displaying posts 401 to 425 of 436
Pages (18): first .. 16 [17] 18
Author Subject: Group buy feeler - Colin Satchel 'satchshift'
Puggitt
Post #401
it stiffens the shell a fair bit, I'd leave it there tbh.
But if you've got a full cage that would make it less required?
Posted 28th Mar 2015 at 07:02
Post #402
pugheaven wrote:
I don't have the forward gears sorted never mind reverse lol
Come on Ollie get it sorted ....a walk in the park for you Whistle
Great Pics ...keep them coming Thumbs up
Posted 28th Mar 2015 at 07:58
Chr1sch
Post #403
Bloody hell I need one of these! I'm on the waiting list but I'm nowhere near technically competent enough to fit it :-s
Also looks like it could be a total b**ch with the dash etc in?
Posted 28th Mar 2015 at 09:16
pugheaven
Post #404
I can't see how you would cut the hole with the dash/heater in but apparently it can be done!
Iv only had an hour on it each day due to working late shift, should get it sorted today
Posted 28th Mar 2015 at 10:08
3rd time lucky
Post #405
I just had my dash put back in! I wont get the dash taken out for this just yet. My engine will be coming out in a couple of weeks though, maybe we can cut the hole through the bulkhead with the engine out...
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 28th Mar 2015 at 10:14
pugheaven
Post #406
They suggest to do it from the under side anyway.... However were is the drill bit going to go when it goes through....
I haven't put my heater box back in yet but I can imagine it's going to be pretty close
Posted 28th Mar 2015 at 10:20
Post #407
Any up date Ollie ?
Mines coming from Kam next Tuesday Thumbs up
I'm dreading fitting it Thumbs down
I'm not taking my dash out Whistle
Posted 31st Mar 2015 at 20:08
Chr1sch
Post #408
Can i ask a simple question and an honest answer pls... (directed at those who have fitted/are fitting this)
I'm an average mechanic at best, my engine is in, my heater is in and my dash is in - do I have a hope in hell of fitting this by myself?
Posted 31st Mar 2015 at 20:33
Post #409
Can't see why not, its got a fair element of DIY rather than pure mechanical work Big grin
not had a chance to try mine yet!
Posted 31st Mar 2015 at 20:48
Chr1sch
Post #410
sod it i just want one so much its insane, i'll worry about welding the bloody thing back together at a later date lol
Posted 31st Mar 2015 at 20:53
pugheaven
Post #411
Now I know what I know for example what goes where it's a pretty easy job, I can't see it being that easy to do with the dash and heater in tho! You will either stick the drill bit/hole cutter/ cone cutter into the heater unit once you have gone through the bulk head!
I'll take a picture with a standard heater unit in tomorrow and you can make your own mind up what you think!
I personally think you make a much neater job with the dash and heater out!
My engine and box were fitted
Posted 31st Mar 2015 at 21:32
Post #412
Ollie you got time to do mine ?....money involved Whistle
We can try with the heater & dash in then ?
Posted 31st Mar 2015 at 22:50
pugheaven
Post #413
I would love to see someone do it with the heater out in....
God knows how Dave/Collin did it! The tube that bolts to the bulkhead has two bolts and two nuts securing it to the bulk head, how they did the nuts up is beyond me!
It was hard enough with the dash and heater out lol.
Trying to get the nuts on with out dropping them and them disappearing down in between the 2 skins took a few attempts Sad
The only way would to use rivnuts from the underneath it then the tube assembly would sit away from the bulkhead
I'm willing to be proved wrong but for the sake of taking the dash and heater out and doing a much better and tidied job I know what I would do if doing it again
Posted 1st Apr 2015 at 05:52
Post #414
Ollie any more pics ?
Did you have to cut anything to Remove the lower heater unit which you didn't put back in ?
You said all you will have is screen heater now ?
Any pics you can take of it now fitted underneath at the front & back would be great Ollie Thumbs up
Posted 1st Apr 2015 at 07:15
pugheaven
Post #415
Pics in my project thread, na all the bits I removed from the heater are busted screwed in or clips! Just make some blanks to cover the old ducts and that's it
Posted 1st Apr 2015 at 07:19
pugheaven
Post #416
I will do a brief fitting guide tonight if I get time
Posted 1st Apr 2015 at 07:21
Post #417
hmm, countersunk rivnuts? might not be thick enough panel though, tiger seal ftw Big grin
the matrix is on the opposite side so if you do manage to make a mess you wont get coolsnt everywhere.
probably need to go in from underneath I think, as the manifold and coolant pipes are in the way from above.
Posted 1st Apr 2015 at 07:22
pugheaven
Post #418
Yup countersunk rivnuts would do the job!
For the sake of an extra 30mins to an hour I would just take the dash out!
I didn't have much faith in the template so I just drilled a 30mm hole in the middle of the template, put the bulkhead tube in place with the plastic grommet from the end of the boot taped into the metal tube, put the push rod through and connected it both ends.
This finds the dead centre of the tube and the natural position for the tube, I then bolted it to the bulkhead, took the push rod out and then ground away from the inside until it was opened up to the internal bore of the tube!
No being on my back with a sore neck and getting covered in swarf
Hope the above method makes sence
Posted 1st Apr 2015 at 07:42
Post #419
Please Ollie Thumbs up
Sorry but NO Way am I going to take my dash out !!!!
Well maybe if I can't do it any other way Maybe Crazy
Posted 1st Apr 2015 at 09:21
Chr1sch
Post #420
Yeah Im in the same position, a guide would be bloody brilliant!
Posted 1st Apr 2015 at 14:43
Chr1sch
Post #421
Spoke to Kam racing and they reckon they'll be wih them mid-next week...not long :-)
Posted 1st Apr 2015 at 17:58
Post #422
Yep & only two out of the second lot of 8 left ?
He said mine should be here by Weds / Thursday ?Thumbs up
Ollie PLEASE a step by step xxxxxxxx ASAP ....Thumbs up
Posted 2nd Apr 2015 at 07:31
Chr1sch
Post #423
So what is everyone planning to do regarding the removal of the heat shielding? I often drive for a good hour plus to a track day and do a fair few laps so it gets damn hot....
Posted 3rd Apr 2015 at 22:11
Chr1sch
Post #424
Anyone?
Posted 7th Apr 2015 at 16:59
pugheaven
Post #425
You can either fit exhaust wrap or by fitting heat proof material to the tunnel
Posted 7th Apr 2015 at 18:52
