Got sooo many spare engine parts I could really do with selling some.
All prices below are delivered to UK Mainland.
Standard camshafts (pair) - £40 delivered:
Knock sensors - £10 delivered:
Main PCV hose - £10 delivered:
Heat exchanger return hose - £10 delivered:
Harness support bracket from font of engine - £10 delivered:
Rear coolant distribution pipework - £15 delivered:
Alternator - £25 delivered:
Thermostat housing - £20 delivered:
Ancillaries / engine mount bracket - £25 delivered (I can plasma cut these down to suit the S/C conversion at extra cost)
Blocks complete with piston oil spray bars - £45 delivered:
Sump - £30 delivered:
Section of timing belt cover - £7.50 delivered:
Rear engine mounts - £15 delivered / or £30 delivered for one with a BakerBM solid rubber mount:
Oil pump spacer plates - £7.50 delivered:
Complete dip=stick assemblies - £15 delivered:
Re-conditioned oil pump, has been stripped down, cleaned out and the steel gasket between the the two halves replaced - £45 delivered:
Contact Details:rich@lynxpowerengineering.co.uk
07732 822546
rich_w
