Author Subject: K-Sport Camber Adjustable Coilovers @ Pug1Off
info@pug1off.com
Pug1Off are pleased to announce the addition of K-Sport to our parts range. Finally there is a value for money camber adjustable damper on the market at just £799+vat. Key features of this kit include:
  • 36 position damping adjustment – easily adjust the damping settings to meet the requirements of circuit / tarmac rally or track day setups.
  • Pillowball spherical bearing alloy camber adjustable top mount.
  • Monotube gas / oil damper design with 50mm diameter strut with 44mm diameter piston.
  • 6061 forged alloy body construction to reduce unsprung weight.
  • Fully ride height and droop adjustable within reasonable limits.
  • Spring rates / lengths optimised for either circuit or tarmac rally use.
  • Full TÜV Rheinland certification.
  • Street kits also available without camber adjustments (£625+vat) and also for other models in the Peugeot / Citroen range.
    For more info please see: http://www.shop.pug1off.com/index.php/cPath/35_97 or contact us via the usual details.
    N/A XU10J4RS = 302.1 bhp / 184.2 lb.ft
    Turbo XU10J4RS = 500.2 bhp / 443 lb.ft
    USC 2011 Double Class winners
    N/A FWD 0-60 winners at TRAX 2011
    Developers, stockists and installers of superior upgrades for the Peugeot 306 GTi6 & Rallye, including:-
    *NEW!!!!! 4.8:1 final drive for BE3/6
    *BBM Group N engine mounts
    *Cat Cams and vernier pulleys
    *Emerald ECU's
    *Jenvey throttle bodies
    *Uprated gear linkages and short shifts
    *Quaife & Tran-X LSD's for BE3/6
    *Tar-Ox brake discs and Ferodo DS2500 pads
    *Solid rear beam mounts
    *21-25mm torsion bars
    *25mm rear anti roll bars
    Posted 13th May 2012 at 02:30
    take it that's a generic pic as that does not look like a 44mm rod LOL
    are those top mounts curved to suit the 306 strut top? or another generic pic?
    sound good, colours much like AST Hmm what spring rates do they use?
    Posted 13th May 2012 at 09:27
    info@pug1off.com
    That is actually our own promotional pics of the 306 kit.
    44mm relates to the piston size. The tube is not inverted.
    I will try to get you some spring rates on Monday. All the best, Matt.
    *Emerald ECU's
    Posted 13th May 2012 at 10:17
    info@pug1off.com
    I also forgot to mention that we are offering forum members fitment and 4-wheel laser allignment / camber adjustments for just £100 on orders placed in May.Thumbs up
    *Emerald ECU's
    Posted 13th May 2012 at 10:20
    pugheaven
    Same as the d2 coilovers, the top mounts are flat but still fit as Eddie fitted them to his car, what is it like to get parts and what warranty do you give with them as at somepoint someone had managed to bend the part of the body that sits in the hub!
    Posted 13th May 2012 at 11:30
    info@pug1off.com
    The Parts are covered by a 12 month warranty, in the event of a problem, ie. a leak, the whole damper would be replaced. We have tested these units on road and track extensively, fitted to Chris's red 306 Rallye, over the last 12months, (a member of this forum). We are very satisfied with the performance and longevity of the product.
    I can certainly ask for a price on the lower part of the damper for your friend, if you'd like to send me a pm or email. Many thanks.
    *Emerald ECU's
    Posted 14th May 2012 at 08:19
    how much is a pair of rears valved for a 205 on 21mm bars and a zx on 23mm bars? Hmm
    Posted 14th May 2012 at 10:23
    fatlapit
    Matt/Lucy you can buy these off the ksport .co.uk website for just over £600 delivered!!!!!!
    Posted 26th Jul 2012 at 13:22
    fatlapit
    or here
    http://www.h-dev.co.uk/product_info.php?products_id=893
    Posted 26th Jul 2012 at 13:24
    phil b
    Like I said at fcs, nice coilovers with neat features but as I said U guys are waaaay out of my price range, specially for a component with only 12months warranty..
    '97 PH1 'Sigma Blue' 306 GTI 6 project 'Tooters'
    194.2bhp 127.6 dB
    '96 PH1 'Black Noir' 306 DTurbo (project in permenant storage)
    '94 300tdi LR Discovery (project gone dead and buried)
    '99 td5 LR Discovery 2 (trailer tug and family bus) project 'in the garage getting chassis welded' (again)
    The 6 can go fast, the disco can go anywhere
    Built: 9 January 1997 - that's a Thursday
    Skip Brown cars: tarporley Cheshire Tel: 01829 720492
    add me --> philbrindley85@hotmail.com
    TEAM: Snapper Sad
    Posted 29th Jul 2012 at 13:28
    fatlapit
    12 is standard i thought
    Posted 31st Jul 2012 at 13:42
    Gaz give 2 years FWIW
  • Posted 31st Jul 2012 at 13:50
    nobody warrants for competition use afaik.
    Posted 31st Jul 2012 at 13:59
