displaying posts 376 to 400 of 436
Pages (18): first .. 15 [16] 17 .. last
Author Subject: Group buy feeler - Colin Satchel 'satchshift'
Post #376
pugheaven wrote:
Got 70% of the satchshift in this morning with a few helpful hints from Colin and Dave!
The heat shields do have to be removed though unfortunately
Once iv got it fully fitted I'll do a guide
That would be excellant if you can !!!
If the heat shield has to come off ....I've got a stainless Exhaust ....that means I'm going to have to wrap it then ?....
Posted 25th Mar 2015 at 18:21
pugheaven
Post #377
I'm just going to get some heat proof tape and line my tunnel with that, never been a fan of the wrap!
maybe if the heat shields were re-shaped it might allow enough room but I couldn't be arsed to mess around
Posted 26th Mar 2015 at 00:40
pugheaven
Post #378
I'll measure the gap tomorrow between the rod and the tunnel but it's probably around 5mm and the standard heat shields sit around 10-15mm away from the tunnel
Posted 25th Mar 2015 at 18:25
Post #379
Some re-snapping of the heat shields might allow enough room but I couldn't be arsed to mess around
Good man Oliver Thumbs up ....keep the photos & updates coming ...
Hopefully mines coming soon Thumbs up
Posted 25th Mar 2015 at 19:40
Post #380
ahh so this is how this bit goes then?
and the stays here need turning over and placing under the bellcrank?
Posted 25th Mar 2015 at 20:09
Cjwatson27
Post #381
Haha should of gone to spec savers
Posted 25th Mar 2015 at 20:20
pugheaven
Post #382
First pic is correct, second one the stays need to go under the bell crank, the one with the wider slotted hole needs to point downwards (goes to the old pivot post) the one with the thinner diameter slotted hole needs to face up so it bolts to the heat shield stud on the passanger side
I'll take pics tomorrow as I'm at work at the min
Posted 26th Mar 2015 at 00:42
Post #383
mint Thumbs up
Posted 25th Mar 2015 at 20:24
pugheaven
Post #384
And it's the elongated right hand hole that is used to bolt the pivot post to the pass side rack mount
Posted 25th Mar 2015 at 20:32
pugheaven
Post #385
Setting up the satchshift is nearly as bad as adjusting all these....
Posted 25th Mar 2015 at 20:39
pugheaven
Post #386
I added an extra washer to the pivot set up so I had one ontop of the stays/ under the bell crank and one between the top of the bell crank and head of the bolt
Posted 25th Mar 2015 at 20:43
Post #387
PMSL Thumbs up
Posted 25th Mar 2015 at 20:44
pugheaven
Post #388
Bit more to go wrong if those are set up wrong tho lol hate doing flying controls they suck donkey dick
Posted 25th Mar 2015 at 20:51
Post #389
What's that on?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Mar 2015 at 21:25
pugheaven
Post #390
Chinook
Posted 25th Mar 2015 at 21:58
pugheaven
Post #391
c**ts at work think they are funny
Posted 25th Mar 2015 at 22:00
Post #392
Laugh
Posted 25th Mar 2015 at 22:12
Post #393
Now that's funny LOL
I'm hoping Mei will sort his out soon & I can pop over the bridge & pay him some dosh to sort mine Whistle
Pretty please Mei !!!!
Posted 25th Mar 2015 at 22:40
pugheaven
Post #394
It's pretty straight forward once the bits are in the correct position
Posted 25th Mar 2015 at 22:57
jorg
Post #395
has anyone else received one yet?
306 2.1 S16 Tarmac Rally Car
Posted 26th Mar 2015 at 08:55
pugheaven
Post #396
Nearly finished, got to go to work now but will have it done tomorrow
Posted 27th Mar 2015 at 12:26
Puggitt
Post #397
Do you if you can remove that second skin over the exhaust tunnel? Withou causing too many issues (other than heat obv)
Posted 27th Mar 2015 at 20:33
Post #398
it stiffens the shell a fair bit, I'd leave it there tbh.
Posted 27th Mar 2015 at 20:41
Post #399
Looking good Ollie Thumbs up
Please keep us updated !
Where's the reverse slider ?
Posted 27th Mar 2015 at 20:51
pugheaven
Post #400
I don't have the forward gears sorted never mind reverse lol
Posted 27th Mar 2015 at 22:34
