Author Subject: Ash 310mm Brembo Kit Clearance
bellcp306td
I have just got the 310mm brembo setup that ash makes I run 16” speedline turini wheels and the clearance is so close that when the callipers get warm they rub the wheel. Has any one had this problem befor?
I am going to take alittle bit off the Calliper it should be fine.
Where did the road go!
Posted 7th Jul 2012 at 11:41
mabgti
NV motors
Thats a bit close, i run 16 pro race 1.2 which a few a few mm more clearance. But 17's are more suited especially for brake cooling
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 7th Jul 2012 at 11:55
Rich E Forum Admin
Yeah, I've had the same with my 16 inch Turinis. Taking a little off the calipers is the right way forward for the kit to fit with those wheels.
Posted 7th Jul 2012 at 12:41
playboyb
I had this problem with those brakes and my 17" superlegeras, I put the back wheel on the front and it cleared.
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 8th Jul 2012 at 08:48
bellcp306td
Ok i took abit off the calliper and its all good now
Posted 9th Jul 2012 at 16:10
Niall
Dragging up an old thread here! Ive now got the exact same setup and exact same problem. How much clearance do i want roughly?
Posted 6th Aug 2014 at 17:28
6waysforward
I have about 3mm clearance and its fine.
Before I filled them down, the were constantly rubbing.
Posted 6th Aug 2014 at 18:26
Niall
I should have about 2mm with the amount I've taken off. Didn't want to take off that much at all seeing as i don't know how thick it is there
Posted 6th Aug 2014 at 18:50
rallyestyle
Not the same kit but i have next to nothing in terms of clearance on my setup and i have never had a problem No
An alternative would be to sand/file the inside of the wheels a little where it catches, there should be more to play with there than on the caliper as there is at least 1mm's worth of paint.
Just Drive It
Posted 6th Aug 2014 at 19:30
jamiek_uk2000
My Brembo's rub on my 1.2's so I took a file to it, they seem to be OK. Gutted though as they had just been refurbed before I done that.
330mm under 16" FTW!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 6th Aug 2014 at 19:45
Niall
Any idea roughly how much you took off Jamie? Ive taken about 1mm off the calliper
Posted 6th Aug 2014 at 20:08
fatlapit
Just put 17s on ffs. Rubbing down brake structure is a great idea. Brembo made them that big for a reason.
Posted 6th Aug 2014 at 20:59
jamiek_uk2000
Yeah only about 1mm myself, it's half paint in all fairness.
I can't run 17's as the wheel will foul on my shocks, I've only got around 10mm between the tyre and bottom nut of the shock
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 6th Aug 2014 at 21:04
Niall
Dude, I've taken off the raised logos and so little that you can still see the grain in the metal. If it was a few mm needed i wouldn't be fitting them but i doubt the raised "brembo" and "renault" logos are structural.
Posted 6th Aug 2014 at 21:19
osm2121
If you put 17" with lower profile tyres to keep the same overall diameter, you wont have trouble at all with your shocks
Posted 22nd Aug 2014 at 01:44
