displaying posts 26 to 45 of 45
Pages (2): 1 [2]
Author Subject: bleeding 4 pot Brembos?
You only check front imbalance not rear on mot Although the rears may have a similar top output one may achieve this earlier causing uneven breaking. Can't see the rear beam being an issue then you got a similar set up to mine. Got miles solid mounts xsara VTS rear axle with 21mm bars and an Ash hybrid arb and b6/8 which ever they are (yellow & blue). Mine feels unshakable at the rear unles you hit a big bump over a corner then can be sketchy.
Only problem I have is the front is still slightly lower than rear so once on the limit it understeers. Will be getting eibachs soon and possibly changing to b8's on the front as well.
Posted 15th Jul 2012 at 23:08
Is it possible the rears are locking under heavy braking?
Posted 16th Jul 2012 at 07:33
No pretty sure there not, you have to brake heavy from a
High speed to get it snaking, I think it's something with the suspension doing it, it's always felt a little unstable since I fitted all the parts, but it handles great.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 16th Jul 2012 at 07:43
Can you stiffen up the front suspension at all? Sounds like too much weight's being shifted to the front. I had to put a bias valve in and have it almost entirely to the front as the back almost comes off the floor whenever I brake hard.
Posted 16th Jul 2012 at 07:45
hmm, maybe it is too soft upfront.
B8s with eibach springs, standard roll bar.
Posted 16th Jul 2012 at 07:49
Only thing I can suggest is find a suitable road where someone can watch you brake hard, see how much rake you're getting; if the car's just lunging forwards you'll never stop smoothly.
Posted 16th Jul 2012 at 07:51
^Never been an issue with mine, and mine dives like a scuba expert in a haram:
Posted 16th Jul 2012 at 17:38
I'll let you have a go soon when I get chance phil.
Posted 17th Jul 2012 at 14:07
Both mine like to snake around when hard on the brakes from high speed, i quite enjoy it. LOL
Posted 19th Jul 2012 at 13:06
Post #35
the snaking around under heavy braking isnt no where near as bad since getting the welding doing on the chassis legs where the bulkhead meets the floor at the front, mot tester said all that was holding her together was the door pillars and roof.
still does it a bit though.
Posted 20th Oct 2012 at 16:15
Post #36
Now that is worrying Andy! Shock
Posted 28th Oct 2012 at 14:43
Post #37
i think he was over exaggerationing mate
Posted 30th Oct 2012 at 19:44
Post #38
Even so, as long as it's all ship-shape now then it's good.
How's the progress coming on with the repair?
Posted 30th Oct 2012 at 19:45
Post #39
only just sent off quote, ive kinda lost interest mate, need to put her away really until i gain the interest and finish it.
Posted 30th Oct 2012 at 20:16
Post #40
That's a shame mate, but I do totally understand where you're coming from. Maybe put her away for a year or so until you feel the passion to carry on and complete it. Smile
Posted 31st Oct 2012 at 07:04
Post #41
Are you runing solid beam mounts? I found braking stability was greatly improved by ditching the rubber ones.
Posted 31st Oct 2012 at 15:56
Post #42
That's a very good point Jim. Yes
I found the rear end stability under braking wasn't good and that was when I had standard brakes and standard rear mounts. I changed the mounts to solids though before I upgraded to the 330mm Brembo kit so I didn't experience Brembo braking with the rubber mounts. Food for thought.
Posted 31st Oct 2012 at 16:44
Post #43
I think he's on solids already.
Posted 31st Oct 2012 at 16:46
Post #44
yes im on solids mate, do you think the solid mounts could of broken?
Posted 31st Oct 2012 at 18:29
Post #45
Unlikely, they are pretty hefty bits of kit. Yes
Mine have been on there for 5 years and have taken a fair amount of stick with no trouble.
Posted 31st Oct 2012 at 19:16
Pages (2): 1 [2]
