displaying posts 226 to 250 of 488
Pages (20): first .. 9 [10] 11 .. last
Author Subject: GETTING THERE Fatlapits turbo (turbo frog)
Post #226
Is it not a cheap (convincing) replica Chris?
  • Posted 24th Apr 2013 at 15:45
    Post #227
    No idea tbh mate, I'm not very clued up on JDM yooo! Laugh
    Can get some pictures etc up if that helps? Mate seemed happy enough with it, and said was a lot cheaper than buying one from elsewhere.
    Posted 24th Apr 2013 at 15:49
    birk
    Post #228
    I dont like the mushroom ones dude, much prefer the normal style ones, i wont be short on room in front of the turbo.
    Dimma + Gt35 turbo = Ninja
    Solid rear beam mounts £130
    07889376885
    Dan
    Posted 24th Apr 2013 at 16:13
    fatlapit
    Post #229
    Defo a a fake plus i dunno how it can flow enough to produce that much power. plus my filters only rated to 450hp.
    Posted 24th Apr 2013 at 16:48
    Post #230
    fatlapit wrote:
    birk its a b4.80 direct from green it wasnt alot of cash i will find the link
    That looks PROPERLY well done on these photos imo.
    Well done
    Posted 24th Apr 2013 at 18:13
    Takedown
    Post #231
    Hahah mine was nowhere near 20 gbp, must be chinese knockoff, but a airfilter isnt exactly higher science, look it up on youtube: mighty carmods airfilter tests... from expensive to cheap ones.. not very much difference, maybe longevity is a different story.
    Looks great mate!!!!!!!!!! Thumbs up where youre filter is, is my ABSstuff
    Posted 24th Apr 2013 at 22:14
    fatlapit
    Post #232
    I think the abs cuts in early so i took it out
    Posted 24th Apr 2013 at 22:24
    birk
    Post #233
    I've taken mine off as well, but that's where my boost pipe will be going.
    07889376885
    Dan
    Posted 24th Apr 2013 at 22:43
    fatlapit
    Post #234
    So wheres the filter going??
    Posted 24th Apr 2013 at 23:04
    fatlapit
    Post #235
    dan get sum recent pics up
    Posted 25th Apr 2013 at 00:17
    fatlapit
    Post #236
    filters make a lot of difference in a turbo car, for a start Ive seen the foam type ones been sucked inside out, hence why ive got a gauze one. the surface area and neck size is also very important for flow, hence why my filters only rated to 450 hp
    Posted 25th Apr 2013 at 00:20
    birk
    Post #237
    Not much to see really, it's just a bare engine bay in primer.
    I've also taken the fusebox out, my turbo outlet sits right next to it, so my boost pipe will cut across where the fusebox used to be, then go down through where the abs pump used to be to the intercooler.
    The air filter, when I get one, will sit somewhere in front of the turbo, depends what happens with the rad pipes.
    How much did you give for your rad?
    07889376885
    Dan
    Posted 25th Apr 2013 at 08:46
    fatlapit
    Post #238
    £130 I sent u a link last week lol. I would chop the turbo flange off and move her to my orientation tbh
    Posted 25th Apr 2013 at 10:14
    fatlapit
    Post #239
    some more pics with water pipes n maybe some exhaust
    Posted 25th Apr 2013 at 22:30
    fatlapit
    Post #240
    also as you can see ive started to mock up the ducting for the 3 coolers (steering cooler should be on the left) there is a 19 row 235 mocal oil cooler on the right too, all needs to be ducted then fed back into the arch areas.
    Also the water pipes need rubbing down and coloured too.
    ANY CRITISISM I NEED NOW BEFORE I START FINISHING THE BLASTED THING!!!
    Posted 25th Apr 2013 at 22:35
    clen666
    Post #241
    Looking good mate.
    Why not get the non-ac facia without those two small holes?
    Team 'unintentional rat look'
    Posted 25th Apr 2013 at 22:43
    fatlapit
    Post #242
    didn't think about that tbh, but I was gonna use one for boost controller and one for a chicken switch for the fans
    Posted 25th Apr 2013 at 22:45
    clen666
    Post #243
    Ah I see, what's a chicken switch though?
    I like what you have done with the water pipes, hoping to do something similar myself
    Posted 25th Apr 2013 at 23:12
    fatlapit
    Post #244
    a switch that allows me to put one of my fans on early or if a relay fails, the bottom one was a bit fiddly but was ok I used 38 mm bends from rally design but there not finished yet they need rubbing back n coloured yet
    Posted 25th Apr 2013 at 23:18
    anth
    Post #245
    Exhaust Gas temp is a good idea.
    Posted 26th Apr 2013 at 07:29
    birk
    Post #246
    Ive just realised i cant have a rad like that with the bottom rad pipe, thats where im having my powersteering pump lol Doh
    07889376885
    Dan
    Posted 26th Apr 2013 at 11:09
    fatlapit
    Post #247
    Doe lol
    Posted 26th Apr 2013 at 13:34
    birk
    Post #248
    Looks like i will just have to get a custom one made, which is 3x as much Sad
    07889376885
    Dan
    Posted 26th Apr 2013 at 15:09
    Takedown
    Post #249
    Looking good!
    Which sump you got? an alloy one? (airco) or a steel one?
    Posted 26th Apr 2013 at 16:25
    fatlapit
    Post #250
    Standard mate
    Posted 26th Apr 2013 at 18:31
