you need the end half of a 6/Xsara shaft to go in the diff.
  • Posted 15th Jul 2012 at 09:48
    eddy_gti6
    You have PM dan
    Posted 15th Jul 2012 at 11:05
