I have for sale a Rotrex C38 series supercharger fitting kit to suit the 2.0 16V XU engines. It was uneconomical to just get 1 off parts manufactured for Andy Rawson’s impressive conversion, so I had to increase the quantities of the parts to make it financially viable, given the machine set-up and tooling costs are substantial. This is essentially a spare set of parts I had made at the same time.
This kit differs considerably to the C30-94 fitting kit you may have seen previously.
Besides having a different S/C mounting bracket to suit the larger family of superchargers, it includes all the components required to change the entire auxiliary drive system from a 6 rib micro-v belt to an 8 rib micro-v belt. It is also designed to run with an aftermarket ECU, rather than the OEM ECU (we favour DTA). This means it’s designed as a conventional blow-through arrangement with the throttle body located on the inlet manifold (not on the inlet of the S/C). This set-up will require the use of a re-circulating dump valve and externally mounted MAP sensor (we use the Marelli / Cosworth 3 BAR sensors). A vacuum hose take-off is provided on the inlet manifold for this purpose.
The kit also contains a WRC style inlet restrictor / diffuser arrangement to control power, which was designed with some fluid dynamics input from Wayne Schofield. The restrictor / diffuser has been designed so the air-flow is not strangled until it reaches (or becomes very close to) terminal velocity. This means you won’t be restricting or losing power below the point at which it reaches peak power. This type of diffuser / restrictor is a lot more efficient than using a simple square edged aperture, like the restrictor rings we use on the low-boost conversion.
The kit comprises the following:
• Inlet manifold (colour choice / engraving can be completed to your specification)
• S/C bracket to suit Rotrex C38 series superchargers
• Tensioner & guide pulley for the above, to suit the wider 8-rib belt
• 8-rib alternator pulley
• 8 –rib alloy crankshaft pulley
• 8-rib alloy pulley for the OEM auto-tensioner
• Mounting spacers for OEM auto-tensioner (this is to space it out and centre it on the wider 8-rib belt)
• PAS pump complete with 8-rib pulley modification
• PAS pump relocation brackets
• New low and high pressure PAS hoses to suit the new location
• 8-rib S/C drive belt
• Alloy inlet housing for S/C (this houses the inlet air restrictor / diffuser)
• Inlet air restrictor / diffuser
• K&N air filter
• Alloy air scoop
• All nuts, bolts, washers etc.
This kit is £TBC
Photos to follow shortly.
Merry Christmas!
Contact Details:rich@lynxpowerengineering.co.uk
07732 822546
