Author Subject: How long do r888's last?
lurch86
Hello, I bought some second hand r888's with about 3mm tread left. I done 1 track day 1 hour 45mins driving on track and they now look like this...
Surely this cant be right? Must be something to do with the car setup can it?
Wanted list... (P.m me if you have any)
Rollcage.
Strut Braces.
Lydden Hill 31/10/2015 Last Track day
1st time at Snetterton on the Bike! 22/08/2017
Posted 16th Oct 2011 at 16:54
matty_rallye
Depends, if its evenly worn then probably is normal.
Pressures have a huge effect on wear if it is uneven. We usually run them at between 22-24psi.
Also the n/s/f will always take a hammering if most corners are right handers!
Are they softs or mediums?
2.1 16v 306 Rallye.
Posted 16th Oct 2011 at 17:28
I bought some new but second hand R888's a couple of years ago, so far i've done around 10 laps of the nordschleife, two trackdays at oulton park, one trackday at cadwell park, one 15 min session round rockingham and a few road miles on them and theres still evidence of tread on them. AFAIK they only come with 5mm tread from new so your wear looks excessive but i guess its down to how hard you are on them.
Mine are GG compound and i tend to run them around 25psi cold then check the pressure after 15 mins on track. Smile
Posted 16th Oct 2011 at 17:41
lurch86
Yea I ran them on 25psi cold. Its only the fronts that have worn really bad. They are SG Compound, super soft. I dont think having stiff rear shocks and standard front suspension helped much either (Dont ask, lol). £200 tyres for 1 track day is heart breaking! :'(
Rollcage.
Strut Braces.
Posted 16th Oct 2011 at 18:24
jeffers Forum Admin
Was this on a proper circuit or an airfield trackday?
Team Running Engine again!
Team Negative Camber!
Posted 16th Oct 2011 at 20:15
Jesus, no that is not normal for two hours driving. I'd say one of following thing is wrong:
a) Your driving
Whistle
What car are they on?
Posted 16th Oct 2011 at 20:46
Im not sure if i once read that the SG compound may be too soft for a 306 and overheat, which i guess would kill the tyre quicker than desired.
Posted 16th Oct 2011 at 21:02
True, but even with a soft tyre in the middle of the summer you'd have to be scrubbing the tyres all over the place to do damage like that.
Posted 16th Oct 2011 at 21:03
lurch86
Its a proper race circuit, probably not the best condition circuit around. My road dunlops I used last time were fine. I was giving it hell for leather (but aren't you supposed to?) I think you could be right with them being too soft. They were very hot after each run!
Rollcage.
Strut Braces.
Posted 16th Oct 2011 at 21:15
Yup, too soft + raping your tyres = raped tyres Yes
Posted 16th Oct 2011 at 21:23
lurch86
Shall I try some mediums or just use the half decent set of road'ies? Cheers
Edit: Most of you lot do track days, do you mind telling me what tyres you use, how long they last and how good they are? Thanks
Rollcage.
Strut Braces.
Posted 16th Oct 2011 at 22:13
Im using 195/50/15 R888's GG on some Team Dynamics Pro Race 1.2 rims (15" 7J).
Like i said above, something like 10 fast-ish laps of the 'ring, two days at Oulton park, one day at Cadwell park, i think two 15 minute sessions round rockingham and a few light road miles.
Theres still a trackday or two left in them if its dry, the wear isnt perfectly even on mine so for next year i'm wanting a bit of negative camber.
Once these tyres are dead i think im going for another set of R888's, same spec as these, although a set of slicks is tempting once i get a cage fitted.
Posted 17th Oct 2011 at 06:56
Using decent road tyres (Michelin PE2s or similar, £60 a corner or so) I can do maybe five trackdays on a set, and that's airfields and tracks. I've not used 888s on the car yet (although I have a set ready to go on next Spring) but there's no way they should go that quickly.
In all honesty that amount of damage is down to driving style. I've toned back my speed in corners a lot lately, you save your tyres and actually get round an awful lot quicker as what sounds like some incredible drift is actually you just doing that to your tyres as you understeer towards a wall Yes
Posted 17th Oct 2011 at 08:04
lurch86
I think I'll put it down to having super softs rather than mediums. I think next time I'll buy some decent road tyres until the summer and try the mediums. I wasn't understeering around corners really.. When I felt the front sliding I would let off the throttle. I was driving fast but I was driving sensible.
I dont think the fact I had stiff rears and standard front suspension helped either...
Rollcage.
Strut Braces.
Posted 17th Oct 2011 at 12:58
My front suspension is very soft compared to the rear and even I don't munch tyres like that! LOL
Tend to fook the rear shoulders over instead.
Posted 17th Oct 2011 at 23:32
lurch86
Have a look at my vid.. I think my driving was more tyre friendly? I wasn't understeering and wasn't spinning the wheels at all. I will try one more time on Medium compound and if it still does it there must be something seriously wrong with my driving or the track lol.
I was well excited about using my 888's but after a couple of goes seeing the tyres warn that bad just made my heart sink! £200 for one track day on tyres is not affordable for me!
Rollcage.
Strut Braces.
Posted 18th Oct 2011 at 05:47
No, doesn't seem too bad, perhaps just overheated them then, what were the hot pressures?
Posted 18th Oct 2011 at 14:14
lurch86
Unfortunately I didnt check the warm tyre pressures as I forgot my pressure guage so had to borrow one when they were cold and didnt want to bother the person I borrowed the guage from again. But I cant imagine them being far off 30psi hot would they?
Rollcage.
Strut Braces.
Posted 18th Oct 2011 at 17:17
could quite easily be a lot higher.
Posted 18th Oct 2011 at 17:23
I managed to wear a set of brand new GG compound R888s down to the wear indicators in less than three hours, it was a really hot day on a fairly aggressive airfielt circuit though. Grip was astonishing and understeer was non-existan, however huge grip takes a toll on the rubber. I was running 36psi hot as I found that gave me even wear accross the surface and minimal shoulder wear. I did'nt have negative camber or coilovers at the time though so who knows what it would be like but I reckon you could come down on the pressures a lot with the right amount of camber etc.
Posted 18th Oct 2011 at 17:42
