Author Subject: Clipping fork on to bearing
I am doing the clutch this evening on my ph3 and have read some horror stories about people struggling to get the clutch fork lined up on to the bearing.
I found the following from Mei
follow the destructions which say to remove the arm off the shaft and mark it's position and it goes on first time Wink
Now, I made a start on this the other day and stripped everything off inluding the pin, arm and top bush and just have the bolts holding the box on ready to go back out with my new clutch and whip the box off to fit it.
Hopefully I am not too late with the marking of the arm LOL But as the fork/shaft is still in situ and the box hasn't been loosened at all, can I 'get away' with putting the arm back on top and looking where the pin hole is through the shaft and then marking up?
When the box is ready to go back on, is it a case of lining the arm marks back up so it is in the position it was in previously when the cable was unclipped from it?
This could potentially save me hours of swearing this evening so any pointers greatly appreciated.
When I fitted the gearbox to my J4RS in the 205 it was the simpler case of bearing on to fork which I didn't realise this differed until I opened the clutch box and found the bearing already on the plate.
  • Posted 18th Apr 2012 at 12:46
    Its a pig of a job sometimes,good luck LOL
    If its any help,i taped the bearing in position with some masking tape to make things easier when i last did one
    Posted 18th Apr 2012 at 12:54
    LOL @ masking tape
  • Posted 18th Apr 2012 at 13:38
    barnettjd77
    1st time lucky to line it up, didn't have a bloody clue what i was doing but it all went together and is working so must be alright ha! good luck LOL
    A red rallye in progress!
    Posted 18th Apr 2012 at 13:45
    matt evans
    As long at the clutch plate is central, generally they just take some wiggling to get right.
    honestly3k wrote:
    owain wrote:
    Posted 18th Apr 2012 at 14:28
    Be nice if I could get to that stage actually.
    Every bolt out, can I get the fecking box off?!
    Gah I'm wiggling it like mad but the release bearing won't let go! Sad
  • Posted 18th Apr 2012 at 19:31
    you have removed the arm right?
    Posted 18th Apr 2012 at 19:42
    Yeh arm off top amd all bolts
  • Posted 18th Apr 2012 at 19:51
    how many bolts? starter too?...
    Posted 18th Apr 2012 at 19:59
    5 hex 4 17mm
    Inch gap all round starter hanging away.
    Can wiggle it like mad but the clutch fork won't budge. Have shook it twiste etc
  • Posted 18th Apr 2012 at 20:02
    And inlet bracket is undone
  • Posted 18th Apr 2012 at 20:08
    both shafts out, top mounting stud removed, PAS pipe clips unbolted? Hmm
    Posted 18th Apr 2012 at 20:10
    Shafts out.
    3 top moun bolts out and mount removed.
    Pas clips are on block and box is free there
    Speedo housing on, but cnt see the use removing that?
  • Posted 18th Apr 2012 at 20:15
    My assistant failed to notice a second bolt on the inlet bracket. He blames me, but the bas**rd came off so all is good LOL
  • Posted 18th Apr 2012 at 22:19
    miles
    Worth taking the speedo housing and the stud off, makes life a doddle then
    www.pugracing.com
    Posted 18th Apr 2012 at 23:42
    I agree, certainly in a 306 it does although, things may be different in a 205? Unsure
    Posted 19th Apr 2012 at 07:19
    Yeah I realise now due to the clearance at the back it will make life easier lifting it back on with those out the way
  • Posted 19th Apr 2012 at 07:27
    very much the same, though I don't know why you raised that Unsure
    dangti6 wrote:
    I am doing the clutch this evening on my ph3.
    Posted 19th Apr 2012 at 09:20
    I raised it because Dan said he left it on and got the box out. I have always found it near impossible to get the box past the subframe on the '6' if you don't remove the housing first.
    I have never removed a '6' box from a 205, so I wasn't sure if was easier or not or how much space was available. My guess is maybe slightly less as its a smaller bay but I didn't know for sure. Smile
    Posted 19th Apr 2012 at 09:34
    LOL yeah Mei that's why I put the bit about it being on the ph3 as I thought people would assume it was the 205 one I was doing.
  • Posted 19th Apr 2012 at 09:37
    It was a pain to remove in situ, so i'l certainly remove it for putting it back on.
    I personally wouldn't fit a '6 box to a 205 anyway. If I did, I think I would just remove the engine and gearbox together in one LOL
    Well at least half the job is done now anyway and the clutch is on. I need to wait for the fork bushes to arrive from Peugeot now. Not looking forward to this bearing malarky. I removed the fork and tried to see how it 'clipped' into the bearing and it seams as if it doesn't clip in as such. On the 205 with the 1.6 BE3 box it was a case of clipping it home. I imagine that's where the lining up of it comes in, to get the fork behind the bearing.
    There was already a nice green paint line on the arm and top of the fork from when it's been done in the past which may help. Easier said than done with that weight being manouvered at the same time.
  • Posted 19th Apr 2012 at 09:52
    daver6
    How did the fork bearing go?
    Wishbone Polybushes available
    Posted 19th Dec 2012 at 21:05
    I believe he managed it fine. Yes
    Posted 20th Dec 2012 at 07:49
    Went on first time actually. Fitted the fork bushes and looked at how much movement the arm gave the fork and put it at the angle required for it to push past it. Was lucky not to knock it out of line.
  • Posted 20th Dec 2012 at 08:38
    i've got all this to do when i finally whack my box on. it's just sat there doing nothing, all the hard work is done but i just can't be arsed doing it. aside from greasing the splines i wasn't sure the procedure with the release bearing and connecting it to the fork and in what order really. guess it'll make sense when i attach the clutch to the engine and go from there. guess it's a case of just keeping the bearing straight and the arm in place Unsure i put a 2nd hand box on my old 306 and never even had a problem at all, can't honestly remember how it worked considering it all went together first time lucky and i did it in an enormous rush
    Posted 20th Dec 2012 at 08:44
