displaying posts 51 to 75 of 125
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Sleeper 306T - 316 wheel bhp
nadium
Post #51
maybe soon a video mate, ?
Posted 12th Feb 2012 at 14:20
marco gti6
Post #52
Nice setup! :thumsup
Posted 12th Feb 2012 at 15:04
arigti6
Post #53
Awesome stuff. What is it running @ the wheels, 230-250hp?
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 16th Feb 2012 at 22:38
FatBastard
Post #54
I dont know, we used a dyna pack (where you remove the wheels and connect the dyno directly). Normally crank power lose 10-15%. I dont know how its calculated with dyna pack
Posted 17th Feb 2012 at 21:51
nadium
Post #55
hello mate. could you please take a pic what u did with the space between manifold/turbo and the termostatwater-outlet? and the hoses for the heatermatrix Big grin
Posted 1st May 2012 at 10:48
Post #56
Well done is all I can say Smile
Posted 1st May 2012 at 11:00
Post #57
What does the throttle body go up to? Do the HB S/C guys still use the standard one?
Yes, we sure do. Yes
Posted 4th May 2012 at 08:50
fatlapit
Post #58
Its 3" so more than enough
Posted 4th May 2012 at 09:00
birk
Post #59
I dont, but then again, i supose i will be classed as super high boost at 2bar Ninja
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 4th May 2012 at 09:02
fatlapit
Post #60
Mental birk
Posted 4th May 2012 at 09:22
FatBastard
Post #61
Sorry for the lack of updates.
first of all. The gear was assembled. 1st and 2nd gears are from a 205 GTI.
3rd, 4th and 5th are from 405.
I used my original final drive.
The gears are great. Been driving with it for 3 months.
I also changed the fuel pump to Walbro 255. This enabled me to remove a lot of fuel during boost, that was compensating for pressure drop.
Still, injectors should be replaced with bigger ones, if i want to increase boost.
Next steps:
1. Replace the MAT sensor with a faster reacting one, since the orig cannot coop with fast temp changes.
2. Install the AEM boost controller.
3. Replace the injectors to RC 750cc and change the fuel pressure reg from 3.5 to 3.0 bar.
4. Re-tune the car with the higher injectors, if needed. increase rev limiter from 6400 to 7000.
Posted 16th May 2012 at 13:00
nadium
Post #62
mate what have you done by the heat where your termostathousing is ?
Posted 16th May 2012 at 16:52
FatBastard
Post #63
All hoses (including the ones behind the manifold) were coated with heat protectors sleeves, you can see 1 of them in the last pics batch, the pic before the destroyed 5th gear.
The material protects up to 1200c direct heat for a short time or 260c constant heat (if i recall correctly). Rather expensive stuff - but mandatory - in my opinion.
http://www.thermotec.com/products/18000-heat-sleeves.html
The downpipe was coated with exhaust wrap, which can withstand 1000c of constant heat.
http://www.thermotec.com/products/11021-exhaust-insulating-wrap-graphite-black.html
The turbine was coated with this:
http://www.thermotec.com/products/11710-micro-louver-air-shield.html
Posted 16th May 2012 at 18:06
lewisdmz
Post #64
Mmm those manifolds look awesome. What colour is the car?
Posted 17th May 2012 at 22:54
FatBastard
Post #65
Sigma Blue. One of the best, in my opinion. Smile
Posted 18th May 2012 at 19:54
playboyb
Post #66
Great project mate, well done.
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 30th May 2012 at 17:08
woody.
Post #67
Really nice mate, always nice to see a turbo conversion. Looks like you're going for it so good on ya Smile
Posted 31st May 2012 at 19:55
FatBastard
Post #68
Original GTI6 vs. slightly modified one...
Posted 3rd Jun 2012 at 00:50
7057sam
Post #69
Love Love Love
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 3rd Jun 2012 at 11:13
FatBastard
Post #70
Update - 440cc ford sport Injectors were replaced with 750cc RC engineering. fuel pressure regulator was replaced from 3.5 bar to 3.0 bar - in order to give less fuel at idle.
I've updated the fuel map and so far it looks good. Idle pulse width is 1.3ms and RPM is around 950-1000.
Also - boost controller was installed. Not configured yet.
When off - 0.65bar (280bhp tested on dyno)
option A - 1.0bar (hopefully around 310 bhp)
option B - 1.3 bar (hopefully around 350 bhp)
Next stage is a faster responding MAT sensor and dyno tuning.
Posted 10th Jun 2012 at 16:35
manthos
Post #71
VERY NICE!! looks fantastic. Are you coming to Pugfest i think there is a group that come from your way.
Team SUPERCHARGED
Old Project thread
Posted 11th Jun 2012 at 18:56
Kyle
Post #72
Any updates to this Fatbas**rd? Smile
Posted 27th Sep 2012 at 12:30
FatBastard
Post #73
Not much, actually, since I am abroad and returning next month. I had to replace the oil hoses from the cooler since they started leaking due to bad pressing. Now the new hoses are metal ones. Hopefully they'll hold.
Posted 27th Sep 2012 at 22:25
Post #74
If you ever get around to flow testing your exhaust manifold it would be very interesting to see how much more restrictive it is than standard. With all those tight radius bends flow loss will be terrible and I think its going to give your exhaust valves such a hard time as it won't let the hot gasses out anything like fast enough, this will also have a huge effect on turbo lag as the gas just wont be going fast enough to spool it up quickly.
Posted 29th Sep 2012 at 14:12
FatBastard
Post #75
The car is already running.
Turbo lag can go up to 1 second if I push the pedal to the metal at 3500 rpm.
Lag when shifting gears during boost is very low, less then half a second.
The manifold was designed and tested by dp-engineering. They use this design on many car they modify. Surely it is somewhat restrictive, but it was designed tgat way to have equeal runners.
Posted 29th Sep 2012 at 19:48
