Author Subject: Hybrid ARB with pics
jord294
Hi guys
I have available an ash supplied hybrid arb
It has been freshly powdercoated, and includes powdercoated end caps
Excellent condition.
£180 inc delivery please
Posted 29th May 2012 at 15:48
jord294
bump
Posted 2nd Jun 2012 at 10:34
jord294
£165 inc delivery
Posted 6th Jun 2012 at 16:30
jammapic
What price for collection?
HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech
306 GTi-6 Track Car - 200+ hp all N/A!
306 DTurbo Track beasty - 209.9hp - RIP
Posted 7th Jun 2012 at 16:55
jord294
£150 please
Posted 7th Jun 2012 at 17:47
Would you throw in some of the seals that go behind the end plates? If so i can collect this weekend for 150 cash?
Posted 12th Jun 2012 at 02:18
jord294
I'll supply the foam rings but not the rubber ones, as they are around £5 each
Posted 12th Jun 2012 at 08:30
Are the foam ones the ones that go behind the end plates where as the rubber ones go on the inside of the end plates where the arb connects on? Those ones don't really perish to badly if that's what I'm thinking of Wink. But ueh can collect this sat eve of your about as I'm coming to crew to pick up my sc kit Big grin.
Posted 12th Jun 2012 at 09:26
jord294
The foam rings sit on the end plate and are up against the end of the trailing arm shaft. You could use the rubber bushes again (they sit inside the trailing arm shaft)
Just common practice that I fit new when supplying rebuilt beams
If you can get here before 5pm Saturday, it would be appreciated
Posted 12th Jun 2012 at 09:35
I will do my best but if not can venture up Sunday as am staying just outside wrexham. Probably can't get to you before 5 as leaving tunbridge wells at 12:30 after work.
Posted 12th Jun 2012 at 10:14
smegal
Andy, Are you interested in a pair of GTI-6 torsion bars or a beam tube? The bars may need some fettling as they were hit with a hammer to remove them, The tube should be ok. The pins and arms were used by yourself to build a 205 beam.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 13:39
jord294
Thanks for the offer, but I have plenty in stock
Posted 12th Jun 2012 at 14:16
smegal
No worries. Was just seeing as they'll be getting weighed in and Pete will be traveling to you from mine.
Ex SC-6
Now in a Megane R26
Posted 12th Jun 2012 at 14:17
jord294
SOLD
Posted 16th Jun 2012 at 22:21
