displaying posts 26 to 50 of 112
Pages (5): 1 [2] 3 .. last
Author Subject: Rear Diffuser
stick the spare wheel back on Thumbs up
Posted 28th Apr 2012 at 12:14
Most aero mods are a comparative waste of money/time on regular cars, they sit too high for ground effect, have lousy drag coefficient and don't have the power to reach the speeds where aero comes into its own anyway.
Posted 28th Apr 2012 at 12:15
marco gti6
Interesting topic Yes I'll keep an eye on this
Posted 28th Apr 2012 at 12:16
Swirl pot and fuel pump in way now, that's why I removed it.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Apr 2012 at 12:38
Same as mine. Wink
I have thought about this issue in the past when the spare wheel gubbins was all taken out, it does create a void space before the rear bumper which must be producing a "parachute" effect to a degree. I just think that it isn't that huge a problem especially with a road car that you would need to combat it with any kind of mod.
Posted 28th Apr 2012 at 13:30
manthos
I've thought about a full undertray for a while. Think a diffuser will look good if subtle but not do too much however the parachute effect could be solved just by drilling some holes in the back bumper. Will keep an eye on this though.
Team SUPERCHARGED
Old Project thread
Posted 28th Apr 2012 at 16:56
drilling holes if anything will make it worse, just cut the middle out.
Posted 28th Apr 2012 at 17:00
I agree, although if you drill holes or cut the middle out it will look gash, unless some sort of diffuser was installed somehow. I know I wouldn't want to "cut" my bumper apart to be honest.
This is an interesting topic though, and I look forward to see if anyone comes up with a decent idea of combatting it. Smile
Posted 28th Apr 2012 at 18:51
just a simple flat sheet from the tank backwards should suffice Smile
Posted 28th Apr 2012 at 18:56
eddy_gti6
Post #35
Been pricing thingd up and itd gona cost around £300 to do a full undertray with front splitter and rear diffuset what is far too expensive i think.
What about blanking the pocket where the spare wheel was with a plastic or aluminium sheet?
Posted 28th Apr 2012 at 18:58
davedgti6
Post #36
That's what I was thinking, being a Joiner I was thinking of just using a piece of 10mm marine plywood sprayed black, cut to shape and kept away from the exhaust a bit, this would cover my swirl pot and fuel pump etc, if it proved to be a benefit then could get some aluminum cut to the same size as the ply, the plywood would be free for me too Whistle
Posted 28th Apr 2012 at 19:07
clen666
Post #37
You can get a 3m x 1.5m sheet of that composite aluminum for about £100, not sure how heavy or rigid it is though Dunno
Team 'unintentional rat look'
Posted 28th Apr 2012 at 19:27
eddy_gti6
Post #38
Polycarb should do the job, i have plenty of that LOL
Posted 28th Apr 2012 at 19:50
Post #39
Seeing as you can get the material for free then Dave, you try it and post the results...Whistle
Question is though, once you've fitted it how are you accurately going to test it to see if it's made an ounce of difference? Do you have access to a windtunnel?? LOL
Posted 28th Apr 2012 at 21:54
eddy_gti6
Post #40
Loads of tabs and a hair sryer should do the job Laugh my ass off
Posted 29th Apr 2012 at 01:39
mik
Post #41
These sorts of subjects are covered here.
Especially:
Modifying Undercar Airflow Part 1
Modifying Undercar Airflow Part 2
These articles include some test results of experiments on road cars.
Based on these articles I am going to install the front wheel "fences" you see on a lot of modern cars including my wife's Mk2 Ford Focus, a factory Pug engine undertray, and possibly a simple flat plastic panel attached to the spare wheel carrier to reduce the parachute effect. To do this I was going to use 3mm black plastic sheet from ebay (though the rear wheel cover might need 4mm for rigidity). I was not going to use expensive stuff.
Even at motorway speeds there will be little real difference, but it might improve things slightly and it is a bit of fun.
Cherry Rallye SOLD
Posted 29th Apr 2012 at 11:30
Post #42
Ferrari underside:
http://honda-tech.com/attachment.php?attachmentid=170472&stc=1&d=1288178092
thread on a Honda forum about same subject, I might read it myself later.
http://honda-tech.com/showthread.php?t=2854103
it's just the rear bumper that I was interested in to try improve the parachute effect, if you want to improve the more technical side of it then theres not much point unless you've got a lotta money to waste.
Posted 29th Apr 2012 at 11:58
fatlapit
Post #43
not sure you will need a diffuser as i dont think the 6 can go fast enough
Posted 29th Apr 2012 at 18:36
Post #44
Marine ply FTW. Saw several of the touring cars sporting it at Thruxton today.
  • Posted 29th Apr 2012 at 18:43
    fatlapit
    Post #45
    but the touring cars have aero packages on them a diffuses wont do alot by itself
    Posted 29th Apr 2012 at 19:11
    Post #46
    In what capacity were they using it Dan?
    Posted 29th Apr 2012 at 19:34
    Post #47
    I reckon its worth plugging the parachute. But making a proper diffuser is more hassle than I could be bothered with.
    Posted 29th Apr 2012 at 20:45
    Post #48
    This ^^
    If you managed to smooth out the airflow and block up the gap before the rear bumper it would be beneficial to straight line speed but only up the top end. Yes
    A proper diffuser would cost thousands to design and implement, and I don't even think you would see a 'real' difference on the track to be honest in terms of cornering ability. I am still interested in a proper neat solution to the parachute issue though. Smile
    Posted 29th Apr 2012 at 23:32
    Post #49
    A few hours with some 2mm ally and a riveter should see it dione.
    Posted 29th Apr 2012 at 23:34
    Post #50
    See if you can knock up a prototype and then post pics of it attached to the car. You never know, you could patent it and start selling them as a genuine aftermarket product. Smile
    Posted 29th Apr 2012 at 23:48
