displaying posts 1 to 25 of 74
Pages (3): [1] 2 3
Author Subject: steam supercharger?
jimmyhackers
i currently have a test car (1.4 306)
and i plan to try something rather,emmet brown.
hear me out and give me some advice/critasisms here.
Genral idea.
boil water on your exhuast to make high pressure steam. pump it into turbine attached by a belt to the engine. thus recycling otherwise waste heat energy back into kinetic energy
bit more complicated explanation.
i plan to remove the power steering pump to provide an easy mounting point for the tirbine hopfully using similar belts and pulleys.
i would like to try a hybrid tesla turbine (they seem simple and reletivly effficient compact etc)
the steam side will be a closed loop system with a reseviour, condensor, feed pump and boiler coil wrapped around the exhaust pipe. there will be a bypass/blow of valve for when not in use and an electric solenoid will controll flow (on/off)
i hope to gain 10bhp. i havnt seen anythign like this done before. i work with large scale fridge and ac systems so i know a bit about highpressure systems and think it may have its merits.
as i said this will be a test done on my 1.4 as a proof of concept i dont plan on butchering the gti just yet.
my main driving point for this route of crazyness was wen i was told less than half of petrols chemical energy is released as kinetic the rest is heat.
so what do you guys reacon?
Posted 5th Nov 2011 at 03:50
atterz
I reckon you are drunk and should go to bed!
owain wrote:
Posted 5th Nov 2011 at 04:42
I reckon you've clearly taken a pound of crack and need to give it up.
Posted 5th Nov 2011 at 09:50
honestly3k
Go for it i say, whats the worst that could happen? (the engine blows up in your face?) Dunno LOL
Posted 5th Nov 2011 at 10:09
honestly3k wrote:
the engine blows up in your face, the pipes explode spraying boiling water over the inside of the car giving you third-degree burns
Okay, I'm sold on the idea.
Posted 5th Nov 2011 at 10:11
monkeyman
How will you calculate feedback between the accelerator and turbine speed?
Have you seen how much water steam engines use LOL the weight of water carried will I think outweigh the increase in power.
If you want an extra 10hp just make a soft cut out for the alternator
Forum Search Clicky
Posted 5th Nov 2011 at 11:26
I'm sure someone's already done this before as a project, I'll see if I can find it.
Posted 5th Nov 2011 at 11:51
Found it.
Posted 5th Nov 2011 at 11:52
Laugh my ass off
Love it Owain, especially the rallye stripes!
Clapping
Posted 5th Nov 2011 at 12:01
monkeyman
http://www.gmcmotorsport.co.uk/electronics/gmc/free-power/prod_488.html
Check out those 48" rims on Owains hybrid LOL
Forum Search Clicky
Posted 5th Nov 2011 at 12:06
Obviously I tried getting Pro Race 1.2s, but they didn't have them in the right offset and hubcentric spacers are well pricey.
Posted 5th Nov 2011 at 12:08
atterz
Legend.
Posted 5th Nov 2011 at 12:13
honestly3k
Laugh my ass off
Posted 5th Nov 2011 at 12:22
stu
Laugh my ass off
That's awesome!
Posted 5th Nov 2011 at 12:39
jimmyhackers
i was stoned and i did go to bed after i posted it Smile
in heinsight i dont think it could actually be classed as a supercharger. more like a steam turbine engine assistor or somehting like that.
think about it more logically. if your cars 50% effecient that means theres the same amount being wasted as heat. so my hopeful 10bhp is a piddly figure. effectivly i could get another 75bhp out of my 1.4. i know in the real world it will be nowhere near that.
but still i think waste heat recovery is an avenue worth looking down.
i know the other 50% of heat energy isnt all located in the exhaust but i still reacon there enough there to run a fair sized turbine.
as for maintainging throttle speed im clueless. i was hopeing a tesla turbine would with its unique and efficient design just work regardless. failing that i could link up a regulator valve to match throttle speed. (im pretty good with my high pressure gas systems being a fridge and ac engineer)
i understand untill the exhuast is hot enough to produce high pressure steam the turbine attached by a fan belt ancilary will have a parasitic effect. this should be well overcome the steam kicks in
also tesl turbines can be ran in a closed loop system. meaning it should be reasonably compact. i have removed my battery so ther plenty of space there for stuff.
im hoping to do somethign a bit weird here. if it works ive done something rather unseen before.
the world is changed by men in sheds not laboratories
Posted 6th Nov 2011 at 22:34
Yes, but also by men in sheds who know what they're doing.
