displaying posts 1 to 25 of 33
Author Subject: right...
mcfc1987
hopefully someone can offer some advice
picked up a rallye on tuesday, no signs of a leak etc, looked tidy, completed the 460 mile trip brough it home in the small hours. woke up this morning and everything seemed fine.
drove it to work and while i was there i decided to nip it to a recommended garage 1 minute walk away to have the wheel bearing changed as i just couldnt be bothered to do it myself. they did that no problem and i picked it up after work and drove it home. 2 hours later nipped to asda and back and pulling back up noticed a patch of oil on the floor where i was parked for the two hours earlier. set the car down level, came back 10 minutes later to find a few more drips. jacked the car up and there was a good covering of oil on most of the drivers side parts that was collecting and dripping from the bottom of the block, got some kitchen roll and cleaned it all off the block and waited a good 20 minutes but no more appeared.
Rolled the car somewhere clean and i have locked it up for the night.
first thing in the morning i will check the engine oil level, is there anyway of checking the gearbox oil level??
Main question is that if (and fingers crossed it is) the block is still clean in the morning and the engine oil level is fine, is there any way that in changing the wheel bearing they could have ended up disturbing the drive shaft causing a gearbox oil leak, and could i have driven with a leaky drive shaft and not known??
In my position, other than suicide or punching the pregnant mrs who is constantly repeating "you will keep buying these pieces of shit", what would be the next step for most people??
Posted 5th Oct 2011 at 19:51
techdw
Might have pulled on the Drive Shaft slightly mate?? Causing it to leak, I did it once on my XR2 years ago
Haha my misses says near the same thing, I dear tell her about the beam yetLOL
Posted 5th Oct 2011 at 19:54
sixygti2
Maybe.
I have had similar recently, drops of oil shortly after driving. Turned out it was leaking from the oil filter, running down and being pushed back along the car as I was driving! Guess the seal had gone hard over time and not sealed properly. Quick swap over and top up with oil and seems ok so far! No more leaky bits!
Still watching you...
Posted 5th Oct 2011 at 19:56
jord294
if it was the o/s wheel bearing they changed, then no they couldn't of pulled it from the box
Posted 5th Oct 2011 at 19:57
mcfc1987
driver side bearing
Posted 5th Oct 2011 at 19:59
marksorrento205
Can you smell the oil on the floor? ( i.e dip your finger in it ) as gearbox oil has a distinctive smell compaired to engine oil.
As Andy said if its the drivers side they aint pulled the shaft out.
mcfc1987
didnt smell it and washed it off the drive so it didnt cause anymore corrosion on the tarmac
Posted 5th Oct 2011 at 20:00
marksorrento205
Fair do's Smile
Posted 5th Oct 2011 at 20:01
honestly3k
Not cam carriers leaking is it?
Posted 5th Oct 2011 at 20:04
bubbagti6
possibly your front crank seal?
They may take my crayons
but they'll never have my windows
Posted 5th Oct 2011 at 20:06
sixygti2
Get your fingers dirty and feel where its coming from! Yes
Posted 5th Oct 2011 at 20:08
mcfc1987
i have no idea where to look and how do i check where the oil is coming from?
if it was a big leak wouldnt it have emptied over the 500 miles in 24 hours??
CUJ
She speaks a lot of sense.
340 horses
Posted 5th Oct 2011 at 20:09
sixygti2
You should be able to see any "wet" patches and follow them back to the source!?
If its not a lot then i guess it might be tricky!
I could see the oil running down the front of the block, put my hand down and felt around the filter and bingo!
Posted 5th Oct 2011 at 20:11
jim01uk
Quoted for truth.
Posted 5th Oct 2011 at 20:14
mcfc1987
she does indeed!
Posted 5th Oct 2011 at 20:16
matt evans
Just have a quick look inside the cambelt cover, if the cam seals have gone, it'll probably be all over the belt etc etc. If dry, my moneys on the front main oil seal. Give it a good clean off with brake cleaner and leave it running till you can pin point it exactly.
honestly3k wrote:
owain wrote:
Posted 5th Oct 2011 at 20:18
mechanical_repairs
If you can see some oil on the floor put your finger in it and give it a smell, if it makes your eyes water it will be gearbox oil and may be a drive shaft seal.
Otherwise if it has no real smell it will be engine oil, check the level on the dipstick, a oil leak always looks worse than it is.
If you go to the petrol station and drop a pennies worth on the four court it looks horrendous.
Carl
Posted 5th Oct 2011 at 20:20
cwspellowe
o/s driveshaft may have moved if the intermediate bearing wasn't held in place by the hockey sticks. Other than that it won't be gearbox oil leak.
Bye bye Sundance Kid Sad
Posted 5th Oct 2011 at 20:21
matt evans
Carl
What Carl's trying to say, is gearbox oil smells like tom cat p*ss!LOL
Posted 5th Oct 2011 at 20:23
mcfc1987
if theres any oil in the morning i'll have a smell
Posted 5th Oct 2011 at 20:24
jim01uk
I always thought it smelt like rotten onions Dunno
Posted 5th Oct 2011 at 20:25
mcfc1987
just swiped my fingers on the remains of the first puddle and it does have a distinctive smell to it
**edit** washed my hands a couple of times and can still smell whatever oil it is on my fingers
how do i check gear box oil levels or is there no way?
Posted 5th Oct 2011 at 20:38
SteviePut
power steering ram maybe
Posted 5th Oct 2011 at 20:40
720puggti
Hi mate,
mcfc1987 wrote:
driver side bearing
If this is the front drivers side, I have to agree with Chris:
Chances are the hockey sticks were forgotten and the shaft has been migrating out causing oil to leak from the differential.
As you've just mentioned, a funny smell normally indicates gearbox oil...
Deepak Gohil
Posted 5th Oct 2011 at 20:41
