displaying posts 351 to 375 of 488
Pages (20): first .. 14 [15] 16 .. last
Author Subject: GETTING THERE Fatlapits turbo (turbo frog)
fatlapit
Post #351
So the dyno figures are 310 bhp and 290 torque @ 12psi of boost.
Full boost is at 2200rpm and revs too 7200
Posted 30th Aug 2014 at 01:15
pebbles167
Post #352
Nice! See it on track anytime soon?
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 30th Aug 2014 at 01:29
fatlapit
Post #353
Forge action day
Posted 30th Aug 2014 at 02:31
Post #354
Nice work mate. Thumbs up
Posted 30th Aug 2014 at 11:53
fatlapit
Post #355
Posted 30th Aug 2014 at 12:06
superchargedblack1997gti6
Post #356
Great result Smile
Posted 30th Aug 2014 at 14:22
pebbles167
Post #357
fatlapit wrote:
Forge action day
I'm on 10:30 & 13:30. Catch you there Thumbs up
2008 BMW K1200R
Posted 30th Aug 2014 at 14:46
fatlapit
Post #358
Im on 230
Posted 2nd Sep 2014 at 20:50
Post #359
Any videos of this ?
Posted 27th Oct 2014 at 19:11
fatlapit
Post #360
add me on face book
Posted 27th Oct 2014 at 19:13
fatlapit
Post #361
plenty videos etc. was at forge action day too
Posted 27th Oct 2014 at 19:20
rallyeash
Post #362
Not on FB. Can't you host them?
309 3dr K20 Type R
Posted 27th Oct 2014 at 19:31
fatlapit
Post #363
nope
Posted 27th Oct 2014 at 21:07
pugheaven
Post #364
Iv got you on facecrack and the only vid I've seen is the one on the rollers, tag me in some please
Posted 27th Oct 2014 at 21:09
fatlapit
Post #365
sorry ways ure name please
Posted 27th Oct 2014 at 21:10
pugheaven
Post #366
Oliver Church.... The one with the dimma Thumbs up
Posted 27th Oct 2014 at 21:13
fatlapit
Post #367
ive only got dyno vids
Posted 27th Oct 2014 at 21:22
pugheaven
Post #368
What's wrong with the car then bud? See on Facebook that you said it's broken
Posted 1st Nov 2014 at 22:36
fatlapit
Post #369
ecu wiring. 1 and 4 injectors intermitantly fire. i think the 12v feeds are bust. i had a multimeter on it and getting 12v but i think there is too much resistance. but if u pull on the loom it runs fine if u let go it looses egt and rund like a bag of poo. if you disconnect inj 1 and 4 it makes no differance. i swapped the injectors about n the fault remains. but jims gonna make the rev counter work too.
Posted 1st Nov 2014 at 22:16
pugheaven
Post #370
Teething problems are expected mate at least it's nothing major
Posted 1st Nov 2014 at 22:35
fatlapit
Post #371
aye true still not found alot thats as quick in the corners and straights
Posted 1st Nov 2014 at 23:07
pugheaven
Post #372
That's surprising about the corner statement as I used to have the same rear beam set up as you, kw v2's and decent tyres and didn't think it was that impressive hence why iv tried to sort the dimma out!
Still need corner weight setting up and then its going to be trial and error with ride height, spring rate, camber and toe!
Did you ever sort out why your back end was trying to overtake the front?
Posted 2nd Nov 2014 at 00:08
fatlapit
Post #373
i think its just very light on the rear with poor tyres i may just put standard arms back on
Posted 2nd Nov 2014 at 03:25
Niall
Post #374
What ECU you running and is it intermittent?
I had a similar issue. Turned out the coil for 1 and 4 was stopping when it felt like it. Was just getting ready to send my ecu back to omex for a new ignition driver when i took the plug off and noticed it wasn't clipped in as far as it could be and the pin for coil 1 and 4 had pushed back in the plug slightly. I can only imagine that it was literally just touching and as the car heated up, changed the resistance in the cable giving just too much for that coil to fire.
Posted 2nd Nov 2014 at 09:25
fatlapit
Post #375
its defo injector wiring its had new coil n plugs. we shall see it should be fixed this week
Posted 2nd Nov 2014 at 15:16