Posted 7th Nov 2011 at 00:29
I can make you some, but by the time they arrive they'll have invented diesel-electric.
Posted 7th Nov 2011 at 00:31
Nice one Phil, I'll drop you a PM Thumbs up
Jimmy - I think you should do it. Because I think it would be fantastic. Like a kind of forum Scrapheap Challenge. Bear in mind not all the wasted energy from an engine goes in heat, a fair bit goes in sound as well, and much of the heat is going out of the exhaust whether you like it or not.
Plus the added weight of the water, extra kit, pipes etc would easily counter any power gains. Personally though I don't think that should stop you. I think you should get the biggest bag of weed you can find, retreat to the shed and start a project thread. I would absolutely subscribe in a second.
Posted 7th Nov 2011 at 08:41
carbonfibre
I am absolutely convinced this is a great idea. Have you considered harnessing the wasted sonic energy too? You could weld a bass bin on the end of the zorst and in a clever reversal of technology convert the noise into electricity. SERS.
Get in your shed now and load the bong. We are waiting.
Hens teeth rocking horse poo Cossack Ph1.3
Posted 7th Nov 2011 at 09:21
jimmyhackers
i better start putting my money where my mouth is, ....right next to the spliff Razz
another sad note that most peopl kinda do but dont realise.
nearly all of our electricity is supplied by some form of steam turbine. this new nuclear fusion bo***cks,tokomaks etc........
essentially all just steam engines.
and for the joke about harnessing sound, its been done, its called a turbo. all sound is, is vibrating/moving air. the reason your turbo exhaust is still noisy is because its harnessed only some the the frequencies
the paradox is about this is that weve harnessed a shed load form the exhaust gas flow why not the exhauist gas heat? the peltier/seebeck route seems a more elegant solution but is way to expensive to get a good enough system to replace your alternator.
Posted 8th Nov 2011 at 00:27
When did you last see a portable steam turbine power station? I want one!
Posted 8th Nov 2011 at 00:42
jimmyhackers wrote:
nearly all of our electricity... essentially all just steam engines.
we've harnessed a shed load form the exhaust gas flow why not the exhauist gas heat?
Whilst there is some extremely questionable science and reasoning there, I reiterate my *need* to see this done, and I don't think you should let little things like physics and common sense get in your way. Whilst I would never advocate the use of drugs, I'm sure any judge would be understanding and appropriately lenient in this case, especially if you took him out for a country hoon in your new Doc Brown motor.
Posted 8th Nov 2011 at 08:09
jimmyhackers
www.gyroscope.com
Posted 8th Nov 2011 at 13:07
jimmyhackers
in all honesty id say inventions like this are not put into production due to customer stupidity.
most motorists find it hard enough to check there oil level and tyre pressure once a week.
asking them to make sure a water resevoir other than the radiator is topped up is beyond most (motorists) ability.
Posted 8th Nov 2011 at 13:12
jimmyhackers wrote:
www.gyroscope.com
I think if we hook a few of those up to the national grid instead of the coal powered plants, there's gonna be a lot of disappointed people when they flick the kettle on in the middle of *insert favorite program here*
Lets think, the small(ish), fairly efficient old double-compound action steam traction engines weighed what, about 7-10 tons? And were rated at a constant-use of 4 or 5hp?
Now, even if you let them build pressure reserves up and ran at a loss (i.e, using more steam than you're producing), you could boost that at peak to about 40hp or so, for a few minutes, until your pressure dropped off.
Thats with a boiler the size of your car?
Your other problem with recovering the heat energy out of the exhaust, is you ideally want to collect it as close to the head as possible, and if you do manage to do that anywhere near to the energy extraction you need, it's going to mean your cat never gets hot enough to work properly.
You might, just might, be able to run the alternator (or an auxillary alternator) off a combination of the water jacket heat and exhaust heat, as BMW have been hoping to do, although in their case it's hooked up to an electric assist unit on a turbocharger which boosts the effiecency of the engine too. And they haven't got it to work properly yet either. And it weighs a shitload.
Posted 8th Nov 2011 at 13:34
Pages (3): [1] 2 3
