displaying posts 1 to 25 of 33
Author Subject: GE quickshift review
billyboy99
sh1t
Posted 28th Mar 2012 at 17:37
darzmat
that is the most accurate review of anything on this site.
it is indeed, mine is in my door pocket.
worked for a couple weeks but then started slipping round the rod.
Posted 28th Mar 2012 at 17:53
marco gti6
billyboy99 wrote:
sh1t
Is it the same design as the ones Pug1off sells? If so i guess i won't even bother putting mine on. Unsure
Posted 28th Mar 2012 at 17:56
Of you look back to like 2009 people raved about them
Posted 28th Mar 2012 at 17:57
darzmat
ye but they changed the design slightly and they are just w**k now
Posted 28th Mar 2012 at 18:00
pete_rallye
They used to be ok when they clamped over the ball and came with a new gear rod attached, although mine still broke and I had to weld it up, but that was after a considerable amount of track work. New one's look a bit pants though.
Lap of the 'ring
billyboy99
This is the second best assessment of this product, the first being 'its s**t'.
Posted 28th Mar 2012 at 18:13
miles
How can you expect a plain a plain shaft not to rotate on a plain clamp with a s**tty small bolt to hold it in place, But for £20.00 what can you expect really
www.pugracing.com
Posted 29th Mar 2012 at 00:20
Nail + Head there...Yes
If you want a 'proper' quickshift that will last you will have to pay a lot more than £20.00. You get what you pay for these days for sure...
Posted 29th Mar 2012 at 07:32
tommy_306
Slightly off topic, but I bought a GE quickshift in '04 for my 306 xs, I've recently found it when I was clearing out the garage. Would this work on my rallye? And is it a worth while mod?
MY RALLYE PROJECT
Posted 29th Mar 2012 at 07:46
anth
Compbrake is the one you want to go for. Was brilliant and it replaces a worn part in the process.
Posted 29th Mar 2012 at 08:14
mine's got one and it hasn't slipped..
Posted 29th Mar 2012 at 08:25
You guys are all doing something wrong, I put mine on two years ago and have done nothing but cane it into gear on track ever since, it's never even slipped.
Pull up your big girl's panties and MTFU. Even if mine did slip, I'd just remove the bolt, drill a hole straight through and put a new stronger bolt through.
Posted 29th Mar 2012 at 08:29
eddy_gti6
I have had a few of these now. Had one on my old 106 gti, one on my old 306 gti6 and i now have one on my current 306 gti6 and never had a problem with them slipping. I would say its £20 well spent if you put it on right! Just make sure you clean the gearbox arm and make sure the short shift is straight and tight then you shouldnt have a problem.
Posted 29th Mar 2012 at 08:37
manthos
Never had a problem fitted years ago and use it hard. When i fitted it i used a file on the rod and hole in the quickshift to get better contact and put it on with some locktight.
Team SUPERCHARGED
Old Project thread
Posted 29th Mar 2012 at 09:02
billyboy99
alot of worms coming out of woodworks. before i went with the GE one, past threads suggested its the best £20 ill ever spend.
A 'mechnanic' fitted this twice and each time there was no significant throw shortening apart from third gear. My previous Spoox one was much better, significantly shorter throws.
Posted 29th Mar 2012 at 09:31
He fitted it wrongly then, needs to be lower down the selector.
Posted 29th Mar 2012 at 09:33
anth
You need to move it further down the selector arm if the throw isnt short enough.
billyboy99
...thats what i told him but he was wearing overalls and i wasnt...so i wasnt going to argue...
TBC...
Posted 29th Mar 2012 at 09:54
I'm not sure this person was a mechanic.
Posted 29th Mar 2012 at 09:55
fletch
Track Head
I'm not sure why they ever bothered to change the original design, It worked well enough and never slipped.
Posted 29th Mar 2012 at 11:42
simonjames
I think i have 1 of these on the Tango (original design) anyone interested in it if i get it off ?
MY EBAY ITEMS
07943066306
Posted 29th Mar 2012 at 11:44
jeffers Forum Admin
^^ This! If you clean the arm properly, and push quick shift down the arm til it's tight then tighten it properly it shouldn't slip and will shorten the throw. I've had one of the newer design ones on my track car for about 2 years and seven trackdays, it's stood up to some hammer and not slipped. I would suggest replacing the monkey in overalls with someone worthy of wielding a spanner! Roll eyes
Team Running Engine again!
Team Negative Camber!
Posted 29th Mar 2012 at 11:46
I've got an old design one under my sofa. Offers?
  • Posted 29th Mar 2012 at 11:56
    simonjames
    Does help for quicker channel changes ?
    MY EBAY ITEMS
    07943066306
    Posted 29th Mar 2012 at 12:02
