Has anyone got one?
| Author | Subject: metal disc for trailing arms |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
I need one of the metal disc things that slide on the rear trailing arm shaft.Has anyone got one? Cheers |
rear disc shields? better off buying from pug mate |
chris with a pug
no its the round thing that slides on the the trailing arm that the seal sits up against.Those sheilds are way to heavy to go back on |
jord294
i've got 2 with very minor weathering. no damage £10 posted? ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
chris with a pug
I think I have sourced one now, but if it falls though I will let you know |
jord294
chris with a pug wrote: no its the round thing that slides on the the trailing arm that the seal sits up against. Those sheilds are way to heavy to go back on ![]() Ah. They fasten on to arm shaft with interference I've only got new ones It was the sleeve the seal sits in I thought you needed ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
![]() might have one. its 5154 09, "Cup", pretty cheap from a dealer if you find one with some in stock, they're SS I think. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chris with a pug
jord294 wrote: chris with a pug wrote: no its the round thing that slides on the the trailing arm that the seal sits up against. Those sheilds are way to heavy to go back on ![]() Ah. They fasten on to arm shaft with interference I've only got new ones It was the sleeve the seal sits in I thought you needed how much for 2 new ones? |
about £3.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chris with a pug
1.57 each and they have 5 instock so ill be popping in later to get some. |
jord294
chris with a pug wrote: 1.57 each and they have 5 instock so ill be popping in later to get some. they have 5 in stock as they come in bags of 5 ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
