FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE.
| Author | Subject: 306 gti rebuilt axles |
jord294
Post #101
Will sort it tomorrow pal ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #102
![]() ![]() currently set at -30mm, but will adjust if needed for buyer ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #103
How much to swap it over onto my derv ? |
jord294
Post #104
bigbadbowen wrote: How much to swap it over onto my derv ? if your dirty diesel has discs, then standard fitting fee of £140 applies, and usually done within 4 hours ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #105
revised pricei have a freshly rebuilt axle sitting here in my garage. was built for a forum member, who sadly has had circumstances change to suit 306 without brake compensator (but can easily change to suit earlier cars), 20mm torsion bars and lowered 30mm (again, easily changed for buyer) and ready to bolt straight on genuine bearings and seals, along with genuine mounts. only the trailing arms that have not been powdercoated. £400 inc px please ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #106
still available________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #107
bump ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #108
SOLD ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
Post #109
Are you still doing these beams Andy? Check your PM's, I'd like a refurb for my P1 if you are. ![]() ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
jord294
Post #110
Another week or so before I start again with axles.Need to get 405 finished, so I can free up garage ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #111
I'm back building axles again, now I have garage space again ![]() If interested, you know where I am. Cheers ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
nadine
Senior User Location: Dunfermline Registered: 02 Mar 2008 Posts: 525 Status: Offline |
Post #112
Do you refurb beams and post them? |
jord294
Post #113
nadine wrote: Do you refurb beams and post them? As stated in first post, collection preferred, but you're welcome to arrange a courier yourself. You'll just need to pay extra for cost of a pallet and packaging. ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #114
Big Thank-you Andy the axle you did for me ...its a work of art m8 !I'm really fussy & I can't believe the Quality & workmanship you put in .... And your a friendly Nice bloke ....which is few & far between now a days Can't wait to fit it next week ..... Thanks again . |
jord294
Post #115
for anyone interested, i can build a 306 gti beam using citroen zx 16v armscheers ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #116
where did you find those? any other bits from where that came from? ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
Post #117
welshpug! wrote: where did you find those? any other bits from where that came from? ![]() i took the axle as px recently, and was told it came off a pug. but something didn't ring true ![]() so i've just spent the last hour on both citroen and peugeot servicebox doing a process of elimination. all i have is the axle. if i had access to zx 16v bits, you'd be the first person i'd let know ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Post #118
ahh no worries thanks ![]() guess it has those bolted on bumpstop spacers. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jord294
Post #119
welshpug! wrote: ahh no worries thanks ![]() guess it has those bolted on bumpstop spacers. it does. ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
Post #120
f.a.o walker_texas_ranger and castor_troyyour uprated beams are ready ![]() ![]() ![]() cheers ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
Castor_Troy
Regular Location: Forfar Registered: 25 Jul 2013 Posts: 282 Status: Offline |
walker_texasranger
Seasoned Pro Location: Sunny Retford Registered: 26 Jan 2008 Posts: 2,502 Status: Offline |
Post #122
![]() Cant wait to collect this bad boy!!! ________________________________________ Almost standard 1999 Bianca RallyeHilux InvincibleX daily 306 No.13 ![]() Carp and specialist Anglers Click here |
russbez
Post #123
very smart looking!!________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
walker_texasranger
Post #124
After making the two hour journey from Sheffield last night to collect my beam, I can confirm the following:Andy does indeed have the fluffiest cat ever (fact) His beams look that good that you actually consider framing them instead of fitting them. Really can't wait to got it fitted next week, if they perform as well as they look then it's gonna be awesome ![]() ![]() ![]() ________________________________________ Almost standard 1999 Bianca RallyeHilux InvincibleX daily 306 No.13 ![]() Carp and specialist Anglers Click here |
jammapic
Senior User Location: Manchester Registered: 11 Jun 2010 Posts: 778 Status: Offline |
Post #125
No piccies of the fluffy cat? ![]() ________________________________________ HDI Engine Tuning / Remapping Services - https://www.facebook.com/dervtech306 GTi-6 Track Car - 200+ hp all N/A! 306 DTurbo Track beasty - 209.9hp - RIP |
