displaying posts 76 to 100 of 167
Pages (7): first .. 3 [4] 5 .. last
Author Subject: Bridgecraft Engineering Services and Products
allanallen
Post #76
As I say the kit will be supplied with new track rods as well as rose jointed track rod ends.
Cheers, Al
Facebook
Posted 2nd Mar 2014 at 20:51
pete_rallye
Post #77
That's how they are done on the touring cars also. Has the added benefit of allowing you to adjust toe settings from the large thread into the track rods rather than on the rose joint. Never noticed that my track rods had been shortened though but you've got me wondering now!
Lap of the 'ring
Posted 2nd Mar 2014 at 22:32
allanallen
Post #78
I would imagine they have been shortened Pete.
I've not forgotten about your rods either buddy, been waiting on someone to get me a quote.
Facebook
Posted 3rd Mar 2014 at 05:52
pete_rallye
Post #79
My track rods are standard length, not shortened but the adjuster piece is much shorter than yours. The rose joint is uses is pretty small as well!
Think I've found someone here to do my rods but let us know anyway in case it falls through! Cheers.
Lap of the 'ring
Posted 3rd Mar 2014 at 20:33
allanallen
Post #80
Yeah the touring cars use tiny joints! Aren't the BBJ Jose joints 1/2 inch?! The adjusters I pictured are for a widetrack 306 hence them being huge! Just used the pic as an example.
I'll let you know about the rods tomorrow buddy Wink
Facebook
Posted 3rd Mar 2014 at 23:05
morbidio
Post #81
What's the size of the EN24T sleeved spacer?
Peugeot 306 Dimma Coupe N/A -95
Posted 4th Mar 2014 at 18:58
allanallen
Post #82
I'm guessing you mean the length? It gives 30mm of correction although it's obviously longer than that to take into account the size difference between a standard TRE and the rose joint
Facebook
Posted 4th Mar 2014 at 19:47
morbidio
Post #83
Of course! So 30 mm above the front hub if I understand you correctly?
Posted 4th Mar 2014 at 20:05
allanallen
Post #84
No, it offers 30mm of correction. The track rod will sit around 45mm below the hub.
Facebook
Posted 4th Mar 2014 at 20:21
morbidio
Post #85
I think we're thinking the same but write different. The spacer is 30 mm in length above the hub and that makes the rod about 45 mm below the hub.
Correct? Razz
Posted 4th Mar 2014 at 21:53
allanallen
Post #86
Correct? Razz
Not sure what's above the hub? Do you mean above the bottom ball joint?
This is a 406 hub and the spacer is slightly shorter but it gives you an idea
Facebook
Posted 5th Mar 2014 at 05:28
hediis
Post #87
allanallen wrote:
I'll look it out for you when I get to work tomorrow.
Ride height is set at around -40 it's with the arm level ie; the stub axle and trailing arm arm pin at the same height.
Did you get a figure?
Peugeot 306 GTi-6 -97 (Ph1, blaze) Low n slow
Peugeot 306 GTi-6 -97 (Ph1, blaze) Trackday car, 226hp N/A (Engine rebuild right now)
Peugeot 306 GTi-6 -00 (Ph3, black) Low n slow
Posted 28th Mar 2014 at 14:47
allanallen
Post #88
Hi, sorry the original arms are -3degrees and 20mins toe in.
Cheers, Allan
Facebook
Posted 28th Mar 2014 at 16:39
calibra306
Post #89
allanallen wrote:
We'll also shortly have a bumpsteer reduction kit available. Again this will require your hubs accurately drilling/boring out to accept a sleeved spacers, the kit will come complete with new shorter track rods as well as an extended rose joints to replace the track rod end. Price is TBA
Cheers, Al
Any new on these please?
V6 Power!
Faster I can go the better!
Posted 31st Aug 2014 at 23:15
allanallen
Post #90
Ive not been rushing as there's very little interest in them but I'd like to do them anyway. I've now got a 306 in my possession so once I find some time I will get the gauges on it and see about producing a generic kit. I'll post up as soon as there's any progress.
Facebook
Posted 1st Sep 2014 at 08:50
demondriverdan
Post #91
Also interested. If you need anything from me, let me know Smile
Rallye Race Car
Posted 1st Sep 2014 at 08:52
calibra306
Post #92
Bump kit interest list.
1. Calibra306 (18mm)
2. Demondriverdan
V6 Power!
Posted 1st Sep 2014 at 11:37
calibra306
Post #93
After roll center kit also. Is that what you call them ie spacers for lowered cars to adjust wishbones back.to a reasonable angle. mine may not need them as mine is a V6 and although lowered (not sure by how much as done by previous owner) my subframe is also lowered for the conversion so surely this would bring the angle of the wishbones back to a normal angle? Ish
V6 Power!
Posted 1st Sep 2014 at 11:44
allanallen
Post #94
Lowering the subframe will make things worse, you've moved the pivots down so it acts like it's been lowered even more. You really want to look at moving it back up.
There's no simple bolt on method of sorting the roll centre, you end up needing custom wishbones/shafts etc like the satchell kit so it gets very expensive.
Facebook
Posted 1st Sep 2014 at 12:08
calibra306
Post #95
Subframe cant be raised as its a V6 Converted 306 so no room to raise.
V6 Power!
Posted 1st Sep 2014 at 16:52
allanallen
Post #96
Can you not modify the subframe like in the 205 conversions?
Facebook
Posted 1st Sep 2014 at 19:39
calibra306
Post #97
How is thats?
V6 Power!
Posted 1st Sep 2014 at 20:38
allanallen
Post #98
Chop bits out where it doesn't clear!? Obviously it needs strengthening in the necessary places where material is removed.
Lowering the subframe is a terrible idea IMO
Facebook
Posted 1st Sep 2014 at 21:34
Post #99
subframe is lowered a little in a 205 conversion too, the CV joints pass right over the front wishbone bush mounting point, there isn't any way around it other than mounting the engine higher in the engine bay, which isn't possible as its not a short engine.
Posted 1st Sep 2014 at 21:51
allanallen
Post #100
The 205 v6 I've seen didn't have a lowered subframe. Perhaps the engine was slightly higher or tilted? Maybe even different cv inner?
Calibra, how much is it lowered?
Facebook
Posted 2nd Sep 2014 at 06:20
