Author Subject: Ph2 seats in ph3
I'm looking to put some ph2 seats in my ph3. The current seats have air bags. Replacements don't.
Now that is going to throw the light up. Is it the same old story as with removing the steering wheel airbag when fitting an aftermarket wheel, or is it a different ball game? With the new MOT rulings I'm not sure what differnce it makes with the seat situation.
I've had ph2s with air bag seats, not sure if they were retrofitted by someone due to the wear situation, or if it's just luck of the draw having being '98s and perhaps bein the first to have air bag seats.
  • Posted 7th Apr 2012 at 17:28
    anth
    Are you asking if your going to get stung because you will no longer have seat airbags?
    If so i would say its extremely unlikely they would even notice. I believe it now fails for the light being on though, take the bulb out..
    Posted 7th Apr 2012 at 17:55
    6waysforward
    I'm pretty sure the new mots will be doing electrical check so they will know if you have removed the bulb.
    If your old seats are fubard then take the airbags out and come mot day, plug them in and wedge them under the seats, or extent the wires and chuck them in the boot.
    Posted 7th Apr 2012 at 18:01
    anth
    Or put a resistor in the circuit would be the other alternative. See what happens I guess
    Posted 7th Apr 2012 at 18:08
    billyboy99
    I'm hoping to do the same but with ph.1 seats...would the same as above apply, or slight differences in ph1 and ph2 set ups?
    Posted 7th Apr 2012 at 18:16
    tom275
    I did this, and just pulled the led out!
    Posted 26th Apr 2012 at 10:59
    Good luck getting through your next MOT. The light needs to illuminate and go out as it is now part of the test.
    I found that the seats I got were airbag units, so didn't need to worry about this in the end.
  • Posted 26th Apr 2012 at 11:01
    what LED?
    Posted 26th Apr 2012 at 11:07
    milkyb
    could use a 1.8 fused ohm resistor as this thread suggests.
    Posted 26th Apr 2012 at 11:13
    what LED?
    i think he just means the bulb that fits in behind the dash for the airbag
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 26th Apr 2012 at 11:16
