Author Subject: what paint for cam covers ect
barnettjd77
As above i need the cambelt doing so at the same time want to clean it up in the bay a tad, it's a mess! cam cover seal/gasket has gone, what paint is best to use? or info on cleaning them down to repaint ect..
A red rallye in progress!
Posted 19th Apr 2012 at 14:06
I used halfords high temp paint and it was good.
To clean, I would go with brake cleaner. Is sub £1.50 a tin from Peugeot off the top of my head and does a better job than some degreasers i've used.
It's what I used on my covers, block etc before painted and has been fine.
  • Posted 19th Apr 2012 at 14:09
    barnettjd77
    Oh ideal i shall get some then, I have brake cleaner here already, do you put a coat of laqeur on or not?
    Posted 19th Apr 2012 at 14:10
    i would for a better Finnish,.. ensure this is high temp lacquer too!
    Posted 19th Apr 2012 at 14:23
    matt evans
    I use brake cleaner for everything these days!
    But yes, high temp paints/laquer will do the job
    honestly3k wrote:
    owain wrote:
    Posted 19th Apr 2012 at 14:41
    barnettjd77
    I shall get some of that too then LOL
    debating on colours though, got a black 6, but not sure whether silver or white will be better
    Posted 19th Apr 2012 at 14:54
    every one will always have a different opinion on what looks best,..
    have a nose though some pix of engine bays and decide for your self what the best colour is,.. it's your car! LOL
    Posted 19th Apr 2012 at 15:07
    barnettjd77
    Yeah true that may go for a lovely yet manly pink colour yet i have a bit of time to think LOL
    Posted 19th Apr 2012 at 15:13
    I didn't bother using laquer. I think it said something about not bothering. You don't need to use primer with it either.
    Silver to make it look OEM. White will just look dirty against everything else I imagine.
  • Posted 19th Apr 2012 at 15:31
    Clean it uP well first using different size wire brush attachments (to get in all the nooks and crannies) in a cordless drill.
    I would use etch primer first and then
    If you want a smooth finish rather than the factory bumpy one then use a few coats of primer or high build Primer second.
    I would defiantly use a laquer after, high temp would be better.
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 21st Apr 2012 at 22:43
    barnettjd77
    I have just started cleaning some bits up as am doing the rocker cover gasket at the same time, i got a high temp silver paint from halfords and said don;t use primer with it. Smile
    Is it actually possible to clean engine up a bit with it still in car? bloody everything is in the way LOL
    Posted 24th Apr 2012 at 16:59
    beez_neez_gt
    Etch primer does not like a lot of heat and the cam cover do get quite hot. I would use 2k clear coat if polished or 2k epoxy primer with 2k paints of any colour you wish to use. These methods will outlast the car, epoxy primer is the toughest primer out there, can also be used on aluminum blocks too.
    I used degreaser before and got oil leaks, so thanks for the brake cleaner tip, very good Thumbs up
    Pug fee`ver,
    Pick a Bogey, buy a Pug.
    Posted 11th Dec 2012 at 12:15
    brake cleaner is fantastic and i use it for cleaning almost everything
    Posted 11th Dec 2012 at 13:57
    rich306
    I did it all when the engine was out, in all honesty unless you remove a fair few bits off of the engine itself, you're going to have fun!! LOL
    Richies Project Rallye
    jamiek_uk2000 wrote:
    - Top Tip!!!
    Posted 11th Dec 2012 at 19:39
    barnettjd77
    I am in NZ until may so mum is driving it haha! don't think she will be too fussed about the whole thing to be honest LOL
    Posted 13th Dec 2012 at 11:17
    Including your dishes i'm lead to believe Wink
    Posted 13th Dec 2012 at 11:22
