displaying posts 26 to 50 of 54
Pages (3): 1 [2] 3
Author Subject: Light throttle/low revs misfire
I haven't heard of it myself but I can't actually verify whether this would have been present on any of my engine configurations because I've only had a lightened flywheel since being charged and at this point and every new (more powerful) conversion after that has been bespoke mapped. Yes
Posted 18th Feb 2013 at 22:58
Lots of places can chip the gti6 ecuYes
Its the old stlye way of doing it though, the ecu needs opening up and a new chip fitting.
They can alter this chip to take into account for mods before fitting, but then if its not spot on the downside is the chip needs to be removed again and put back in the writer to be alteredThumbs down
Pretty sure its only chip wizards that offers to fit a cable to the ecu which they can then adjust the chip without having to remove it from the ecuThumbs up
Posted 18th Feb 2013 at 23:18
beez_neez_gt
Great thanks guys, very useful information Thumbs up
I would rather go see chip wizards, unless rich w can send me one much the same, which may be a cheaper easier way ?
Ill PM him.
On a side note, i unplugged the PTS plug and the revs stayed the same for say ten seconds, then they started to go lower and lower till it just cuts out, ECU reset too ??
I thought the TPS being unplugged wont make any difference at all and should work almost as good before unplugging it ??
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 18th Feb 2013 at 23:32
Pretty sure Rich uses chip wizards converted ECU's.
So prob better off going straight to them,but going by what people on here say it is hard to get in contact with himDunno
Posted 19th Feb 2013 at 09:46
beez_neez_gt
Ok ill give him a try then see how it goes, will be a while till i can now afford it anyways unless i sell a set of alloys, im addicted to buying them LOL
Pug fee`ver,
Posted 19th Feb 2013 at 10:01
monty-69
Mine has the same symptons also but im not convinced its flywheel unless the pickup is machined in the wrong position. It runs fine on idle, just slight misfire at light throttle and over - run. Think its time to measure manifold vacuum down the road, maybe blank off the manifold vacuum take-off. Failing that its a case of checking wiring and swapping bits with miss ladybell Confused
Posted 10th May 2013 at 11:46
It's usually either the lambda (disengages at high rpms/high loads), or wear at the start of the throttle pot (which is where they spend most of their time).
Flywheel shouldn't make it miss, there's plenty of acceleration enrichment, and it would be a lot worse just blipping the throttle and low rpms/high throttle opening than when actually accelerating the car
Also, check the coilpacks for any pinholes in the insulation.
Posted 10th May 2013 at 11:54
Someone that had there car remapped said the injector timing needed adjusting due to the lightened flywheel, this cured there low down misfire.
Posted 10th May 2013 at 12:26
That's interesting to know...Yes
Posted 10th May 2013 at 18:18
beez_neez_gt
Post #35
Well after all the issues with mine all what was wrong was the wrong plugs fittted, ie map and tps on the wrong sensor.
However mine does not have any misfire at all and mine has the lightened flywheel so maybe its something else as many others hasnt had any misfires when fitting one ??
Pug fee`ver,
Posted 10th May 2013 at 18:26
Post #36
Is yours on the road now then?
Posted 12th May 2013 at 12:06
mike rallye
Post #37
Did anybody manage to resolve this fault?
Posted 14th May 2013 at 17:43
monty-69
Post #38
Not yet im struggling for time but i will get to the bottom of it. Even if it means going as far as testing all the wires resistance from sensors to ecu. Does anyone have a decat with this problem?
Posted 14th May 2013 at 18:55
beez_neez_gt
Post #39
All my work passed its mot no problem or advisers etc but today it just couldnt get an mot due to being a 92 car which is a shame, so waiting till Monday now when ill know if car came with a cat or not when new. Cars passed other years without a cat so will see how it goes. Fook me she is fast though, revs just fly up so quick to what i remember with the old mi it had previously.
Pug fee`ver,
Posted 18th May 2013 at 19:12
beez_neez_gt
Post #40
Its ok had trouble with car either being a cat or non cat car and all sorted now so once i pop back ill have an mot pass no adviseries which im proud to have with all the work done to it.
Pug fee`ver,
Posted 20th May 2013 at 18:16
beez_neez_gt
Post #41
Pug fee`ver,
Posted 20th May 2013 at 18:33
beez_neez_gt
Post #42
Pug fee`ver,
Thomsongti6
Post #43
I have the same problem in about 6th gear 2k rpm 40mph and only slight throttle it misses a bit then picks up also noticed i get a bit of pinking when hard accelerating right uo theought the revs im wondering if its an over fueling problem as some days its ok others its worse, could it possibly be a knock sensor? I only think this as my sensor wiring has been taped up and feels quite flimsy but bot had a minute to get a look at it.
Posted 21st Sep 2015 at 11:52
mocinim
Post #44
I dont think you have an issue chap i think your just over gearing not enough engine speed to high a gear does it do the same in 5th at that speed
BLACK RALLYE - phoenix
WHITE RALLYE - valliant
Posted 21st Sep 2015 at 16:02
RetroPug
Post #45
No way. A healthy engine will pull away from 20mph with part throttle with no misfiring or issues let alone 40mph.
Posted 21st Sep 2015 at 19:20
mocinim
Post #46
Fair play have never tried to do this in 6th gear
Posted 22nd Sep 2015 at 09:34
mocinim
Post #47
Not in the rallye anyway
Post #48
not in 6th LOL:
Posted 22nd Sep 2015 at 10:31
Post #49
It still shouldn't misfire, regardless.
Posted 22nd Sep 2015 at 11:24
Post #50
probably not a misfire, just an engine doing the ERMAGHERDYOUCRETINCHANGEGEAR noise.
Posted 22nd Sep 2015 at 11:57
Pages (3): 1 [2] 3
