Author Subject: odyssey pc680 battery
jimmyhackers
at the moment i have relocated my battery to the boot for beter weight distribution. its worked as the front end rolls less now. im still looking for other lightweight mods aswell and im "weighing" up my options pound for pound as it were Big grin. the battery compared to carbon fibre bonnet, lighter seats, plastic windows.....it seems a cheaper option
i was looking at these odyssey batteries. their over half the weight, over half the size and better capacity/cranking than my current battery,
my questions are
1. has anyone tried these batteires out before?, specificaly the pc680, what did you think of them?
2. i plan on mounting this under the paseenger seat as it should fit and aid my weight distriibution saga. will this be an mot fail?
thanks for any info in advance
Posted 16th Dec 2011 at 01:43
dump the heavy wheels first, you'll get more benefit from that than a lighter battery.#
1, probably, do a searhc.
2, no.
Posted 16th Dec 2011 at 10:32
jimmyhackers
sounds really silly and like im being hippocritical but i really like them, so much i dont mind the extra weight Smile
know anyone with a cnc wheel maker? wouldnt mind the same design in a lighter compound with a bit more dish on the rim. maybe a better offset aswell as i need 15mm spacers minimum for them to fit on my 306 with the coilovers.
thanks for the info
Posted 16th Dec 2011 at 15:00
This effect is in your head I'm afraid. 10kg taken off a 200kg engine is going to make absolutely no difference whatsoever.
Posted 16th Dec 2011 at 15:23
jimmyhackers
my batteries closer to 15kg :s thats like 7% difference, i know its really much less. i noticed it so lets just say im sensitive. Big grin so sensitive i noticed the diference when i mooved my battery from my boot to behind my rear passenger seat in my 1.4. cant do this in my gti as i want to keep the rear seats functional
thats kinda the reason why i looked for a better/smaller battery and found this. the half sized (pos) cable will counteract the slow cranking. ill get my weight distribution/reduction, and its will all be out of sight under the passenger seat.
the battery is situated rather high up in the engine bay. the majority of the engines weight is in the bottom end. this also gives me a feeling a carbon bonnet and plastics windows will be noticble through the corners aswell. seeing as there situated even higher up.
Posted 16th Dec 2011 at 15:54
velar
WRONG, every bit helps. !!
Posted 16th Dec 2011 at 16:19
quote:
[quote="jimmyhackers"
Yes.
Would you like to spend a grand per wheel?
Posted 16th Dec 2011 at 21:57
those wheels do not ever need spacers on a 306.
if you want them wider -
http://www.force-racing.co.uk/wheels-15/
Posted 16th Dec 2011 at 22:14
jimmyhackers
Yes.
not right now. think ill stick to 100 quid for a better battery to save 7kgs Big grin
Posted 16th Dec 2011 at 23:11
velar
You can get the odyssey pc680 for a lot less than £100
ebay clicky
Posted 16th Dec 2011 at 23:38
woody.
Tbh I'd wait until the battery was dead and then maybe buy an odyssey one. Think how much the cable from front to back may weigh, could be more than you think?
But as welshpug says, dump the heavy wheels and get some lighter ones. Less unsprung weight FTW!
Posted 17th Dec 2011 at 02:53
velar
My cable weighs just over 1Kg in total, but it's about getting weight further back in the car, and off the nose.
Posted 17th Dec 2011 at 12:33
jimmyhackers
i still have a use for the old batteries. i charge them with a solar panel for free and use them with my hho torch.
my cable too weighs around 1kg and is already installed. seeing as im about to half it i dont think it will offset the weight im loosing due to a new battery. i agree with you velar for the most part. making items lower will also aid cornering. hence me trying to shove this battery under the passenger seat. i was contemplating mooving my washer bottle to the boot or under a seat,
any other cheeky things like this youve done that i could imitate?
Posted 17th Dec 2011 at 12:56
jimmyhackers
oh and i did get it for 84 quid off ebay. cheapest they had new, was one going second hand for like a tenner at the time but.......new and shiny is my weakness
Posted 17th Dec 2011 at 12:59
I havent bothered looking into the Odyssey battery but i imagine it will be similar to the Powervamp that i have in my track car. It stated that it has a limited number of uses, i think it mentioned 1000 if under good conditions, but if you flatten it it loses some etc.
I dont think i would bother using one on my daily driver tbh.
Posted 17th Dec 2011 at 13:03
jimmyhackers
i know this would loose me a fair bit of weight, but once again im gonna drop a bombshell and tell all i think the majority of lightweight wheels look like wolfrace boy racer jobbies from halfords. only other wheels i really like a deepdish borbet type a's/similar
thanks for the info anyways
ill stick with the retro 205 gti's for the moment.
jimmyhackers
oh dear i havnt read this anywhere about this battery. hopefully its not an issue, says its life is 8 - 10 years. i will investigate further now. so basically if what your saying is true i can start and drive my car 1000 times :S (bout a years worth of driving). i dont plan on it going flat. ive mounted a solar panel on the parcel shelf thats kept my old battery topped up.
its ordered now so i may aswell use it and report back on here on how happy i am with it
Posted 17th Dec 2011 at 13:10
velar
Most are covered on this forum, but I would remove any front driving/fog lamps, get a smaller alternator, ditch Aircon, Strip the bonnet, (or get a GRP one] manual window winders, smaller single fan, aluminium brake calipers and diffo put some light wheels on it!!!! (have a look and daveyboys anthracite pro race 1.2s wheels on this track car thread Love Love)
P.S leave the water bottle were it is, but run it almost empty all the time.
Posted 17th Dec 2011 at 15:40
jimmyhackers
thanks for the info. ive done/planned on most of the stuff on your list already Smile
looks like im running out of options Sad
p.s just weighed my rear head rests today. 1kg each!!! i should of really weighed everything ive taken off the car. i bet its around the 30-40kg mark. pair that with the fact its phase one with no aircon or sunroof. should be pretty floaty about now. ill get it on the scales next time im down the scrapies. and make a "whats your vehicle weigh?" thread
Posted 18th Dec 2011 at 14:46
