I bought it at 88k from Carl 12th September 2010 and loved it since. Still puts a huge smile on my face, however the suspension has now seen much better days, and now im no longer a student I can treat it a bit.
Here it is as it was when i got it. Since then its had GTI-6 badges on the doors, I've used plastic polish to sort the crystals out and its had new (albeit depo) fogs.
I've done quite a few little jobs to it, New fuel 90 degree pipe (My least favourite 3-4 hours of my life), Attempted and failed fitting the hybrid arb as the tear shape part of the beam was properly fused to the old arb.
Fitted a Crank pulley (Lightened one form rich_w)
The new fogs as said (WHICH WAS A PAIN)
New aerial and base
Bought a new 6 gear nob to freshen up the interior and made myself chocks for the upper mount.
New injector seals
Serviced it several times with Fuchs oil
New radiator mounts
A few new sensors and electrical bits
Fitted Peugeot tweeters in the mirror blanks
Nothing major just many little jobs.
However now im starting to accumulate the stuff I need to completely rebuild the suspension front and back.
As it stands its only going to be left with the uprights and front arb and bushes.
The set up will be as follows
Bits i've got:
New peugeot Top Mounts and bearings
New 79mm bumpstops
New dustcovers for shocks
New Peugeot 306 estate/xsara vts torsion bars (On Back order coming from france monday)
Hybrid arb
Baker BM mounts
Phillip M strut brace
C2R2 Brake adaptors and bolts
Bits I need to get (Trying to get genuine peugeot where I can but if not then lemforder with regards to mushes etc)
Most likely a Bilstein B12 pro kit (Inculdes front B8s and rear b6's with eibach -30mm springs)
A new /Refurbed beam built with the above TB's, mounts and ARB
Peugeot Wishbone bushes (Likely to be the Partner van alloy type) and ball joints (Lemforder)
Lemforder droplinks pending price of genuine.
New track rod ends and rods (Lemforder)
Thought I would freshen up the spoiler with the plastidip I bought the other day,
while i was there I coated the mounts a few times too as well as the hybrid arb.
Before:
After:
Arb and mounts:
Mounts upclose:
everything i have at the mo for my new Struts
C2R2 brake adaptors:
Wont be using those for a little while though
Cheers to Carl and all for the advice on swapping the locks.
I LIVE FOR THE 306
