displaying posts 1 to 25 of 45
Author Subject: bleeding 4 pot Brembos?
Hi am I right in thinking that the first bleed point to bleed on the Brembos will be the inner one as that's the first side to receive the fluid?
I know the order is rear p/s - rear d/s - front p/s - front d/s
Basically working from furthest away from the master cylinder and working closer but I'm just guessing to do the
Inner nipple first before the outer on each caliper?
Thanks amdy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 14th Jul 2012 at 17:33
but I'm reading conflicting information so really arent sure which nipple should be done first.
Posted 14th Jul 2012 at 17:45
whatever works Thumbs up
Posted 14th Jul 2012 at 17:52
It doesn't matter??
I've only got 1.5 litre of fluid! Was reading a thread on here and some guy used over 6 litres, he forgot to open 1 of the nipples!
Posted 14th Jul 2012 at 17:55
It's very humid and rainy today, will this put moisture in the system or am I thinking too much f1 again?
Posted 14th Jul 2012 at 18:36
Don't worry about it so long as you don't get rain into the bottle or the reserviour
Posted 14th Jul 2012 at 18:57
All bled up now but each time I crack each front nipple I get a few bubbles first then solid fluid, I move to other bleed nipple on same caliper then a few bubbles again before solid fluid, moving on to the first side and I get the same, back to other side and same again and so on.
Is this normal?
Edit:
It could be the bit of air in my bleeding line from when I remove it from the nipple after tightening it,
I'll try again and try and leave my bleed line full of air.
Posted 14th Jul 2012 at 19:17
R1-Mini
Hi
If there the same as the old Metro Brakes
We had to open both Bleed Nipples at the same time and lock them of at the same time
A bit fiddly but worked
Might be worth tryin it that way
Posted 14th Jul 2012 at 19:28
I will try that tmmrw, first I will do it and keep the tube full of fluid so I know it's not bubbles just from the tube.
Thanks.
Posted 14th Jul 2012 at 20:05
R1-Mini
Be Good to Know this as ive got to Fit some Brembos to my CAB
In the Next week or so
Posted 14th Jul 2012 at 20:15
Yeh I've gotta fit some when they turn up obvs will use someone to pump the pedel for md anyway. Get fluid from work for nout so not worried how much gets used.
Posted 14th Jul 2012 at 23:57
You'll never get all the air out on the first bleed, do them as best you can, give it a drive to shake them up then do it again.
I buy big 5 litre bottles of cheapy Unipart brake fluid for the initial bleed, then once it's bled through I'll flush through the decent stuff.
Generally furthest from the reservoir first, doesn't really matter which side of the caliper first, then go around the whole car at least twice.
Are you bleeding them by yourself or is someone helping? I find best bet is to have someone pump the pedal slowly, and tighten the nipple up as they're pushing down so you get zero air back into the brakes.
Posted 15th Jul 2012 at 11:31
that's what I was doing mate, was also holding the tube into the fluid do if anything did backflip it would be fluid not air.
I'm struggling for a helper today cos Katie's a Mardy arse.
Posted 15th Jul 2012 at 11:36
Well they stop it pretty well, and
That's before they're bed in!
Posted 15th Jul 2012 at 12:42
Not bad are they? Just drive it about for a bit and let them settle then do it again, never had a problem.
Posted 15th Jul 2012 at 17:25
Thanks folk, I'll do that, it sets the abs off easy now!
Posted 15th Jul 2012 at 18:35
Ah, so you need better tyres then. Then better suspension. IT NEVER ENDS.
Posted 15th Jul 2012 at 18:42
Allready got good year eagle f1s just worn in, bilatein b8 with eibach springs.
I'm going for pilot sports next time
Posted 15th Jul 2012 at 18:45
R888's FTW. This is the problem with improving things on a car, all you do is move what the weak link is. Normal road tyres are fine while you have normal brakes, but now you've improved your brakes so much it's the rubber or suspension letting you down Yes
Or you could decide it's good enough and you're leaving it how it is. For now...
Posted 15th Jul 2012 at 18:47
tbh mate, it brakes very well, I didn't mean it as a bad thing, it's really really good, I'm more interested in stopping it snaking around under hard braking, it did this before!
Posted 15th Jul 2012 at 18:52
Heh no I had the Brembos on mine for a long time before I upgraded to Ash's kit, for road use they're just awesome and you can easily damage people's faces.
Any squeal? Or is this Ash's kit?
Posted 15th Jul 2012 at 19:03
stu
Glad to hear the brakes are finally being put to good use! Cool
Keep up the good work. Thumbs up
It's ashes kit 330mm bought from the one and only stu ^^ thanks stu awsome!
it still snakes like f**k under hard braking though, it's as though the rear beam is moving around.
Posted 15th Jul 2012 at 21:23
Depends how well your rears are working and how evenly. Don't have any problems on mine even under really hard braking. The abs comes in well before it snakes about. What rear beam set up you got?
Posted 15th Jul 2012 at 21:50
21mm tb's
Hybrid arb
Bilstein b6/b8
Solid rear mounts
4 wheel alignment said I had 0 toe both rear wheels.
It snaked before I fitted these, Jim had a look at the beam and all seemed ok.
It's very lively at the rear on braking and road camber changes and acceleration eg
When it had its mot the braking was very even, it feels no different now balancewise
Posted 15th Jul 2012 at 22:15
