Author Subject: ID a pipe on D Turbo 1.9 Phaze II XUD
kewl_sol
Hi guys need some help, just bought my first 1.9 Diesil Turbo XUD Phaze II and am trouble shooting around the engine bay have found a couple of pipes needing help with.
1. Clearish (when not dirty) pipe coming of what i think is the fuel filter ? it just hangs down by the gearbox and im sure it should attatch to sumthink ?
Pipe down center of screen
2. Behind the Battery (back right hand sie of engine bay) i have found a snapped off pipe quite small but is attached (or was) to a kind of sensor by the looks of it with a green plug on it, pipe runs parallel with another under the intercooler, the other pipe is attached to the top half of the place it has snapped off, any help is appreciated thanks
Posted 18th Feb 2012 at 18:34
Welcome mate Wave
Sadly there aren't alot of diesel owners on this site as its intended audience is GTI-6's and Rallyes.maybe worth popping over to pug306.net as theres far mor diesel owners on there
Ash Smile
Posted 18th Feb 2012 at 18:37
matt evans
Top one is i think the water drain off pipe from the fuel filter housing. (going from memory when i had a 406 1.9 DT)
As for the second one, no idea.
honestly3k wrote:
owain wrote:
Posted 18th Feb 2012 at 18:50
kewl_sol
cheers for the help ill post on pug306.net too cheers guys
Posted 18th Feb 2012 at 18:58
judge dead
it looks slightly similar setup a transit has and its a vacume pipe on 2nd picture
Posted 18th Feb 2012 at 19:03
ash23
second pik is the egr vac pipe just block it up with a bolt thats what most of us xud owners do
Posted 18th Feb 2012 at 19:14
First pic is definitely of the water drain hose from the fuel filter. Yes
As stated, Pug306.net has a vast range of knowledge on the diesel side of the 306's so try over there and I'm sure you will get a suitable answer. Smile
Posted 18th Feb 2012 at 19:16
kewl_sol
okies done some research and this and apparently to plug this would add to performace as it were by bypassing the recirculation in the system - also a BAD idea from what i read thanks for the help guys will fix up now i know what it is thanks
Posted 18th Feb 2012 at 19:27
ruan
The second picture is the EGR solenoid valve... Repair those pipes, or at least block off each side of it, as at part throttle it'll open your brake vacuum pump to atmosphere, losing your brake vacuum...
So either pull off both pipes and bung them (woodscrew up the end of the pipe...) and it'll disable the EGR whilst you're at it or repair it and unplug the green connector.
And yeah, first is the water drain for the filter housing, perfectly normal.
Posted 22nd Feb 2012 at 14:27
